Part Number: DP83826E
Hi Team,
I have a question on the LED configuration for the basic mode. The DS says if strap selecting 0, a 1 kΩ pull-up resistor in series with the LED should be used and a 5 kΩ pull-down resistor. does there still need the 1.5KkΩ pull-down resistor to be parallel with the 5kΩ resistor?
In addition, since the the LED polarity will always be active low, does it means the LED will be always ON (because it's pulled up to 3.3V)? thanks a lot.
Yang
