Part Number: DS80PCI810
Other Parts Discussed in Thread: DS80PCI800, SN75LVCP601, SN65LVPE501, DS50PCI402, DS80PCI402, , DS125BR820, DS160PR410
Hi Sirs,
Sorry to bother you.
May i know what different between linear re-driver and non linear re-driver ?
Linear redriver basically uses EQ for signal attenuation compensation, while flat gain and SW are both for voltage swing.
In the past, the redriver (ie. DS80PCI800) used EQ & De-emphasis for signal attenuation compensation.
Does this also represent the placement of the Linear Redriver, which is more unrestricted?
