Part Number: SN74LVC1G07
Other Parts Discussed in Thread: SN74LVC1G32, SN74LVC1G97, SN74LVC1G57
Hi Sir,
May I know if we have buffer with enable pin control?
I need non-inverting, open drain output and one channel buffer.
Thank you.
Hi Sir,
Thank you.
There is no single device with this function.
If the enable signal is active low, you can put an OR gate (e.g., SN74LVC1G32) in front of the SN74LVC1G07.
If the enable signal is active high, you need an OR gate with one inverted input, i.e., SN74LVC1G57 or SN74LVC1G97.
