I am unable to get DHCP Assigned IP when i connect to the ethernet, But through my laptop shared ethernet i got DHCP ip Assigned,
I am working over a charger and my code is almost final the only problem is when i connect the ethernet to my PC Shared ethernet port i am able to access the server as DHCP IP assigned,but when i try to access through real ethernet of my modem or some other ethernets DHCP IP do not assigned.I have already tested with multiple ethernet ports.Every port is working with my PC and other sevices.
Please check the File for some configuration changes.I used enet_weather example library.
// eth_client.c - This file handles all of the Ethernet connections using lwIP.
// Copyright (c) 2014-2017 Texas Instruments Incorporated. All rights reserved.
// Software License Agreement
// Texas Instruments (TI) is supplying this software for use solely and
// exclusively on TI's microcontroller products. The software is owned by
// TI and/or its suppliers, and is protected under applicable copyright
// laws. You may not combine this software with "viral" open-source
// software in order to form a larger program.
// THIS SOFTWARE IS PROVIDED "AS IS" AND WITH ALL FAULTS.
// NO WARRANTIES, WHETHER EXPRESS, IMPLIED OR STATUTORY, INCLUDING, BUT
// NOT LIMITED TO, IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A PARTICULAR PURPOSE APPLY TO THIS SOFTWARE. TI SHALL NOT, UNDER ANY
// CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL, OR CONSEQUENTIAL
// DAMAGES, FOR ANY REASON WHATSOEVER.
// This is part of revision 2.1.4.178 of the EK-TM4C1294XL Firmware Package.
#include <stdint.h>
#include<string.h>
#include <stdbool.h>
#include "inc/hw_memmap.h"
#include "inc/hw_types.h"
#include "driverlib/flash.h"
#include "driverlib/gpio.h"
#include "driverlib/interrupt.h"
#include "utils/ustdlib.h"
#include "driverlib/sysctl.h"
#include "driverlib/systick.h"
#include "utils/lwiplib.h"
#include "lwip/dns.h"
#include "eth_client.h"
#include "json.h"
#include "utils/uartstdio.h"
#include "driverlib/uart.h"
#include "PacketFormat/format.h"
#include "PacketFormat/tables.h"
#include "UART_Control/UARTHandler.h"
// Flag indexes for g_sEnet.ui32Flags
#define FLAG_TIMER_DHCP_EN 0
#define FLAG_TIMER_DNS_EN 1
#define FLAG_TIMER_TCP_EN 2
#define FLAG_DHCP_STARTED 3
#define FLAG_DNS_ADDRFOUND 4
// g_sEnet.ulRequest Values
#define WEATHER_NONE 0
#define WEATHER_CURRENT 1
#define WEATHER_FORECAST 2
extern uint8_t TestMode;
char buftemp[255];
uint8_t PacketType=e_None;
extern funct ReqFunctions[];
extern TransmitProcess ProcessTransmit; /*Ethernet Transmit Structure*/
extern char Response[1024];
extern Web_Socket_Flags WebSocketflags;
extern WebSocket_Strct WebSocket;
// The current state of the Ethernet connection.
struct
volatile uint32_t ui32Flags;
// Array to hold the MAC addresses.
uint8_t pui8MACAddr[8];
// Global define of the TCP structure used.
struct tcp_pcb *psTCP;
// Global IP structure to hold a copy of the IP address.
struct ip_addr sLocalIP;
// Global IP structure to hold a copy of the DNS resolved address.
struct ip_addr sServerIP;
// The saved proxy name as a text string.
const char *pcProxyName;
volatile enum
iEthNoConnection,
iEthDHCPWait,
iEthDHCPComplete,
iEthDNSWait,
iEthTCPConnectWait,
iEthTCPConnectComplete,
iEthQueryWait,
iEthTCPOpen,
iEthIdle
} eState;
unsigned long ulRequest;
tEventFunction pfnEvent;
g_sEnet;
// Maximum size of an weather request.
#define MAX_REQUEST 4096//2048
extern uint32_t g_ui32SysClock;
extern uint32_t g_ui32IPaddr;
// Various strings used to access weather information on the web.
char g_cWeatherRequest[] =
"GET http://api.openweathermap.org/data/2.5/weather?q=";
char g_cWeatherRequestForecast[] =
"GET http://api.openweathermap.org/data/2.5/forecast/daily?q=";
char g_cMode[] = "&mode=json&units=metric";
char g_cAPPIDOpenWeather[] =
"&APPID=afc5370fef1dfec1666a5676346b163b";
char g_cHTTP11[] = " HTTP/1.0\r\n\r\n";
/****************Hnadshake Data and URL**************/
//char cmd_1[] ="GET /EFILLXOCPP20J/AC001TEST HTTP/1.1\r\n";//"GET HTTP/1.1\r\n";//"GET http://65.0.24.136:3002/EFILL002 HTTP/1.1\r\n";
//char cmd_2[] ="Host: 13.127.80.198:6002\r\n";
//char cmd_1[] ="GET /OCPP2.0.1/AC001TEST HTTP/1.1\r\n";//"GET HTTP/1.1\r\n";//"GET http://65.0.24.136:3002/EFILL002 HTTP/1.1\r\n";
//char cmd_2[] ="Host: 65.0.24.136:3002\r\n";
char cmd_1[] ="GET /EFILLXOCPP16J/EFILLAC001_00002 HTTP/1.1\r\n";
//char cmd_1[] ="GET /EFILLXOCPP16J/EFILLAC001_00007 HTTP/1.1\r\n";
//char cmd_1[] ="GET /EFILLXOCPP16J/EFILLAC001_00001 HTTP/1.1\r\n";
//char cmd_1[] ="GET /EVELTXRFIK/PRO-GUJ-SZ-AC-002 HTTP/1.1\r\n";
//char cmd_2[] ="Host: econnect.electreefi.com:80\r\n";
char cmd_3[] ="Upgrade: websocket\r\n";
char cmd_4[] ="Connection: Upgrade\r\n";
char cmd_5[] ="Sec-WebSocket-Key: hsgS1BezikgQ9FxPJ3qWyw==\r\n";
char cmd_6[] ="Sec-WebSocket-Protocol: ocpp1.6\r\n";
char cmd_7[] ="Sec-WebSocket-Version: 13\r\n\r\n";
// This structure holds the state and control values for the weather requests.
struct
// The current weather source.
tWeatherSource eWeatherSource;
// The format expected from the weather source.
enum
iFormatJSON
eFormat;
// The application provided callback function.
// The application provided weather information structure.
tWeatherReport *psWeatherReport;
// The local buffer used to store the current weather request.
char pcRequest[MAX_REQUEST];
// The number of valid bytes in the request.
uint32_t ui32RequestSize;
g_sWeather;
// Close an active connection.
void
EthClientReset(void)
// No longer have a link.
g_sEnet.eState = iEthNoConnection;
// Reset the flags to just enable the lwIP timer.
g_sEnet.ui32Flags = (1 << FLAG_TIMER_DHCP_EN);
// Reset the addresses.
g_sEnet.sLocalIP.addr = 0;
g_sEnet.sServerIP.addr = 0;
// Deallocate the TCP structure if it was already allocated.
if(g_sEnet.psTCP)
// Clear out all of the TCP callbacks.
tcp_sent(g_sEnet.psTCP, NULL);
tcp_recv(g_sEnet.psTCP, NULL);
tcp_err(g_sEnet.psTCP, NULL);
// Close the TCP connection.
tcp_close(g_sEnet.psTCP);
g_sEnet.psTCP = 0;
// Handles lwIP TCP/IP errors.
// \param vPArg is the state data for this connection.
// \param iErr is the error that was detected.
// This function is called when the lwIP TCP/IP stack has detected an error.
// The connection is no longer valid.
// \return None.
static void
TCPError(void *vPArg, err_t iErr)
// Finalizes the TCP connection in client mode.
// \param pvArg is the state data for this connection.
// \param psPcb is the pointer to the TCP control structure.
// \param psBuf is the buffer structure that holds the data for this receive
// event.
// \param iErr is not used in this implementation.
// This function is called when the lwIP TCP/IP stack has completed a TCP
// connection.
// \return This function will return an lwIP defined error code.
static err_t
TCPReceive(void *pvArg, struct tcp_pcb *psPcb, struct pbuf *psBuf, err_t iErr)
struct pbuf *psBufCur;
// char buftemp[1024];
int32_t i32Items;
if(psBuf == 0)
// Tell the application that the connection was closed.
if(g_sWeather.pfnEvent)
g_sWeather.pfnEvent(ETH_EVENT_CLOSE, 0, 0);
g_sWeather.pfnEvent = 0;
// Close out the port.
tcp_close(psPcb);
if(psPcb == g_sEnet.psTCP)
g_sEnet.psTCP = 0;
g_sEnet.eState = iEthIdle;
PacketType = e_None;
return(ERR_OK);
if(g_sEnet.eState == iEthQueryWait) //Data Response for Query
// memset(buftemp,0,psBuf->len);
// memcpy(buftemp ,psBuf->payload,psBuf->len );
// UARTprintf("\n\t%s",buftemp);//@@@
// UARTprintf("\n\tLen:- %d",psBuf->len);//@@@
// UARTprintf("\n\t%s",((uint8_t *)psBuf->payload));//@@@
// UARTprintf("\n");
i32Items = ParseExample(0,psBuf);
// UARTprintf("NumberofItems: %u\n\r",i32Items);
if(i32Items>0)
g_sWeather.pfnEvent(ETH_EVENT_RECEIVE,
(void *)g_sWeather.psWeatherReport, 0);
// Clear the event function and return to the idle state.
PacketType = e_InitbyClientRec;
else //Data Recieved without Query
// Go to idle state.
PacketType = e_InitByServerRec;
// Initialize the linked list pointer to parse.
psBufCur = psBuf;
// Free the buffers used since they have been processed.
while(psBufCur->len != 0)
// Indicate that you have received and processed this set of TCP data.
tcp_recved(psPcb, psBufCur->len);
// Go to the next buffer.
psBufCur = psBufCur->next;
// Terminate if there are no more buffers.
if(psBufCur == 0)
break;
// Free the memory space allocated for this receive.
pbuf_free(psBuf);
// Return.
return(ERR_OK);
// Handles acknowledgment of data transmitted via Ethernet.
// \param ui16Len is the length of the data transmitted.
// This function is called when the lwIP TCP/IP stack has received an
// acknowledgment for data that has been transmitted.
static err_t
TCPSent(void *pvArg, struct tcp_pcb *psPcb, u16_t ui16Len)
// Return OK.
return (ERR_OK);
// connection.
static err_t
TCPConnected(void *pvArg, struct tcp_pcb *psPcb, err_t iErr)
// Check if there was a TCP error.
if(iErr != ERR_OK)
tcp_sent(psPcb, NULL);
tcp_recv(psPcb, NULL);
tcp_err(psPcb, NULL);
tcp_close(psPcb);
g_sEnet.psTCP = 0;
// And return.
return (ERR_OK);
// Setup the TCP receive function.
tcp_recv(psPcb, TCPReceive);
// Setup the TCP error function.
tcp_err(psPcb, TCPError);
// Setup the TCP sent callback function.
tcp_sent(psPcb, TCPSent);
// Connection is complete.
g_sEnet.eState = iEthTCPConnectComplete;
// Return a success code.
return(ERR_OK);
// TCP connect
// This function attempts to connect to a TCP endpoint.
// \return None.
err_t
EthClientTCPConnect(uint32_t ui32Port)
err_t eTCPReturnCode;
// Enable the TCP timer function calls.
HWREGBITW(&g_sEnet.ui32Flags, FLAG_TIMER_TCP_EN) = 1;
if(g_sEnet.psTCP)
// Initially clear out all of the TCP callbacks.
// Make sure there is no lingering TCP connection.
// Create a new TCP socket.
g_sEnet.psTCP = tcp_new();
// Check if you need to go through a proxy.
// if(g_sEnet.pcProxyName != 0)
// Attempt to connect through the proxy server.
// eTCPReturnCode = tcp_connect(g_sEnet.psTCP, &g_sEnet.sServerIP,
// ui32Port, TCPConnected);
// else
// Attempt to connect to the server directly.
return(eTCPReturnCode);
// TCP connect
// \return None.
void
EthClientTCPDisconnect(void)
// HWREGBITW(&g_sEnet.ui32Flags, FLAG_TIMER_TCP_EN) = 0;
if(g_sEnet.psTCP)
g_sEnet.psTCP = 0;
// Handler function when the DNS server gets a response or times out.
// \param pcName is DNS server name.
// \param psIPAddr is the DNS server's IP address.
// \param vpArg is the configurable argument.
// This function is called when the DNS server resolves an IP or times out.
// If the DNS server returns an IP structure that is not NULL, add the IP to
// to the g_sEnet.sServerIP IP structure.
// \return None.
static void
DNSServerFound(const char *pcName, struct ip_addr *psIPAddr, void *vpArg)
// Check if a valid DNS server address was found.
if(psIPAddr != NULL)
// Copy the returned IP address into a global IP address.
g_sEnet.sServerIP = *psIPAddr;
// Tell the main program that a DNS address was found.
HWREGBITW(&g_sEnet.ui32Flags, FLAG_DNS_ADDRFOUND) = 1;
else
// Disable the DNS timer.
HWREGBITW(&g_sEnet.ui32Flags, FLAG_TIMER_DNS_EN) = 0;
// Required by lwIP library to support any host-related timer functions.
void
lwIPHostTimerHandler(void)
// Send a request to the server
// \param pcRequest request to be sent
// \param ui32Size length of the request to be sent. this is usually the size
// of the request minus the termination character
// This function will send the request to the connected server
// \return the lwIP error code.
err_t
EthClientSend(char *pcRequest, uint32_t ui32Size)
err_t eError;
eError = tcp_write(g_sEnet.psTCP, pcRequest, ui32Size,
TCP_WRITE_FLAG_COPY);
// Write data for sending (but does not send it immediately).
if(eError == ERR_OK)
// Find out what we can send and send it
tcp_output(g_sEnet.psTCP);
return(eError);
// DHCP connect
// This function obtains the MAC address from the User registers, starts the
// DHCP timer and blocks until an IP address is obtained.
// \return None.
err_t
EthClientDHCPConnect(void)
// Check if the DHCP has already been started.
if(HWREGBITW(&g_sEnet.ui32Flags, FLAG_DHCP_STARTED) == 0)
// Set the DCHP started flag.
HWREGBITW(&g_sEnet.ui32Flags, FLAG_DHCP_STARTED) = 1;
else
// If DHCP has already been started, we need to clear the IPs and
// switch to static. This forces the LWIP to get new IP address
// and retry the DHCP connection.
// lwIPNetworkConfigChange(0, 0, 0, IPADDR_USE_STATIC);
// Restart the DHCP connection.
lwIPNetworkConfigChange(0, 0, 0, IPADDR_USE_DHCP);
return ERR_OK;
// \return None.
int32_t
EthClientDNSResolve(const char *pcName)
err_t iRet;
if(HWREGBITW(&g_sEnet.ui32Flags, FLAG_TIMER_DNS_EN))
return(ERR_INPROGRESS);
// Set DNS config timer to true.
HWREGBITW(&g_sEnet.ui32Flags, FLAG_TIMER_DNS_EN) = 1;
// Initialize the host name IP address found flag to false.
HWREGBITW(&g_sEnet.ui32Flags, FLAG_DNS_ADDRFOUND) = 0;
// Resolve host name.
iRet = dns_gethostbyname(pcName, &g_sEnet.sServerIP, DNSServerFound, 0);
// If ERR_OK is returned, the local DNS table resolved the host name. If
// ERR_INPROGRESS is returned, the DNS request has been queued and will be
// sent to the DNS server.
if(iRet == ERR_OK)
// Stop calling the DNS timer function.
// Return host name not found.
return(iRet);
// Returns the IP address for this interface.
// This function will read and return the currently assigned IP address for
// the Tiva Ethernet interface.
// \return Returns the assigned IP address for this interface.
uint32_t
EthClientAddrGet(void)
// Return IP.
return(lwIPLocalIPAddrGet());
// Returns the weather server IP address for this interface.
// This function will read and return the weather server IP address that is
// currently in use. This could be the proxy server if the Internet proxy
// is enabled.
// \return Returns the weather server IP address for this interface.
uint32_t
EthClientServerAddrGet(void)
// Return IP.
return((uint32_t)g_sEnet.sServerIP.addr);
// Returns the MAC address for the Tiva Ethernet controller.
// \param pui8MACAddr is the 6 byte MAC address assigned to the Ethernet
// controller.
// This function will read and return the MAC address for the Ethernet
// controller.
void
EthClientMACAddrGet(uint8_t *pui8MACAddr)
int32_t iIdx;
for(iIdx = 0; iIdx < 6; iIdx++)
pui8MACAddr[iIdx] = g_sEnet.pui8MACAddr[iIdx];
// Set the proxy string for the Ethernet connection.
// \param pcProxyName is the string used as the proxy server name.
// This function sets the current proxy used by the Ethernet connection. The
// \e pcProxyName value can be 0 to indicate that no proxy is in use or it can
// be a pointer to a string that holds the name of the proxy server to use.
// The content of the pointer passed to \e pcProxyName should not be changed
// after this call as this function only stores the pointer and does not copy
// the data from this pointer.
// \return None.
void
EthClientProxySet(const char *pcProxyName)
// Save the new proxy string.
g_sEnet.pcProxyName = pcProxyName;
// Reset the connection on any change to the proxy.
EthClientReset();
// Initialize the Ethernet client
// This function initializes all the Ethernet components to not configured.
// This tells the SysTick interrupt which timer modules to call.
// \return None.
void
EthClientInit(tEventFunction pfnEvent)
uint32_t ui32User0, ui32User1;
// Initialize all the Ethernet components to not configured. This tells
// the SysTick interrupt which timer modules to call.
HWREGBITW(&g_sEnet.ui32Flags, FLAG_TIMER_DHCP_EN) = 0;
g_sEnet.pfnEvent = pfnEvent;
// Convert the 24/24 split MAC address from NV ram into a 32/16 split MAC
// address needed to program the hardware registers, then program the MAC
// address into the Ethernet Controller registers.
FlashUserGet(&ui32User0, &ui32User1);
g_sEnet.pui8MACAddr[0] = ((ui32User0 >> 0) & 0xff);
g_sEnet.pui8MACAddr[1] = ((ui32User0 >> 8) & 0xff);
g_sEnet.pui8MACAddr[2] = ((ui32User0 >> 16) & 0xff);
g_sEnet.pui8MACAddr[3] = ((ui32User1 >> 0) & 0xff);
g_sEnet.pui8MACAddr[4] = ((ui32User1 >> 8) & 0xff);
g_sEnet.pui8MACAddr[5] = ((ui32User1 >> 16) & 0xff);
lwIPInit(g_ui32SysClock, g_sEnet.pui8MACAddr, 0, 0, 0, IPADDR_USE_DHCP);
// Start lwIP tick interrupt.
HWREGBITW(&g_sEnet.ui32Flags, FLAG_TIMER_DHCP_EN) = 1;
// Periodic Tick for the Ethernet client
// This function is the needed periodic tick for the Ethernet client. It needs
// to be called periodically through the use of a timer or systick.
// \return None.
void
EthClientTick(uint32_t ui32TickMS)
uint32_t ui32IPAddr;
int32_t i32Ret;
if(HWREGBITW(&g_sEnet.ui32Flags, FLAG_TIMER_DHCP_EN))
lwIPTimer(ui32TickMS);
dns_tmr();
if(HWREGBITW(&g_sEnet.ui32Flags, FLAG_TIMER_TCP_EN))
tcp_tmr();
// Check for loss of link.
if((g_sEnet.eState != iEthNoConnection) &&
(lwIPLocalIPAddrGet() == 0xffffffff))
// Reset the connection due to a loss of link.
EthClientReset();
// Signal a disconnect event.
g_sEnet.pfnEvent(ETH_EVENT_DISCONNECT, 0, 0);
else if(g_sEnet.eState == iEthNoConnection)
// Once link is detected start DHCP.
if(lwIPLocalIPAddrGet() != 0xffffffff)
EthClientDHCPConnect();
g_sEnet.eState = iEthDHCPWait;
else if(g_sEnet.eState == iEthDHCPWait)
// Get IP address.
ui32IPAddr = lwIPLocalIPAddrGet();
// If IP Address has not yet been assigned, update the display
// accordingly.
if((ui32IPAddr != 0xffffffff) && (ui32IPAddr != 0))
// Update the DHCP IP address.
g_sEnet.sLocalIP.addr = ui32IPAddr;
g_sEnet.eState = iEthDHCPComplete;
// Stop DHCP timer since an address has been provided.
HWREGBITW(&g_sEnet.ui32Flags, FLAG_DHCP_STARTED) = 0;
else if(g_sEnet.eState == iEthDHCPComplete)
if(g_sEnet.pcProxyName == 0)
// Resolve the host by name.
// i32Ret = EthClientDNSResolve("api.openweathermap.org");
// i32Ret = EthClientDNSResolve("65.0.24.136");
i32Ret = EthClientDNSResolve("13.127.80.198");
//i32Ret = EthClientDNSResolve("cms.efillelectric.com");
//i32Ret = EthClientDNSResolve("192.168.137.1");
//i32Ret = EthClientDNSResolve("econnect.electreefi.com");
else
// Resolve the proxy by name.
i32Ret = EthClientDNSResolve(g_sEnet.pcProxyName);
if(i32Ret == ERR_OK)
// If the address was already returned then go to idle.
// Notify the main routine of the new Ethernet connection.
g_sEnet.pfnEvent(ETH_EVENT_CONNECT, &g_sEnet.sLocalIP.addr, 4);
else if(i32Ret == ERR_INPROGRESS)
// If the request is pending the go to the iEthDNSWait state.
g_sEnet.eState = iEthDNSWait;
else if(g_sEnet.eState == iEthDNSWait)
// Check if the host name was resolved.
if(HWREGBITW(&g_sEnet.ui32Flags, FLAG_DNS_ADDRFOUND))
else if(g_sEnet.eState == iEthTCPConnectWait)
else if(g_sEnet.eState == iEthTCPConnectComplete)
err_t eError;
g_sEnet.eState = iEthTCPOpen;
eError = EthClientSend(g_sWeather.pcRequest,
g_sWeather.ui32RequestSize);
// Waiting on a query response.
g_sEnet.eState = iEthQueryWait;
else
// Set the current weather source.
void
WeatherSourceSet(tWeatherSource eWeatherSource)
// Save the source.
g_sWeather.eWeatherSource = eWeatherSource;
g_sWeather.eFormat = iFormatJSON;
// Merges strings into the current request at a given pointer and offset.
uint32_t MergeRequest1(int32_t i32Offset, char *pcSrc, int32_t i32Size)
int32_t i32Idx;
// Copy the base request to the buffer.
for(i32Idx = 0; i32Idx < i32Size; i32Idx++)
g_sWeather.pcRequest[i32Offset] = pcSrc[i32Idx];
if(WebSocketflags.HandshakeInprogress==1)
if((i32Offset >= sizeof(g_sWeather.pcRequest)) ||
(pcSrc[i32Idx] == 0))
break;
else
if(i32Offset >= sizeof(g_sWeather.pcRequest))
break;
i32Offset++;
return(i32Offset);
// Gets the daily forecast for a given city.
int32_t
WeatherForecast(tWeatherSource eWeatherSource, const char *pcQuery,
tWeatherReport *psWeatherReport, tEventFunction pfnEvent)
int32_t i32Idx;
// const char pcCount[] = "&cnt=1";
// If the requested source is not valid or there is no call back then
// just fail.
// if((eWeatherSource != iWSrcOpenWeatherMap) || (g_sWeather.pfnEvent))
// return (-1);
if(eWeatherSource != iWSrcOpenWeatherMap)
return (-1);
g_sWeather.pfnEvent = pfnEvent;
g_sWeather.psWeatherReport = psWeatherReport;
// if(g_sEnet.eState == iEthNoConnection) return(0);
// Connect or reconnect to port 80.
// g_sEnet.eState = iEthTCPConnectWait;
// Copy the base forecast request to the buffer.
// i32Idx = MergeRequest1(0, g_cWeatherRequestForecast,
// sizeof(g_cWeatherRequestForecast));
// Append the request.
//i32Idx = MergeRequest1(i32Idx, pcQuery, sizeof(g_sWeather.pcRequest));
// Append the request mode.
// i32Idx = MergeRequest1(i32Idx, g_cMode, sizeof(g_cMode));
// Append the count.
//i32Idx = MergeRequest1(i32Idx, pcCount, sizeof(pcCount));
// Append the App ID.
// i32Idx = MergeRequest1(i32Idx, g_cAPPIDOpenWeather,
// sizeof(g_cAPPIDOpenWeather));
// Append the "HTTP:/1.1" string.
// i32Idx = MergeRequest1(i32Idx, g_cHTTP11, sizeof(g_cHTTP11));
// UARTprintf("\n\t%s",g_sWeather.pcRequest);
// Forcast weather report request.
// g_sEnet.ulRequest = WEATHER_FORECAST;
ProcessTransmit.Tx_ActionIndex = Id_Heartbeat;
ProcessTransmit.Tx_MessageId[e_IdCallResult] = 2;
i32Idx = MergeRequest1(0,Webpack,sizeof(Webpack));
if(ProcessTransmit.TransmitFlag[e_IdCall]==1)
ProcessTransmit.TransmitLength = ReqFunctions[ProcessTransmit.TransmitIndex[e_IdCall]]();
else
ProcessTransmit.TransmitLength = ReqFunctions[ProcessTransmit.TransmitIndex[e_IdCallResult]]();
WebSocketflags.DataLen = Websocket_TxHandle(Response,ProcessTransmit.TransmitLength,1,1);
i32Idx = MergeRequest1(0, WebSocketflags.DataBuff, WebSocketflags.DataLen);
i32Idx = MergeRequest1(0, cmd_1, sizeof(cmd_1));
i32Idx = MergeRequest1(i32Idx, cmd_2, sizeof(cmd_2));
i32Idx = MergeRequest1(i32Idx, cmd_3, sizeof(cmd_3));
i32Idx = MergeRequest1(i32Idx, cmd_4, sizeof(cmd_4));
i32Idx = MergeRequest1(i32Idx, cmd_5, sizeof(cmd_5));
i32Idx = MergeRequest1(i32Idx, cmd_6, sizeof(cmd_6));
i32Idx = MergeRequest1(i32Idx, cmd_7, sizeof(cmd_7));
i32Idx = MergeRequest1(i32Idx,Webpack,sizeof(Webpack));
i32Idx = MergeRequest1(i32Idx, Response, ProcessTransmit.TransmitLength);
// if(EthClientTCPConnect(3002) != ERR_OK)
if(EthClientTCPConnect(6002) != ERR_OK)
//if(EthClientTCPConnect(80) != ERR_OK)
return(-1);
else
// tcp_connect(g_sEnet.psTCP, &g_sEnet.sServerIP,3002, TCPConnected);
tcp_recv(g_sEnet.psTCP, TCPReceive);
tcp_err(g_sEnet.psTCP, TCPError);
tcp_sent(g_sEnet.psTCP, TCPSent);
// Save the size of the request.
g_sWeather.ui32RequestSize = i32Idx;
return(0);
// Gets the current weather information for a given city.
int32_t
WeatherCurrent(tWeatherSource eWeatherSource, const char *pcQuery,
int32_t i32Idx;
// if(eWeatherSource != iWSrcOpenWeatherMap)
// if(g_sWeather.pfnEvent)
// return (-1);
return(0);
void restore(void)
//Function Returns Length of Data After Adding Websocket
uint32_t Websocket_TxHandle(char *payload , uint32_t dtln,uint8_t Fin, uint8_t Masking)
uint32_t Dl=0;
if(WebSocketflags.HanshakeStatus==0)return 0;
WebSocket.BIT_FIELD.FIN =Fin;
WebSocket.BIT_FIELD.RSV1=0;
WebSocket.BIT_FIELD.RSV2=0;
WebSocket.BIT_FIELD.RSV3=0;
WebSocket.BIT_FIELD.OPCODE=1;
WebSocketflags.DataBuff[0]=WebSocket.BYTE_ARRAY[0];
Dl++;
WebSocket.BIT_FIELD.MASK=Masking;
//if(masking =1, Do masking of payload otherwise Do not mask payload)
//Generate a 32 bit Masking Key if Mask flag=1;
WebSocket.BIT_FIELD.MASKING_KEY1=0x2A;//ReturnRandomHex();// 0x2A;
WebSocket.BIT_FIELD.MASKING_KEY2=0x3C;//ReturnRandomHex();//0x3C;
WebSocket.BIT_FIELD.MASKING_KEY3=0x4D;//ReturnRandomHex();//0x4D;
WebSocket.BIT_FIELD.MASKING_KEY4=0x5B;//ReturnRandomHex();//0x5B;
//For now masking is fixed @enable i.e. 1
if(dtln>=126) //and smaller than 65535
//insert extended payload length here
WebSocket.BIT_FIELD.PAYLOAD_LEN = 126;
WebSocketflags.DataBuff[1] = WebSocket.BYTE_ARRAY[1];
Dl++;
WebSocket.BIT_FIELD.EXTENDED_PAYLOAD_LEN = dtln;
WebSocketflags.DataBuff[2] = WebSocket.BYTE_ARRAY[3];
Dl++;
WebSocketflags.DataBuff[3] = WebSocket.BYTE_ARRAY[2];
Dl++;
WebSocketflags.DataBuff[4] = WebSocket.BIT_FIELD.MASKING_KEY1;
Dl++;
WebSocketflags.DataBuff[5] = WebSocket.BIT_FIELD.MASKING_KEY2;
Dl++;
WebSocketflags.DataBuff[6] = WebSocket.BIT_FIELD.MASKING_KEY3;
Dl++;
WebSocketflags.DataBuff[7] = WebSocket.BIT_FIELD.MASKING_KEY4;
Dl++;
MaskData(dtln,payload);
Dl = (Dl+dtln);
else
WebSocket.BIT_FIELD.PAYLOAD_LEN = dtln;
Dl++;
WebSocketflags.DataBuff[2] = WebSocket.BIT_FIELD.MASKING_KEY1;
Dl++;
WebSocketflags.DataBuff[3] = WebSocket.BIT_FIELD.MASKING_KEY2;
Dl++;
WebSocketflags.DataBuff[4] = WebSocket.BIT_FIELD.MASKING_KEY3;
Dl++;
WebSocketflags.DataBuff[5] = WebSocket.BIT_FIELD.MASKING_KEY4;
Dl++;
Dl = (Dl+dtln);
return Dl;
void MaskData(uint32_t DataSize,char *payload) //if Data Size is smaller than equal to 125 bytes
uint32_t Lp=0;
uint8_t KeyId=0;
if(TestMode==false)UARTprintf("\r\nTX:- ");
if(DataSize>=126)
for(Lp=0;Lp<DataSize;Lp++)
if(TestMode==false)UARTCharPut(UART0_BASE,payload[Lp]);
WebSocketflags.DataBuff[Lp+8] = payload[Lp]^WebSocketflags.DataBuff[KeyId+4];
KeyId++;
if(KeyId>3)KeyId=0;
else
WebSocketflags.DataBuff[Lp+6] = payload[Lp]^WebSocketflags.DataBuff[KeyId+2];
KeyId++;
if(KeyId>3)KeyId=0;
uint8_t ReturnRandomHex(void)
uint8_t RdmNum=0;
RdmNum = urand()%256-13;
return RdmNum;
// enet_weather.c - Sample Weather application using lwIP.
#include <stdint.h>
#include <string.h>
#include "inc/hw_ints.h"
#include "inc/hw_nvic.h"
#include "inc/hw_gpio.h"
#include "driverlib/pin_map.h"
#include "driverlib/rom.h"
#include "driverlib/rom_map.h"
#include "driverlib/emac.h"
#include "driverlib/timer.h"
#include "drivers/pinout.h"
#include "utils/cmdline.h"
#include "utils/locator.h"
#include "utils/flash_pb.h"
#include "enet_weather.h"
#include "fatfs/src/ff.h"
#include "fatfs/src/diskio.h"
#include "json.h"
#include "Timer_Control/TimerHandler.h"
#include "Conversions/unit_conversion.h"
#include "GPIO_Control/GPIO_Controls.h"
#include "Sensing_ADC/ADC_Sensing.h"
#include "sd_card/sd_card.h"
#include "EEPROM_Control/Int_EEPR.h"
#include "EEPROM_Control/i2c_config.h"
#include "EEPROM_Control/24AAN256.h"
#include "DisplayData/DisplayCommands.h"
#include "inc/hw_hibernate.h"
#include "driverlib/hibernate.h"
#include "UART_Control/Modem.h"
void Transmit_DataForCallResult(void);
void Transmit_DataForCall(void);
void HandleConnectionsServerStates(void);
void SendHandshake(void);
//extern VP_Table Variabledatatable[];
extern Relay_States RelayStates;
uint32_t OCPPVersion=0;
extern Level_Passwords LevelPasswords;
uint32_t OV_OC_DelayTime=0;
extern EV_Param EVParam;
char buffr[50];
uint8_t PowerUpflag=1;
uint8_t EthResetRequired=0;
uint32_t WaitEthReconnect=WAIT_ETH_RECONNECT;
extern Fuction_Handle FuctionHandle[TOTAL_ACTION_ARRAY_COUNT];
//extern uint16_t *tableArray1[];
extern Param_Update_Flags ParamUpdateFlags;
extern UpdateSDCard_TL UpdateSDCardTL;
extern uint8_t Fault_Table1K_Flag;
extern uint8_t TL_Table1K_Flag;
extern uint8_t CacheMem1K_Flag;
extern Disp_ControlFunc DispControlFuncLatest;
//extern Relay_States RelayStates;
//extern struct g_sEnet;
//! \addtogroup example_list
//! <h1>Ethernet Weather Application (enet_weather)</h1>
//! This example application demonstrates the operation of the Tiva C series
//! evaluation kit as a weather reporting application.
//! The application supports updating weather information from Open Weather Map
//! weather provider(http://openweathermap.org/). The application uses the
//! lwIP stack to obtain an address through DNS, resolve the address of the
//! Open Weather Map site and then build and handle all of the requests
//! necessary to access the weather information. The application can also use
//! a web proxy, allows for a custom city to be added to the list of cities and
//! toggles temperature units from Celsius to Fahrenheit. The application
//! scrolls through the city list at a fixed interval when there is a valid
//! IP address and displays this information over the UART.
//! The application will print the city name, status, humidity, current temp
//! and the high/low. In addition the application will display what city it
//! is currently updating. Once the app has scrolled through the cities a
//! a defined amount of times, it will attempt to update the information.
//! UART0, connected to the Virtual Serial Port and running at 115,200, 8-N-1,
//! is used to display messages from this application.
//!/ For additional details about Open Weather Map refer to their web page at:
//! http://openweathermap.org/
//! For additional details on lwIP, refer to the lwIP web page at:
//! http://savannah.nongnu.org/projects/lwip/
// Connection states for weather application.
volatile enum
STATE_NOT_CONNECTED, //ETHERNET NOT CONNECTED
STATE_NEW_CONNECTION, //SERVER CONNECTION STARTED
STATE_CONNECTED_IDLE, //CONNECTED AND CLIENT IN IDLE STATE
STATE_WAIT_DATA, //WAITING DATA TO RECEIVE
STATE_PROCESS_RX_DATA, //PROCESSING RECIEVED DATA
STATE_SERVER_BUSY,//This Happens if Server do not Respond Any Data for A Query
STATE_DATA_PROCESSED,
g_iState = STATE_NOT_CONNECTED;
uint8_t TCP_ConnectionStatus= e_TCP_Disconnected;
// Global for IP address.
// The delay count to reduce traffic to the weather server.
volatile uint32_t g_ui32Delay;
err_t Err;
// System Clock rate in Hertz.
// Flag indicate Ehernet Transmission//1-->Transmit,0-->Idle
//uint8_t EthFlagTransmit=0;
extern Timer_Flags TimerFlags;
extern uint32_t Time_Sec;
// The defaults for the flash and application settings.
static const sParameters g_sDefaultParams =
0,
{"Custom City Name"},
{"your.proxy.com"},
false,
false,
false,
false
// The current live configuration settings for the application.
sParameters g_sConfig;
// The state of each city panel.
struct
// The last update time for this city.
uint32_t ui32LastUpdate;
// The current weather report data for this city.
tWeatherReport sReport;
// Indicates if the city needs updating.
bool bNeedsUpdate;
// The name of the current city.
const char *pcName;
g_psCityInfo[1];
// Interrupt priority definitions. The top 3 bits of these values are
// significant with lower values indicating higher priority interrupts.
#define SYSTICK_INT_PRIORITY 0x80
#define ETHERNET_INT_PRIORITY 0xC0
// The error routine that is called if the driver library encounters an error.
#ifdef DEBUG
void
__error__(char *pcFilename, uint32_t ui32Line)
#endif
// MAC address.
char g_pcMACAddr[40];
// IP address.
char g_pcIPAddr[20];
// Update the IP address string.
void
UpdateIPAddress(char *pcAddr, uint32_t ipAddr)
uint8_t *pui8Temp = (uint8_t *)&ipAddr;
if(ipAddr == 0)
ustrncpy(pcAddr, "IP: ---.---.---.---", sizeof(g_pcIPAddr));
else
usprintf(pcAddr,"IP: %d.%d.%d.%d", pui8Temp[0], pui8Temp[1],
pui8Temp[2], pui8Temp[3]);
void ProcessMcuLed(void);
// Update the MAC address string.
void
UpdateMACAddr(void)
uint8_t pui8MACAddr[6];
EthClientMACAddrGet(pui8MACAddr);
usprintf(g_pcMACAddr, "MAC: %02x:%02x:%02x:%02x:%02x:%02x",
pui8MACAddr[0], pui8MACAddr[1], pui8MACAddr[2], pui8MACAddr[3],
pui8MACAddr[4], pui8MACAddr[5]);
// Print the IP address string.
void
PrintIPAddress(char *pcAddr, uint32_t ipaddr)
uint8_t *pui8Temp = (uint8_t *)&ipaddr;
// Convert the IP Address into a string.
UARTprintf("%d.%d.%d.%d\n", pui8Temp[0], pui8Temp[1], pui8Temp[2],
pui8Temp[3]);
// Updates the UART information.
void
UpdateUART(void)
volatile uint32_t ui32IPaddr;
// Get the IP address.
ui32IPaddr = EthClientAddrGet();
// If the IP changed, reassign.
if (g_ui32IPaddr != ui32IPaddr)
// Reassign the global IP to the current.
g_ui32IPaddr = ui32IPaddr;
// Update the UART.
// g_UpdateUART = 1;
// Check if we should scroll the cities.
// Clear the terminal. Print the banner and IP place holder.
UARTprintf("SYSTEM IP: ");
// Print the IP address.
PrintIPAddress(g_pcIPAddr, ui32IPaddr);
UARTprintf("\n");
void
WeatherEvent(uint32_t ui32Event, void* pvData, uint32_t ui32Param)
if(ui32Event == ETH_EVENT_RECEIVE)
// Let the main loop update the city.
g_iState = STATE_DATA_PROCESSED;
g_iState= STATE_CONNECTED_IDLE;
// g_psCityInfo[g_ui32CityUpdating].ui32LastUpdate =
// g_psCityInfo[g_ui32CityUpdating].sReport.ui32Time;
else if(ui32Event == ETH_EVENT_INVALID_REQ)
//if Data packet Recieved not Valid
// g_psCityInfo[g_ui32CityUpdating].sReport.pcDescription = g_pcNotFound;
//g_iState = STATE_UPDATE_CITY;
else if(ui32Event == ETH_EVENT_CLOSE)
if(g_iState == STATE_WAIT_DATA)
// g_pcServerBusy;
//SERVER NOT ABLE TO RESPOND//
g_iState = STATE_SERVER_BUSY;
// If the update indicated no time, then just set the time to a value
// to indicate that at least the update occurred.
if(g_psCityInfo[0].ui32LastUpdate == 0)
// Failed to update for some reason.
g_psCityInfo[0].ui32LastUpdate = 1;
// The interrupt handler for the SysTick interrupt.
void
SysTickIntHandler(void)
// Call the lwIP timer handler.
EthClientTick(SYSTEM_TICK_MS);
disk_timerproc();
// Handle the delay between accesses to the weather server.
if(g_ui32Delay != 0)
g_ui32Delay--;
// Network events handler.
void
EnetEvents(uint32_t ui32Event, void *pvData, uint32_t ui32Param)
if(ui32Event == ETH_EVENT_CONNECT)
// if(!(TCP_ConnectionStatus==e_TCP_NotResponding))
g_iState = STATE_NEW_CONNECTION;
// Update the string version of the address.
UpdateIPAddress(g_pcIPAddr, EthClientAddrGet());
else if(ui32Event == ETH_EVENT_DISCONNECT)
// Update the address to 0.0.0.0.
UpdateIPAddress(g_pcIPAddr, 0);
int
main(void)
ROM_FPULazyStackingEnable();
ROM_FPUEnable();
sParameters *pParams;
// Make sure the main oscillator is enabled because this is required by
// the PHY. The system must have a 25MHz crystal attached to the OSC
// pins. The SYSCTL_MOSC_HIGHFREQ parameter is used when the crystal
// frequency is 10MHz or higher.
SysCtlMOSCConfigSet(SYSCTL_MOSC_HIGHFREQ);
#if INTERNAL_CLOCK
//Run On internal Clock
g_ui32SysClock = MAP_SysCtlClockFreqSet(SYSCTL_OSC_INT | SYSCTL_USE_PLL | SYSCTL_CFG_VCO_480, 120000000);
#elif EXTERNAL_CLOCK
// Run from the PLL at 120 MHz.
g_ui32SysClock = MAP_SysCtlClockFreqSet((SYSCTL_XTAL_25MHZ |
SYSCTL_OSC_MAIN |
SYSCTL_USE_PLL |
SYSCTL_CFG_VCO_480), 120000000);
#endif
// Configure the device pins.
PinoutSet(true, false);
GPIO_Configure();
/********************************EEPROM INITIALIZATION********************************/
initialize_Internal_EEPR();
LoadEEPROMAllParameters();
// Initialize the UART 0.
UARTStdioConfig(0, 115200, g_ui32SysClock);
/********************************UART CONFIGURATIONS**********************************/
// Initialize_Uart(0);
Initialize_Uart(1);
Initialize_Uart(2);
Initialize_Uart(3);
// Configure SysTick for a periodic interrupt at 10ms.
SysTickPeriodSet((g_ui32SysClock / 1000) * SYSTEM_TICK_MS);
SysTickEnable();
SysTickIntEnable();
// Initialized the flash program block and read the current settings.
FlashPBInit(FLASH_PB_START, FLASH_PB_END, 256);
pParams = (sParameters *)FlashPBGet();
// Use the defaults if no settings were found.
if(pParams == 0)
g_sConfig = g_sDefaultParams;
else
g_sConfig = *pParams;
// Set the IP address to 0.0.0.0.
// Enable processor interrupts.
IntMasterEnable();
// Set the interrupt priorities. We set the SysTick interrupt to a higher
// priority than the Ethernet interrupt to ensure that the file system
// tick is processed if SysTick occurs while the Ethernet handler is being
// processed. This is very likely since all the TCP/IP and HTTP work is
// done in the context of the Ethernet interrupt.
IntPriorityGroupingSet(4);
IntPrioritySet(INT_EMAC0, ETHERNET_INT_PRIORITY);
IntPrioritySet(FAULT_SYSTICK, SYSTICK_INT_PRIORITY);
g_sConfig.bProxyEnabled=0;
if(g_sConfig.bProxyEnabled)
EthClientProxySet(g_sConfig.pcProxy);
EthClientInit(EnetEvents);
else
EthClientProxySet(0);
UpdateMACAddr();
g_ui32IPaddr = EthClientAddrGet();
// Update the current city information.
UpdateUART();
// Loop forever. All the work is done in interrupt handlers.
/*************************************ENABLING RTC MODULE******************************************************/
ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_HIBERNATE);
// Wait for the Hibernate module to be ready.
while(!ROM_SysCtlPeripheralReady(SYSCTL_PERIPH_HIBERNATE)){}
ROM_HibernateEnableExpClk(g_ui32SysClock);
ROM_SysCtlDelay(3000);
ROM_HibernateClockConfig(HIBERNATE_OSC_LOWDRIVE);
ROM_SysCtlDelay(1000);
ROM_HibernateRTCTrimSet(0x7FFF);
ROM_HibernateRTCEnable(); // start RTC count
/********************************TIMER CONFIGURATIONS**********************************/
Initialize_TIMER(TIMER1);
Initialize_TIMER(TIMER0);
/*******************************Initialize EEPROM I2C********************************/
InitI2C1();
/********************************ADC CONFIGURATIONS**********************************/
ADC_Configure();
/********************************SD Card CONFIGURATIONS**********************************/
ConfigureSD_Card();
UpadateParam();
/*******************************UPDATE DISPLAY PARAMETERS****************************/
InitDisplayVariables();
//WriteEEPbysize(&Def_QR_CodeA[0] , 0X28 ,20);
//WriteEEPbysize(&Def_QR_CodeB[0] , 0x3C ,20);
// WriteEEPbysize(&Def_QR_CodeC[0] , 0X50 ,20);
// UpdateFaultLogCount(1);
// SetChargingCostParams(0,0,0,0,1);
// SetChargingCostParams(0,0,0,0,2);
// SetChargingCostParams(0,0,0,0,3);
InitCostVariablesfromEEPOnLoad();
LoadEEPParameters();
LoadVPParamValueFromEEProm();
LoadMeterValueOnInitialization();
FormatHandshakeStr();
//UpdateFaultTabletoSDCard();
//UpdateTLTabletoSDCard();
// Update1KfullCountFlag(0,enFaultLog);
// Update1KfullCountFlag(0,enTradeLog);
//Update1KfullCountFlag(0,enCacheData);
//Fault_Table1K_Flag = Read1Kflag(enFaultLog);
//TL_Table1K_Flag = Read1Kflag(enTradeLog);
//CacheMem1K_Flag = Read1Kflag(enCacheData);
//UpdateFaultLogCount(1);
//UpdateTLLogCount(0);
// FaultTableTotalPages = TotalPageCount(TotalSavedLogCount_Fault);
// TL_TotalPages = TotalPageCount(TotalSavedLogCount_TL);
//FaultTableCurrentPageNo = GetCurrentPage(6);
//TL_CurrentPageNo = GetCurrentPage(12);
//ParseSDCardDataFaultTable(1);
//ParseSDCardDataTLTable(1);
// InitializeDisplayParameters();
//memset(&ChargingRateA,0,4);
//ReadEEpbysize(Variabledatatable[TBID_PRODUCTID].Default_value ,Variabledatatable[TBID_PRODUCTID].EepAdress,Variabledatatable[TBID_PRODUCTID].DataLength );
// uint32_t defval[1];
// defval[0] = 0;
// Set_Int_EEP_32bit(defval , OCPP_VERSION );
//Set_Int_EEP_32bit(defval , 820 );
// Set_Int_EEP_32bit(defval , 824 );
//OverVoltage = Get_Int_EEP_32bit(Variabledatatable[TBID_OVERVOLTAGE].EepAdress);
//LocalIpAddr = Get_Int_EEP_32bit(Variabledatatable[TBID_LOCALIPADDR].EepAdress);
// xx = ReqFunctions[Id_Authorize]();
// UARTprintf("%s \n", Response);
// xx = ReqFunctions[Id_BootNotification]();
xx = Req_Authorize();
//Pointer to string Array Get Field Value example
int i=0;
char **ptr = NULL;
ptr =ActionString;
strcpy(buffr, ptr[0]);
strcpy(buffr, ptr[1]);
for(i=0;i<2;i++)
UARTprintf(" %s \n", ptr[i]);
//Pointer to string Array Get Field Name example
int i=0;
char **ptr = NULL;
ptr =TypeField_Name_strings[0];
for(i=0;i<2;i++)
strcpy(model_str , "EVAC001.01");
strcpy(VendorName_str , "E-fill Pvt. Ltd.");
int i=0;
char **ptr = NULL;
ptr =TypeFieldstrings[0];
for(i=0;i<2;i++)
//Pointer to string Array Get Enum strings Example
int i=0;
char **ptr = NULL;
char **ptr1 = NULL;
ptr =EnumStrings[0]; //Here Enter index of Enum
ptr1 =EnumStrings[1]; //Here Enter index of Enum
strcpy(buffr, ptr[0]); //Get this by enum Value for perticular parameter
strcpy(buffr, ptr[1]); //Get this by enum Value for perticular parameter
strcpy(buffr, ptr[2]);
strcpy(buffr, ptr[3]);
strcpy(buffr, ptr[4]);
strcpy(buffr, ptr1[0]);
strcpy(buffr, ptr1[1]);
strcpy(buffr, ptr1[2]);
strcpy(buffr, ptr1[3]);
strcpy(buffr, ptr1[4]);
strcpy(buffr, ptr1[5]);
strcpy(buffr, ptr1[6]);
strcpy(buffr, ptr1[7]);
strcpy(buffr, ptr1[8]);
strcpy(buffr, ptr1[9]);
//sprintf("%s",ptr[0]);
for(i=0;i<4;i++)
for(i=0;i<4;i++)
UARTprintf(" %s \n", ptr1[i]);
// UARTprintf("This is new! \n", Response);
// RelayStates.Bit.Relay_1=STATEON;
// RelayStates.Bit.Relay_2=STATEON;
// RelayStates.Bit.Relay_3=STATEON;
UpdateSDCardTL.TL_SavePending[1]=0;
UpdateSDCardTL.TL_SavePending[2]=0;
UpdateSDCardTL.TL_SavePending[3]=0;
ParamUpdateFlags.Bit.ParamStartStopFlag=0;
ParamUpdateFlags.Bit.TimerFlagInitDelay=0;
DispControlFuncLatest.Bit.Flag_fault_Upbtn=1;
DispControlFuncLatest.Bit.Flag_TL_Downbtn=1;
TimerFlags.Bit.Flag_InitFault=0;
EVParam.InitBootNotificationDoneflag=0;
FuctionHandle[Id_BootNotification].BIT_FIELD.ProcessingEn=1;
//FuctionHandle[Id_StartTransactionOCP16].BIT_FIELD.ProcessingEn=1;
InitModemParams();
OV_OC_DelayTime = OVOC_DETECT_DELAY;
RelayStates.Bit.BatteryPowerRelay = STATEON;
while(1)
if(g_iState == STATE_NEW_CONNECTION) g_iState = STATE_CONNECTED_IDLE;
if((PowerUpflag==1)&&(g_iState==STATE_CONNECTED_IDLE))
PowerUpflag = 0;
if((PowerUpflag==0)&&(g_iState == STATE_NOT_CONNECTED)&&(EthResetRequired==0))
EthResetRequired = 1;
if((g_iState == STATE_CONNECTED_IDLE)&&(EthResetRequired==1))
WaitEthReconnect = WAIT_ETH_RECONNECT;
//reset here
Sec_1Loop();
// HandleConnectionsServerStates();
CalculateEnergy_MeterValues();
ProcessMcuLed();
InputPfcStatus();
RelayControl();
//Response once Data Received from Server(Take a flag which tell to responce)
if(g_ui32Delay<=0)
UpdateUART();
g_ui32Delay = SYSTEM_TICK_MS * 50;
SendHandshake();
Transmit_DataForCallResult();
TransmitModemDataToServer();
// Transmit_DataForCall();
// SD_Card_CommandHandler_Processor(); //UART Commands for SD Card
//OCPP1.6 related Commands//
GetStartTransactionResponseparam(); //OCPP1.6
GetAuthResponseParam();
GetBootNotificationResponseparam();
GetUndefinedResponseparam();
GetHeartbeatResponseParam();
GetTransactionEventResponseparam();
GetStopTransactionResponseparam();
GetCancelReservationReqparam();
GetCertificateSignedReqparam();
GetChangeAvailabilityReqparam();
GetClearCacheReqparam();
GetClearChargingProfileReqparam();
GetClearDisplayMessageReqparam();
GetClearVariableMonitoringReqparam();
GetCostUpdatedReqparam();
GetCustomerInformationReqparam();
GetDataTransferReqparam();
GetDeleteCertificateReqparam();
GetBaseReportReqparam();
GetChargingProfilesReqparam();
GetCompositeScheduleReqparam();
GetDisplayMessagesReqparam();
GetInstalledCertificateIdsReqparam();
GetLocalListVersionReqparam();
GetLogReqparam();
GetMonitoringReportReqparam();
GetReportReqparam();
GetTransactionStatusReqparam();
InstallCertificateReqparam();
PublishFirmwareReqparam();
RequestStartTransactionReqparam();
RemoteStartTransactionReqparam();
RequestStopTransactionReqparam();
RemoteStopTransactionReqparam();
ReserveNowReqparam();
ResetReqparam();
SendLocalListReqparam();
SetChargingProfileReqparam();
SetDisplayMessageReqparam();
SetMonitoringBaseReqparam();
SetMonitoringLevelReqparam();
SetNetworkProfileReqparam();
SetVariablesReqparam();
TriggerMessageReqparam();
UnlockConnectorReqparam();
UnpublishFirmwareReqparam();
UpdateFirmwareReqparam();
GetConfigurationReqparam();
FnTx_Authorize();
FnTx_BootNotification();
FnTx_FirmwareStatusNotification();
FnTx_Heartbeat();
FnTx_LogStatusNotification();
FnTx_MeterValues();
FnTx_NotifyChargingLimit();
FnTx_ReservationStatusUpdate();
FnTx_SecurityEventNotification();
FnTx_StatusNotification();
FnTx_TransactionEvent();
FnTx_StartTransaction();
FnTx_StopTransaction();
FnTxC_CancelReservation();
FnTxC_CertificateSigned();
FnTxC_ChangeAvailability();
FnTxC_ClearCache();
FnTxC_ClearChargingProfile();
FnTxC_ClearDisplayMessage();
FnTxC_ClearVariableMonitoring();
FnTxC_CostUpdated();
FnTxC_CustomerInformation();
FnTxC_DataTransfer();
FnTxC_DeleteCertificate();
FnTxC_GetBaseReport();
FnTxC_GetChargingProfiles();
FnTxC_GetCompositeSchedule();
FnTxC_GetDisplayMessages();
FnTxC_GetInstalledCertificateIds();
FnTxC_GetLocalListVersion();
FnTxC_GetLog();
FnTxC_GetMonitoringReport();
FnTxC_GetReport();
FnTxC_GetTransactionStatus();
FnTxC_InstallCertificate();
FnTxC_PublishFirmware();
FnTxC_RequestStartTransaction();
FnTxC_RequestStopTransaction();
FnTxC_RemoteStopTransaction();
FnTxC_ReserveNow();
FnTxC_Reset();
FnTxC_SendLocalList();
FnTxC_SetChargingProfile();
FnTxC_SetDisplayMessage();
FnTxC_SetMonitoringBase();
FnTxC_SetMonitoringLevel();
FnTxC_SetNetworkProfile();
FnTxC_SetVariables();
FnTxC_TriggerMessage();
FnTxC_UnlockConnector();
FnTxC_UnpublishFirmware();
FnTxC_UpdateFirmware();
FnTxC_RemoteStartTransaction();
FnTxC_GetConfiguration();
TransmitPeriodicHeartbeat();
TransmitPeriodicBootNotification();
//Display Hnadling Functions//
UpdateVPDataBufftoEEPandAssignvaluetoVP();
UpdateStartStopChargingIcon();
UpdateCurrent_Voltage_Power();
UpdateTime();
UpdateNetworkStatus();
//UpdateandCheckOTP();
//UpdateandCheckSettingUserIDPassword();
UpdateCheckIpMode();
updateFaultTable();
UploadFaultTableData();
updateTradeLogsTable();
UploadTLTableData();
StartChargingDisplayUpdate();
StopChargingDisplayUpdate();
StopChargingA();
StopChargingB();
StopChargingC();
StartChargingGunA();
StartChargingGunB();
StartChargingGunC();
UpdateRTCTimetoDisplay();
UpdateRTCTimefromDisplay();
CalculateSessionDurationAllGun();
UpdatePicNumber();
UpdateCostParamtodisplayA();
UpdateCostParamtodisplayB();
UpdateCostParamtodisplayC();
UpdateRealtimeCostGunA();
UpdateRealtimeCostGunB();
UpdateRealtimeCostGunC();
ChargingAnimationPicshow();
GetPFCFaults(); //Uncomment Later
FaultDisplay();
WriteFaultDataToDisplay();
OV_OC_faults(); //Uncomment Later
UpdateFaultToServer();
TxMeterValueA();
TxMeterValueB();
TxMeterValueC();
RealTimeUpdateSDCardFaults();
RealTimeUpdateSDCardTL();
//GSM Modem
ProcessModemATRxbuff();
ProcessModemUartRxPack();
ProcessModemUartRxPack2();
StateMachineModemATCommunication();
ModemResesetOnRetries();
StartModemCommAfterReset();
HanshakeProcess();
TurnModuleOnOff();
ModuleReset();
GetSignalStrengthTx();
ProcessStatusNotificationPeriodic();
if(TimerFlags.Bit.FunctionCodeProcessTimeflag==1)
TimerFlags.Bit.FunctionCodeProcessTimeflag=0;
Fc_B_C02_Authorization_StartButton_Con1();
Fc_B_C02_Authorization_StartButton_Con2();
Fc_B_C02_Authorization_StartButton_Con3();
Fc_B_C05_Authorization_CSMS_ConAll();
Fc_B_F03_RemoteStopTransaction_CSMS_ConAll();
StopFaultTxInit();
Fc_B_E06_FaultStop_CSMS_ConAll();
HandleMultiStart();
HandleMultiStop();
CheckModemServerComm();
if(g_iState == STATE_NOT_CONNECTED)
TCP_ConnectionStatus = e_TCP_Disconnected;
else
TCP_ConnectionStatus = e_TCP_Connected;
//Author: Pradeep Kumar
//Date: 06/01/2021 Time: 19:37
//Function void Transmit_Data(void)
//Input Parameters: None
//Description:This Function will be called in while Loop
//This is the main Function to transmit Data to Ethernet
if(g_iState==STATE_CONNECTED_IDLE)
if(EthResetRequired==1)
//EthClientTCPDisconnect();
EthResetRequired=0;
Soft_Reset();
//if((ProcessTransmit.TransmitFlag[e_IdCallResult]==0)||(ProcessTransmit.TransmitFlag[e_IdCall]==0))return;
//if(ProcessTransmit.Tx_Inprogress[e_IdCallResult]==1)return; //Uncomment Later , This will Block packet if Server Did not Respond//
if(WaitEthReconnect>0)return;
if((WebSocketflags.HanshakeStatus ==1)&&(WebSocketflags.HandshakeInprogress==0))
if(ProcessTransmit.TransmitFlag[e_IdCallResult]==1)
//EthClientReset();
//Return 1 if packet send successfully otherwise return 0
if(WeatherForecast(iWSrcOpenWeatherMap,g_psCityInfo[0].pcName,&g_psCityInfo[0].sReport,WeatherEvent)==0)
g_iState=STATE_WAIT_DATA;
ProcessTransmit.TransmitFlag[e_IdCallResult]=0;
ProcessTransmit.Tx_Inprogress[e_IdCallResult]=1;
Time_Sec = 10; //10 Sec
else if(ProcessTransmit.TransmitFlag[e_IdCall]==1)
g_iState=STATE_CONNECTED_IDLE;
ProcessTransmit.TransmitFlag[e_IdCall]=0;
ProcessTransmit.Tx_Inprogress[e_IdCall]=1;
else if((WebSocketflags.HanshakeStatus ==0)&&(WebSocketflags.HandshakeInprogress==0))
WebSocketflags.FlagProcessHandshake=1;
if( ProcessTransmit.TransmitFlag[e_IdCall]==0)return;
if(ProcessTransmit.Tx_Inprogress[e_IdCall]==1)return; //Uncomment Later , This will Block packet if Server Did not Respond//
//EthClientReset();
if(WeatherCurrent(iWSrcOpenWeatherMap,g_psCityInfo[0].pcName,&g_psCityInfo[0].sReport,WeatherEvent)==0)
restore();
// g_sEnet.eState = 8;
//Function void HandleConnectionsServerStates(void)
//This Function Handles and gives Connection Status
if(Time_Sec == 0)
// Close out the current connection.
// EthClientTCPDisconnect();
//lwIPNetworkConfigChange(0, 0, 0, IPADDR_USE_STATIC);
// lwIPNetworkConfigChange(0, 0, 0, IPADDR_USE_DHCP);
//EthClientReset();
//EthClientInit(EnetEvents);
TCP_ConnectionStatus = e_TCP_NotResponding;
Time_Sec = 10; //Retry Delay
return;
if(TCP_ConnectionStatus==e_TCP_NotResponding)
if(Time_Sec == 0)
// WeatherForecast1(iWSrcOpenWeatherMap,
// g_psCityInfo[0].pcName,
// &g_psCityInfo[0].sReport,
// WeatherEvent);
// This Condition Should not Occurr//
//lwIPNetworkConfigChange(0, 0, 0, IPADDR_USE_DHCP);
//EthClientReset();
// EthClientInit(EnetEvents);
g_iState=STATE_NOT_CONNECTED;
// g_iState= STATE_CONNECTED_IDLE;
else
else
if(TimerFlags.Bit.MCU_Led_Flag_1sec==0)return;
TimerFlags.Bit.MCU_Led_Flag_1sec=0;
if(ROM_GPIOPinRead(GPIO_PORTK_BASE ,MCU_LED )==0) ROM_GPIOPinWrite(GPIO_PORTK_BASE, MCU_LED, MCU_LED);
else ROM_GPIOPinWrite(GPIO_PORTK_BASE, MCU_LED, 0);
ProcessChargingTimeout();
// IndicationPower();
ChargingLEDAIndication();
ChargingLEDBIndication();
ChargingLEDCIndication();
FaultIndication();
//if(ProcessTransmit.Tx_Inprogress[e_IdCallResult]==0)return;
if(WebSocketflags.FlagProcessHandshake==0)return;
WebSocketflags.FlagProcessHandshake=0;
WebSocketflags.HandshakeInprogress=1;
//EthClientReset();
when i tried with enet_weather example the same is happening.
