SN75176B: N75176B: R pin received unexpected signal while the differentiated signal is 0(A-B) in noise environment
Part Number: SN75176B
Other Parts Discussed in Thread: THVD1420,
Hello, I saw a forum with the same name for this topic. I also encountered the same problem. The principle diagram is basically the same. The SN75176 used before will get better effect when replaced by THVD1420, but R will still have abnormalities. The pull-down resistance is 4.7k, the terminal resistance is 120Ω, and the current limiting resistance is 20Ω。
Is it necessary to adjust the pull-down resistance to achieve, how to adjust, thank you
