SN74S124: Functions of the pins
Part Number: SN74S124
Hi Team,
A customer would like to know the functions of the pins of SN74S124 because the datasheet has very limited information.
Danilo
  • Hi Danilo
    The SN74S124 is a dual voltage controlled oscillator (VCO) with isolated supply and ground for the internal oscillator (isolated from the control circuitry).
    I pulled some information from an old logic data book (https://www.ti.com/lit/ug/scyd013b/scyd013b.pdf)
    The "FREQUENCY CONTROL" and "RANGE" pins take a 1V to 5V input.
    The "Cext" pins should be connected to either side of a capacitor to provide the frequency range for operation. Capacitor size determines the base output frequency as per figure 1 of the datasheet.
    The input voltages at "FREQUENCY CONTROL" and "RANGE" will shift the base frequency as per the graph in figure 2 of the datasheet.
    I think everything else is fairly self-explanatory, If you need me to go into details on anything, please let me know.
  • Hi Team,
    The customer wants to know the functions of pins, specifically pins FC, RNG, CX1, CX2 and OSC.
    Danilo
  • Hi Emrys,
    Thank you very much for sharing this information.
    Danilo
