Hi Ross,
at moment I can not change the PHY ID because I am using the card with an application SW that
runs only with address ID = 0x02.
I think that the ID = 0x02 is read correctly by DP83848 device but the MDIO interface responds wrong.
I can observe three typical situations:
a) Initially the OUI is read correctly then the registers show wrong values (at the same time the Ethernet link is up)
Firmware 'Microcode version 0.0.1 for P1021 r1.0' for 1021 V1.0
QE: uploading microcode 'Microcode for P1021 r1.0' version 0.0.1
In: serial
Out: serial
Err: serial
Net: eTSEC1 [PRIME]
Hit any key to stop autoboot: 0
=> mii info
PHY 0x02: OUI = 0x80017, Model = 0x09, Rev = 0x00, 100baseT, HDX
PHY 0x03: OUI = 0x80017, Model = 0x09, Rev = 0x00, 10baseT, HDX
=> mdio read 2 0-19
Reading from bus FSL_MDIO
PHY at address 2:
0 - 0xffff
1 - 0xffff
2 - 0xffff
3 - 0xffff
4 - 0xffff
5 - 0xffff
6 - 0xffff
7 - 0xffff
8 - 0xffff
9 - 0xffff
10 - 0xffff
11 - 0xffff
12 - 0xffff
13 - 0xffff
14 - 0xffff
15 - 0xffff
16 - 0xffff
17 - 0xffff
18 - 0xffff
19 - 0xffff
b) the OUI value is wrong and the registers show wrong values (at the same time the Ethernet link is up) only for PHY 0x02
In: serial
Out: serial
Err: serial
Net: eTSEC1 [PRIME]
=> mii info
PHY 0x02: OUI = 0x3C34D6, Model = 0x12, Rev = 0x01, 100baseT, HDX
=> mdio read 2 0-19
PHY at address 2:
0 - 0xffff
1 - 0xffff
2 - 0xffff
3 - 0xffff
4 - 0xffff
5 - 0xffff
6 - 0xffff
7 - 0xffff
8 - 0xffff
9 - 0xffff
10 - 0xffff
11 - 0xffff
12 - 0xffff
13 - 0xffff
14 - 0xffff
15 - 0xffff
16 - 0xffff
17 - 0xffff
18 - 0xffff
19 - 0xffff
=>mdio read 3 0-19
PHY at address 3:
0 - 0x3100
1 - 0x7849
2 - 0x2000
3 - 0x5c90
4 - 0x1e1
5 - 0x0
6 - 0x4
7 - 0x2001
8 - 0x0
9 - 0x0
10 - 0x0
11 - 0x0
12 - 0x0
13 - 0x0
14 - 0x0
15 - 0x0
16 - 0x0
17 - 0x0
18 - 0x0
19 - 0x0
c) the BMCR register shows different value using multiple readings only for PHY 0x02 (at the same time the Ethernet link is up)
- initially the value is correct
- then the value change
- finally the value is 0xffff and the MDIO bus is blocked (to unblock the MDIO interface is necessary to reset the DP83848 device)
In: serial
Out: serial
Err: serial
Net: eTSEC1 [PRIME]
=> mdio read 2 0
PHY at address 2:
0 - 0x3100
=> mdio read 3 0
PHY at address 3:
0 - 0x3100
=> mdio read 2 0
PHY at address 2:
0 - 0x3100
=> mdio read 2 0
PHY at address 2:
0 - 0x3001
=> mdio read 2 0
PHY at address 2:
0 - 0x3001
=> mdio read 2 0
PHY at address 2:
0 - 0x3101
=> mdio read 2 0
PHY at address 2:
0 - 0x3101
=> mdio read 2 0
PHY at address 2:
0 - 0x3100
=> mdio read 2 0
PHY at address 2:
0 - 0xffff
Do you know a condition that could block the MDIO interface ?
Could you comment me the Figure 5.1 Power-Up Timing (page 17 of data sheet) ?
Thank you in advance
Aniello
