Part Number: DP83867IS
Dear TI
We changed the PCB design and conducted a new test.
(There are two-PHY ICs on the PBA, LAN#0 & LAN#1)
Some failed.
Please guide me on the solution.
[Based on LAN Compliance]
(1) Problem#1(10Base-T) : w/ TPM level is 700mV. (w/o TPM level is 1.4V)
-.Measure 2 items(Link Test Pulse)
-->No TPM(14.3.1.2.1) item is PASS (LAN#0, LAN#1)
-->With TPM(14.3.1.2.1) item is FAIL (LAN#0, LAN#1)
--> I2C register :
mii write 0x0d 0x001F 0x8000
=> mii write 0x0f 0x001F 0x8000
=> mii write 0x0d 0x0000 0x0100
=> mii write 0x0f 0x0000 0x0100
=> mii write 0x0d 0x0010 0x5008
=> mii write 0x0f 0x0010 0x5008
(2) Problem#2(100Base-T) : I tested it with Mode 5 and it failed. Any other setting?
-.Measure 1 items(Return Loss)
-->Transmitter Returen Loss(9.1.5) item is PASS(LAN#0, LAN#1)
-->Receiver Return Loss(9.2.2) item is FAIL(LAN#0, LAN#1)
--> I2C register : (Test Mode 5)
=> mii write 0x0d 0x0000 0x2100
=> mii write 0x0f 0x0000 0x2100
=> mii write 0x0d 0x0009 0xBB00
=> mii write 0x0f 0x0009 0xBB00
=> mii write 0x0d 0x00D 0x001F
=> mii write 0x0f 0x00D 0x001F
=> mii write 0x0d 0x00E 0x0025
=> mii write 0x0f 0x00E 0x0025
=> mii write 0x0d 0x00D 0x401F
=> mii write 0x0f 0x00D 0x401F
=> mii write 0x0d 0x00E 0x0480
=> mii write 0x0f 0x00E 0x0480
(3) Problem#3(1000Base-T) : shortage of Margin
--> Differential Output Templates With Disturber's Point H is FAIL(LAN#1)
--> I2C register : (Test Mode 1)
=> mii write 0x0d 0x0000 0x0140
=> mii write 0x0f 0x0000 0x0140
=> mii write 0x0d 0x0009 0x3B00
=> mii write 0x0f 0x0009 0x3B00
=> mii write 0x0d 0x00E 0x01D5
=> mii write 0x0f 0x00E 0x01D5
=> mii write 0x0d 0x00E 0xF508
=> mii write 0x0f 0x00E 0xF508
