Part Number: TM4C123GH6PM
Is it possible to sync pwm generators when you are using different modules? From what I understand, in order to use different periods, I need to use different modules, and that the methods:
PWMSyncTimeBase()
PWMSyncUpdate()
only work for the generators of the same module. I think I got my answer from https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/342642/synchronize-pwm-generators-of-differnet-pwm-modules and the poster Amit Ashara has posted a workaround.
But I am just asking again to clarify, and maybe the API has changed since then. Rephasing my questions:
a. can we sync different pwm modules?
b. if we are using the same module, can we set different periods for different generators?
C.
