Part Number: TPS65987D
Other Parts Discussed in Thread: TUSB544
Hello, i have a question about TPS65987D master I2C interface. Is it possible to use it to program a redriver for example and if so how would one go about it.
The redriver TUSB544 has Linear Equalization that can be programmed through I2C. Seeing that TPS65987D has a master I2C interface, is it possible to use it in this way? We want to avoid using an extra MCU just to program the redriver.
Checking the datasheets and forums couldn't find anything on how this "TPS65987D master I2C interface" is controllable. Does it read values from flash memory and sends them over I2C or is there a special way to it?
Any help is welcomed , thank you in advance.
