Other Parts Discussed in Thread: TPD4E02B04
I am using DP to eDP 4 lane interface board.
For ESD protection I have placed TPD8S009DSMR part to protect my device, but i see when solder the TPD8S009DSMR on the board, the quality of the signal gets worse.
I have tested it without the TPD8S009DSMR, and everything works fine.
The issue is that when TPD8S009DSMR is soldered, i can see instability in the vide of the panel I am using, something similar to flickering (garbage or so).
The 5 volts are provided from and LDO, which is powering a pwm circuitry as well.
Do you have any recommendation?
