DP83TC812EVM-MC: 100Base-T1 signal test
Part Number: DP83TC812EVM-MC
hi team,
Can you provide the measured waveform of the 100Base-T1 of this evaluation board? The waveform I measured myself was poor!
    I would suggest probing the 100Base-T1 signal using a differential probe across the TRD_M and TRD_P pins.
    The signal should look like the yellow signal below at link up.
    Melissa
  • Hi I want to see   the   signal  details, could you please  Stretch the  timeline ?
    Why do you want to see the signal details? What is this for? Are you seeing an issue with the TI DP83TC812EVM?
    Melissa
  • my  test result is poor, I want to  see  your  test result  as a compare,  I am not sure  the signal   I test whether is ok
    Please confirm you are using a differential probe and measuring it across the connector output of the TRD_P and TRD_M pins.
    If you do not have a differential probe, you may use a single ended probe to measure TRD_P to GND in channel 1 and TRD_M to GND in channel 1 and perform a MATH function on the scope and do Channel1-Channel2.
    Melissa
  • I measured it the way you said, wiht 3.5GHz  bandwidth    differential probe。 I want to  the signal  detail   you test   as  a contrast, wil you  provide it? thank you!
    The expected waveform is shown above. Can you provide a photo of your waveform? Are you trying to measure the waveform for compliance? What is your application?
    If there is a specific issue with your EVM, I’d be happy to help.
    Melissa
  • hi
    1.The expected waveform is shown above------ I can‘t see ’the TRD_P A&TRD_N  details,
    2.Can you provide a photo of your waveform?---------A:  I has put my  waveform below my qustion  at  the begginning.
    3.Are you trying to measure the waveform for compliance? What is your application?---- I am testing the EVM board‘s’  TRD_PP&TRD_N  signal  Quality ,  I plan to  use  the PHY chip  for  our  new  design,  I should  make  sure this  PHY  chip  is no problem; I don't thik  there is  any issue   in the EVM ,I just want to see  the  RD_PP&TRD_N  signal  details  as  a contrast.
    Im a little confused on what specific derails you require. The amplitude? The scale is shown in the photo if needed.
    Are you measuring the signal at linkup? Can you provide a photo of your probe?
    Melissa
