Part Number: TUSB4041I-Q1
Team,
Customer would like to know if there's a minimum/maximum value (0.15±?) on our TUSB4041IPAPRQ1 thermal pad corner, marked in red as below figure from datasheet. Could you help to check? Thanks.
Team,
Hi Yu:
let me check with internal team and will keep you update.
Brian
Yu:
Thanks for patience, I have not got feedback from our package engineer. Please wait one more day.
Brian
Yu:
Here is the reply from our package engineer:
Usually “Typical Value” in a package drawing means there is more than one location with that dimension. In this example, all those features around the DAP have the same dimension. There is no min/max value since the PCB land pattern will only have a square or rectangle. All those features will be ignored in the PCB land pattern or stencil. Mold flash and vendor capabilities usually highlighted in the footnote..
Brian
