Other Parts Discussed in Thread: TL7702B, SN74AUP1G125,
I would like to implemente a basic latch on this way:
In the simulation, this works properly, but I would like to know if there is any way to change R3 by a pull up resistor to set the output HIGH on startup. When I change R3 by a pull up, the output also starts at LOW level. I assume the output is set to LOW level prior to check the inputs, so the input are also set to low through R2.
Please could you confirm the output startup state?
Thank you a lot!
