Hi experts,
Thank you and best regards,
Max
TMS570LC4357: MEM8: Interconnect Self Test does not set NT_OK and PT_OK bits but ESM 3.12 is not set
Hi QJ,
Since the bits get updated on a failed test and Test results in a CPU-Reset anyway this should not be a problem correct.
It is just that the Reference Manual has a faulty description of the behaviour?
Thank you and best regard,
Max
Hi Max,
The flags will be cleared if the text fails. I will check with the owner of the Technical Reference Manual if it is a lit bug.
I think the description of NT_OK and PT_OK in TRM is not correct. Those two flags are not cleared by reset (nRST and nPORRST). Those two flags are cleared by the failed test. Thank you, Max, for pointing this out.
