Part Number: LAUNCHXL2-TMS57012
Other Parts Discussed in Thread: HALCOGEN
my code compser studio 12.0.0 was working properly. but since today when I create a new project and debug it, I get the following errors in the console. I don't know what is happening, I already reinstalled the ccs and I changed the workspace. Could anyone help me please?
The errors on the console are below
**** Build of configuration Debug for project DAC_Spi ****
"C:\\ti\\ccs1200\\ccs\\utils\\bin\\gmake" -k -j 4 all -O
Building file: "../source/errata_SSWF021_45.c"
Invoking: Arm Compiler
"C:/ti/ccs1200/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/Documents/myWorkspace/DAC_Spi" --include_path="D:/Documents/myWorkspace/DAC_Spi/source" --include_path="C:/ti/ccs1200/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="source/errata_SSWF021_45.d_raw" --obj_directory="source" "../source/errata_SSWF021_45.c"
>> Compilation failure
source/subdir_rules.mk:16: recipe for target 'source/errata_SSWF021_45.obj' failed
"../source/errata_SSWF021_45.c", line 40: fatal error #1965: cannot open source file "errata_SSWF021_45_defs.h"
1 catastrophic error detected in the compilation of "../source/errata_SSWF021_45.c".
Compilation terminated.
gmake: *** [source/errata_SSWF021_45.obj] Error 1
Building file: "../source/esm.c"
"C:/ti/ccs1200/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/Documents/myWorkspace/DAC_Spi" --include_path="D:/Documents/myWorkspace/DAC_Spi/source" --include_path="C:/ti/ccs1200/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="source/esm.d_raw" --obj_directory="source" "../source/esm.c"
>> Compilation failure
source/subdir_rules.mk:16: recipe for target 'source/esm.obj' failed
"../source/esm.c", line 52: fatal error #1965: cannot open source file "esm.h"
1 catastrophic error detected in the compilation of "../source/esm.c".
gmake: *** [source/esm.obj] Error 1
Building file: "../source/mibspi.c"
"C:/ti/ccs1200/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/Documents/myWorkspace/DAC_Spi" --include_path="D:/Documents/myWorkspace/DAC_Spi/source" --include_path="C:/ti/ccs1200/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="source/mibspi.d_raw" --obj_directory="source" "../source/mibspi.c"
>> Compilation failure
source/subdir_rules.mk:16: recipe for target 'source/mibspi.obj' failed
"../source/mibspi.c", line 46: fatal error #1965: cannot open source file "mibspi.h"
1 catastrophic error detected in the compilation of "../source/mibspi.c".
gmake: *** [source/mibspi.obj] Error 1
Building file: "../source/dabort.asm"
"C:/ti/ccs1200/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/Documents/myWorkspace/DAC_Spi" --include_path="D:/Documents/myWorkspace/DAC_Spi/source" --include_path="C:/ti/ccs1200/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="source/dabort.d_raw" --obj_directory="source" "../source/dabort.asm"
Finished building: "../source/dabort.asm"
Building file: "../source/notification.c"
"C:/ti/ccs1200/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/Documents/myWorkspace/DAC_Spi" --include_path="D:/Documents/myWorkspace/DAC_Spi/source" --include_path="C:/ti/ccs1200/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="source/notification.d_raw" --obj_directory="source" "../source/notification.c"
>> Compilation failure
source/subdir_rules.mk:16: recipe for target 'source/notification.obj' failed
"../source/notification.c", line 51: fatal error #1965: cannot open source file "esm.h"
1 catastrophic error detected in the compilation of "../source/notification.c".
gmake: *** [source/notification.obj] Error 1
Building file: "../source/pinmux.c"
"C:/ti/ccs1200/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/Documents/myWorkspace/DAC_Spi" --include_path="D:/Documents/myWorkspace/DAC_Spi/source" --include_path="C:/ti/ccs1200/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="source/pinmux.d_raw" --obj_directory="source" "../source/pinmux.c"
>> Compilation failure
source/subdir_rules.mk:16: recipe for target 'source/pinmux.obj' failed
"../source/pinmux.c", line 45: fatal error #1965: cannot open source file "pinmux.h"
1 catastrophic error detected in the compilation of "../source/pinmux.c".
gmake: *** [source/pinmux.obj] Error 1
Building file: "../source/sys_dma.c"
"C:/ti/ccs1200/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/Documents/myWorkspace/DAC_Spi" --include_path="D:/Documents/myWorkspace/DAC_Spi/source" --include_path="C:/ti/ccs1200/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="source/sys_dma.d_raw" --obj_directory="source" "../source/sys_dma.c"
>> Compilation failure
source/subdir_rules.mk:16: recipe for target 'source/sys_dma.obj' failed
"../source/sys_dma.c", line 44: fatal error #1965: cannot open source file "sys_dma.h"
1 catastrophic error detected in the compilation of "../source/sys_dma.c".
gmake: *** [source/sys_dma.obj] Error 1
Building file: "../source/sys_core.asm"
"C:/ti/ccs1200/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/Documents/myWorkspace/DAC_Spi" --include_path="D:/Documents/myWorkspace/DAC_Spi/source" --include_path="C:/ti/ccs1200/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="source/sys_core.d_raw" --obj_directory="source" "../source/sys_core.asm"
Finished building: "../source/sys_core.asm"
Building file: "../source/sys_main.c"
"C:/ti/ccs1200/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/Documents/myWorkspace/DAC_Spi" --include_path="D:/Documents/myWorkspace/DAC_Spi/source" --include_path="C:/ti/ccs1200/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="source/sys_main.d_raw" --obj_directory="source" "../source/sys_main.c"
>> Compilation failure
source/subdir_rules.mk:16: recipe for target 'source/sys_main.obj' failed
"../source/sys_main.c", line 50: fatal error #1965: cannot open source file "sys_common.h"
1 catastrophic error detected in the compilation of "../source/sys_main.c".
gmake: *** [source/sys_main.obj] Error 1
Building file: "../source/sys_intvecs.asm"
"C:/ti/ccs1200/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/Documents/myWorkspace/DAC_Spi" --include_path="D:/Documents/myWorkspace/DAC_Spi/source" --include_path="C:/ti/ccs1200/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="source/sys_intvecs.d_raw" --obj_directory="source" "../source/sys_intvecs.asm"
Finished building: "../source/sys_intvecs.asm"
Building file: "../source/sys_pcr.c"
"C:/ti/ccs1200/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/Documents/myWorkspace/DAC_Spi" --include_path="D:/Documents/myWorkspace/DAC_Spi/source" --include_path="C:/ti/ccs1200/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="source/sys_pcr.d_raw" --obj_directory="source" "../source/sys_pcr.c"
>> Compilation failure
source/subdir_rules.mk:16: recipe for target 'source/sys_pcr.obj' failed
"../source/sys_pcr.c", line 42: fatal error #1965: cannot open source file "sys_pcr.h"
1 catastrophic error detected in the compilation of "../source/sys_pcr.c".
gmake: *** [source/sys_pcr.obj] Error 1
Building file: "../source/sys_phantom.c"
"C:/ti/ccs1200/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/Documents/myWorkspace/DAC_Spi" --include_path="D:/Documents/myWorkspace/DAC_Spi/source" --include_path="C:/ti/ccs1200/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="source/sys_phantom.d_raw" --obj_directory="source" "../source/sys_phantom.c"
>> Compilation failure
source/subdir_rules.mk:16: recipe for target 'source/sys_phantom.obj' failed
"../source/sys_phantom.c", line 45: fatal error #1965: cannot open source file "sys_common.h"
1 catastrophic error detected in the compilation of "../source/sys_phantom.c".
gmake: *** [source/sys_phantom.obj] Error 1
Building file: "../source/sys_mpu.asm"
"C:/ti/ccs1200/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/Documents/myWorkspace/DAC_Spi" --include_path="D:/Documents/myWorkspace/DAC_Spi/source" --include_path="C:/ti/ccs1200/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="source/sys_mpu.d_raw" --obj_directory="source" "../source/sys_mpu.asm"
Finished building: "../source/sys_mpu.asm"
Building file: "../source/sys_pmm.c"
"C:/ti/ccs1200/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/Documents/myWorkspace/DAC_Spi" --include_path="D:/Documents/myWorkspace/DAC_Spi/source" --include_path="C:/ti/ccs1200/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="source/sys_pmm.d_raw" --obj_directory="source" "../source/sys_pmm.c"
>> Compilation failure
source/subdir_rules.mk:16: recipe for target 'source/sys_pmm.obj' failed
"../source/sys_pmm.c", line 42: fatal error #1965: cannot open source file "sys_pmm.h"
1 catastrophic error detected in the compilation of "../source/sys_pmm.c".
gmake: *** [source/sys_pmm.obj] Error 1
Building file: "../source/sys_selftest.c"
"C:/ti/ccs1200/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/Documents/myWorkspace/DAC_Spi" --include_path="D:/Documents/myWorkspace/DAC_Spi/source" --include_path="C:/ti/ccs1200/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="source/sys_selftest.d_raw" --obj_directory="source" "../source/sys_selftest.c"
>> Compilation failure
source/subdir_rules.mk:16: recipe for target 'source/sys_selftest.obj' failed
"../source/sys_selftest.c", line 48: fatal error #1965: cannot open source file "sys_selftest.h"
1 catastrophic error detected in the compilation of "../source/sys_selftest.c".
gmake: *** [source/sys_selftest.obj] Error 1
Building file: "../source/sys_startup.c"
"C:/ti/ccs1200/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/Documents/myWorkspace/DAC_Spi" --include_path="D:/Documents/myWorkspace/DAC_Spi/source" --include_path="C:/ti/ccs1200/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="source/sys_startup.d_raw" --obj_directory="source" "../source/sys_startup.c"
>> Compilation failure
source/subdir_rules.mk:16: recipe for target 'source/sys_startup.obj' failed
"../source/sys_startup.c", line 57: fatal error #1965: cannot open source file "sys_common.h"
1 catastrophic error detected in the compilation of "../source/sys_startup.c".
gmake: *** [source/sys_startup.obj] Error 1
Building file: "../source/sys_vim.c"
"C:/ti/ccs1200/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/Documents/myWorkspace/DAC_Spi" --include_path="D:/Documents/myWorkspace/DAC_Spi/source" --include_path="C:/ti/ccs1200/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="source/sys_vim.d_raw" --obj_directory="source" "../source/sys_vim.c"
>> Compilation failure
source/subdir_rules.mk:16: recipe for target 'source/sys_vim.obj' failed
"../source/sys_vim.c", line 44: fatal error #1965: cannot open source file "sys_vim.h"
1 catastrophic error detected in the compilation of "../source/sys_vim.c".
gmake: *** [source/sys_vim.obj] Error 1
Building file: "../source/sys_pmu.asm"
"C:/ti/ccs1200/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/Documents/myWorkspace/DAC_Spi" --include_path="D:/Documents/myWorkspace/DAC_Spi/source" --include_path="C:/ti/ccs1200/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="source/sys_pmu.d_raw" --obj_directory="source" "../source/sys_pmu.asm"
Finished building: "../source/sys_pmu.asm"
Building file: "../source/system.c"
"C:/ti/ccs1200/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/bin/armcl" -mv7R4 --code_state=32 --float_support=VFPv3D16 --include_path="D:/Documents/myWorkspace/DAC_Spi" --include_path="D:/Documents/myWorkspace/DAC_Spi/source" --include_path="C:/ti/ccs1200/ccs/tools/compiler/ti-cgt-arm_20.2.6.LTS/include" -g --diag_warning=225 --diag_wrap=off --display_error_number --enum_type=packed --abi=eabi --preproc_with_compile --preproc_dependency="source/system.d_raw" --obj_directory="source" "../source/system.c"
>> Compilation failure
source/subdir_rules.mk:16: recipe for target 'source/system.obj' failed
"../source/system.c", line 53: fatal error #1965: cannot open source file "system.h"
1 catastrophic error detected in the compilation of "../source/system.c".
gmake: *** [source/system.obj] Error 1
gmake: Target 'all' not remade because of errors.
**** Build Finished ****
