AM2634-Q1: Autosar : ADC ISR not triggered on period match event of PWM
Part Number: AM2634-Q1
Platform :
MCAL : MCAL_AM263x_08.06.02
Configurations :
XBAR Configured :
MCU Config : XBAR0_OUT0 -> EPWM0_INT
MCU Config : XBAR0_OUT1 -> ADC0_INT1
INT Enabled :
Os_Hal_INTC_EnableSource(146)
Os_Hal_INTC_EnableSource(147)
Notifications Enabled :
ADC and PWM channel notification
Configured PWM : Period Match Interrupt (CDD based - Not Autosar Based)
Compare SS : CMPA and CMPC registers configured
Trigger SS : Configured to trigger EPWM0.SOCA
Configured ADC : to be triggered by EPWM0
Trigger Source EPWM0
Interrupt based result collection
Configured OS ISR:
Cat0 ISR for PWM0
Cat1 ISR for ADC0
Observations :
PWM0.ETFLG shows SOCA was generated
ADCSOCFLG.SOC0 updated
ADCRESULT0 seems to be updated.
Miss-match in expectation :
ADC INT not triggered
ADC notification not triggered; as ADC INT not triggered
Additional tries:
Configured ADC as ISR CAT2; still the same behavior.
I have query related to the MCU generation; as well.
A quick help here would be much appreciated please. Please do also let me know if a call is possible to address the topic.
  • MoM : 22/06/2023:
    • Adc_EnableHardwareTrigger will start configuring the registers from SOC15 Sub-modules onwards
      • It will configure the SOC sub-modules based on the configured group priority.
        • Ex: If Grp0 -> lower prio and Grp1 -> higher prio; then Grp0 SOC updated in SOC15 register  then Grp1 SOC updated in SOC14 register
    • Adc_EnableHardwareTrigger for One-Shot conversion; would need to be called cyclically as the current MCAL implementation would clear the SOC configuration info from ISR. This behaviour would need to be re-looked by TI internally.
    • Adc_EnableHardwareTrigger for Continuous conversion is not supported due to Autosar limitation in he MCAL.
    • Mcu generation for the XBAR interrupt mapping for ADC channels seems to be incorrect; which would need to be fixed.
    Further action points:
    • Check the VIM status dump for interrupts mapped out of OS context.
      • If its generating the interrupts correctly; then Vector needs to be contacted for further debugging.
    • Need to know why HW trigger details are not getting captured in the corresponding SOC14 and SOC13 registers; for the other ADC channels; even though they are configured.
  • Hi Ashish,
    Please find the details below shared by our ADC expert.
    The Interrupt Flag to be verified in ADC module, to confirm whether interrupt occurred or not:
    The below provided package has details of the MCAL ADC module working for Cross bar OUT 2 (Interrupt source 148).
    /cfs-file/__key/communityserver-discussions-components-files/908/MCAL_5F00_AM263x_5F00_08.06.02.zip
    Application provided here is on top of the MCAL Release package 8.6.2. Changes we did are:
    HW UNIT 0 used here (Similar to your use case application) and
    XBAR OUT 2 (148)  is mapped to HW UNIT 0 , INT 0 (as shown below)
    Please validate package has the same behavior at your end and confirm it.
    Thanks And Regards,
    Sunil Kumar M S
    * Copyright (c) 2023 Texas Instruments Incorporated
    * All rights reserved not granted herein.
    * Limited License.
    * Texas Instruments Incorporated grants a world-wide, royalty-free, non-exclusive
    * license under copyrights and patents it now or hereafter owns or controls to make,
    * have made, use, import, offer to sell and sell ("Utilize") this software subject to the
    * terms herein.  With respect to the foregoing patent license, such license is granted
    * solely to the extent that any such patent is necessary to Utilize the software alone.
    * The patent license shall not apply to any combinations which include this software,
    * other than combinations with devices manufactured by or for TI ("TI Devices").
    * No hardware patent is licensed hereunder.
    * Redistributions must preserve existing copyright notices and reproduce this license
    * (including the above copyright notice and the disclaimer and (if applicable) source
    * code license limitations below) in the documentation and/or other materials provided
    * with the distribution
    * Redistribution and use in binary form, without modification, are permitted provided
    * that the following conditions are met:
    * *       No reverse engineering, decompilation, or disassembly of this software is
    * permitted with respect to any software provided in binary form.
    * *       any redistribution and use are licensed by TI for use only with TI Devices.
    * *       Nothing shall obligate TI to provide you with source code for the software
    * licensed and provided to you in object code.
    * If software source code is provided to you, modification and redistribution of the
    * source code are permitted provided that the following conditions are met:
    * *       any redistribution and use of the source code, including any resulting derivative
    * works, are licensed by TI for use only with TI Devices.
    * *       any redistribution and use of any object code compiled from the source code
    * and any resulting derivative works, are licensed by TI for use only with TI Devices.
    * Neither the name of Texas Instruments Incorporated nor the names of its suppliers
    * may be used to endorse or promote products derived from this software without
    * specific prior written permission.
    * DISCLAIMER.
    * THIS SOFTWARE IS PROVIDED BY TI AND TI'S LICENSORS "AS IS" AND ANY EXPRESS
    * OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
    * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
    * IN NO EVENT SHALL TI AND TI'S LICENSORS BE LIABLE FOR ANY DIRECT, INDIRECT,
    * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
    * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
    * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY
    * OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE
    * OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
    * OF THE POSSIBILITY OF SUCH DAMAGE.
        Project: AM263x
        Date   : 2023-05-05 22:44:32
        This file is generated by EB Tresos
        Do not modify this file, otherwise the software may behave in unexpected way
     *  INCLUDES
    #include "Std_Types.h"
    #include "Adc.h"
    #include "Adc_Irq.h"
     *  VERSION CHECK
    #if ( (ADC_CFG_MAJOR_VERSION != (8U)) \
        ||(ADC_CFG_MINOR_VERSION != (6U)))
      #error "Version numbers of Adc_PBcfg.c and Adc_Cfg.h are inconsistent!"
    #endif
     *  GLOBAL CONFIG DATA
    #define ADC_START_SEC_CONFIG_DATA
    #include "Adc_MemMap.h"
    #ifdef __cplusplus
    extern "C" {
    #endif
    extern void AdcApp_HwUnit0_Group0EndNotification(void);
    extern void AdcApp_HwUnit0_Group1EndNotification(void);
    extern void AdcApp_HwUnit0_Group2EndNotification(void);
    extern void AdcApp_HwUnit0_Group3EndNotification(void);
    extern void AdcApp_HwUnit0_Group4EndNotification(void);
    extern void AdcApp_HwUnit1_Group5EndNotification(void);
    /* Create runtime configurations. */
    CONST(struct Adc_ConfigType_s, ADC_CONFIG_DATA) AdcConfigSet =
        .maxGroup = 6U,
        .maxHwUnit = 2U,
        .groupCfg  =
            [0] =
                .groupId = AdcConf_AdcHwUnit_AdcHwUnit_0_AdcGroup_AdcGroup_0,
                .groupPriority =0U,
                .hwUnitId = 0,
                .Adc_GroupEndNotification = AdcApp_HwUnit0_Group0EndNotification,
                .streamNumSamples = (Adc_StreamNumSampleType)1,
                .resolution = ADC_DEF_CHANNEL_RESOLUTION,/* This is not configurable and should be set to ADC_DEF_CHANNEL_RESOLUTION */
                .convMode = ADC_CONV_MODE_ONESHOT,
                .triggSrc = ADC_TRIGG_SRC_SW,
                .accessMode = ADC_ACCESS_MODE_SINGLE,
                .streamBufMode = ADC_STREAM_BUFFER_LINEAR,
                .hwTrigSignal = ADC_HW_TRIG_BOTH_EDGES,
                .hwTrigTimer =ADC_TRIGGER_SW_ONLY,
                .groupReplacement = (Adc_GroupReplacementType)ADC_GROUP_REPL_SUSPEND_RESUME,
                .groupChannelMask = 0x1,
    #if (STD_ON == ADC_ENABLE_LIMIT_CHECK)
                .grouplimitcheck = FALSE,
    #endif
                .groupDataAccessMode = ADC_GROUP_INTERRUPT_ACCESS,
                .numChannels = 1U,
                .channelConfig =
                    [0] =
                        .hwChannelId = 0U,
                        .samplewindow = 16U,
    #if (STD_ON == ADC_DMA_MODE)
                        .adcDMAChannel = 0,
    #endif
                        .channelEnableLimitCheck =(FALSE),
                        .highRange =2482,
                        .lowRange =1241,
    #endif
            [1] =
                .groupId = AdcConf_AdcHwUnit_AdcHwUnit_0_AdcGroup_AdcGroup_1,
                .groupPriority =2U,
                .hwUnitId = 0,
                .Adc_GroupEndNotification = AdcApp_HwUnit0_Group1EndNotification,
                .convMode = ADC_CONV_MODE_CONTINUOUS,
    #endif
                .numChannels = 1U,
                .channelConfig =
                    [0] =
                        .hwChannelId = 0U,
                        .adcDMAChannel = 0,
    #endif
                        .highRange =2482,
                        .lowRange =1241,
    #endif
            [2] =
                .groupId = AdcConf_AdcHwUnit_AdcHwUnit_0_AdcGroup_AdcGroup_2,
                .groupPriority =3U,
                .hwUnitId = 0,
                .Adc_GroupEndNotification = AdcApp_HwUnit0_Group2EndNotification,
                .triggSrc = ADC_TRIGG_SRC_HW,
                .hwTrigTimer =ADC_TRIGGER_EPWM0_SOCA,
                .groupChannelMask = 0xd,
    #endif
                .numChannels = 4U,
                .channelConfig =
                    [0] =
                        .hwChannelId = 0U,
                        .adcDMAChannel = 0,
    #endif
                        .highRange =2482,
                        .lowRange =1241,
    #endif
                    [1] =
                        .hwChannelId = 2U,
                        .adcDMAChannel = 2,
    #endif
                        .highRange =4095,
                        .lowRange =0,
    #endif
                    [2] =
                        .hwChannelId = 2U,
                        .adcDMAChannel = 2,
    #endif
                        .highRange =4095,
                        .lowRange =0,
    #endif
                    [3] =
                        .hwChannelId = 3U,
                        .adcDMAChannel = 3,
    #endif
                        .highRange =4095,
                        .lowRange =0,
    #endif
            [3] =
                .groupId = AdcConf_AdcHwUnit_AdcHwUnit_0_AdcGroup_AdcGroup_3,
                .groupPriority =4U,
                .hwUnitId = 0,
                .Adc_GroupEndNotification = AdcApp_HwUnit0_Group3EndNotification,
                .streamNumSamples = (Adc_StreamNumSampleType)3,
                .hwTrigSignal = ADC_HW_TRIG_FALLING_EDGE,
                .hwTrigTimer =ADC_TRIGGER_EPWM0_SOCB,
    #endif
                .numChannels = 2U,
                .channelConfig =
                    [0] =
                        .hwChannelId = 0U,
                        .adcDMAChannel = 0,
    #endif
                        .highRange =2482,
                        .lowRange =1241,
    #endif
                    [1] =
                        .hwChannelId = 1U,
                        .adcDMAChannel = 1,
    #endif
                        .highRange =4095,
                        .lowRange =0,
    #endif
            [4] =
                .groupId = AdcConf_AdcHwUnit_AdcHwUnit_0_AdcGroup_AdcGroup_4,
                .groupPriority =5U,
                .hwUnitId = 0,
                .Adc_GroupEndNotification = AdcApp_HwUnit0_Group4EndNotification,
                .hwTrigSignal =ADC_HW_TRIG_BOTH_EDGES,
                .hwTrigTimer =ADC_TRIGGER_EPWM1_SOCA,
    #endif
                .numChannels = 1U,
                .channelConfig =
                    [0] =
                        .hwChannelId = 0U,
                        .adcDMAChannel = 0,
    #endif
                        .highRange =2482,
                        .lowRange =1241,
    #endif
            [5] =
                .groupId = AdcConf_AdcHwUnit_AdcHwUnit_1_AdcGroup_AdcGroup_5,
                .groupPriority =0U,
                .hwUnitId = 1,
                .Adc_GroupEndNotification = AdcApp_HwUnit1_Group5EndNotification,
                .groupChannelMask = 0x3f,
    #endif
                .groupDataAccessMode = ADC_GROUP_DMA_ACCESS,
                .numChannels = 6U,
                .channelConfig =
                    [0] =
                        .hwChannelId = 0U,
                        .adcDMAChannel = 6,
    #endif
                        .highRange =2482,
                        .lowRange =1241,
    #endif
                    [1] =
                        .hwChannelId = 1U,
                        .adcDMAChannel = 7,
    #endif
                        .highRange =4095,
                        .lowRange =0,
    #endif
                    [2] =
                        .hwChannelId = 2U,
                        .adcDMAChannel = 8,
    #endif
                        .highRange =4095,
                        .lowRange =0,
    #endif
                    [3] =
                        .hwChannelId = 3U,
                        .adcDMAChannel = 9,
    #endif
                        .highRange =4095,
                        .lowRange =0,
    #endif
                    [4] =
                        .hwChannelId = 4U,
                        .adcDMAChannel = 10,
    #endif
                        .highRange =4095,
                        .lowRange =0,
    #endif
                    [5] =
                        .hwChannelId = 5U,
                        .adcDMAChannel = 11,
    #endif
                        .highRange =4095,
                        .lowRange =0,
    #endif
        .hwUnitCfg =
            [0] =
                .hwUnitId = (Adc_HWUnitType)ADC_HWUNIT_0,
                .baseAddr =0x502c0000UL,
                .prescale = (Adc_mcalClkPrescale_t)ADC_CLK_DIV_1_0,
                .resolution = (Adc_mcalResolution_t)ADC_RESOLUTION_12BIT,
            [1] =
                .hwUnitId = (Adc_HWUnitType)ADC_HWUNIT_3,
                .baseAddr =0x502c3000UL,
    #ifdef __cplusplus
    #endif
    #define ADC_STOP_SEC_CONFIG_DATA
     *  END OF FILE: Adc_PBcfg.c
     *   Copyright (C) 2022-2023 Texas Instruments Incorporated
     *   All rights reserved. Property of Texas Instruments Incorporated.
     *   Restricted rights to use, duplicate or disclose this code are
     *   granted through contract.
     *   The program may not be used without the written permission
     *   of Texas Instruments Incorporated or against the terms and conditions
     *   stipulated in the agreement under which this program has been
     *   supplied.
     *  \file     AdcApp.c
     *  \brief    This file contains the Adc test example
    /*                             Include Files                                  */
    /*LDRA_NOANALYSIS*/
    #include "string.h"
    /*LDRA_ANALYSIS*/
    #include "assert.h"
    /*LDRA_NOANALYSIS*/
    #include "SchM_Port.h"
    #include "Det.h"
    #include "Dem.h"
    #include "Mcu.h"
    #include "Mcu_Cfg.h"
    #include "Port_Cfg.h"
    #include "Port.h"
    #include "Cdd_Dma.h"
    #include "Adc_Cfg.h"
    #include "Adc.h"
    #include "app_utils.h"
    #include "sys_common.h"
    #include "AdcApp.h"
    #include "Epwm_Platform.h"
    #include "trace.h"
    #include "sys_vim.h"
    /* For PRCM base addresses */
    #include "soc.h"
    /*                           Macros & Typedefs                                */
    #define ARRAYSIZE(x)                    (sizeof ((x)) / sizeof ((x)[0]))
    /* Macros to Enable ADC Application Test and Performance Test */
    #define ADC_APPL_TEST                   STD_ON
    #define ADC_PERFORMANCE_TEST            STD_OFF
    /*                         Structures and Enums                               */
    typedef void (*AdcAppFxn_t)(void);
    #if (STD_OFF == MCU_NO_PLL)
    extern CONST(Mcu_ConfigType, MCU_PBCFG) McuModuleConfiguration;
    #endif
    /*                 Internal Function Declarations                             */
    void _enable_interrupt_(void);
    void StartCyclecount(void);
    static void AdcApp_platformInit(void);;
    static void AdcApp_interruptConfig(void);
    static void AdcApp_interruptInit(void);
    static void SOC_setEpwmGroup(uint32 epwmInstance, uint32 group);
    static void SOC_setEpwmTbClk(uint32 epwmInstance, uint32 enable);
    static void SOC_controlModuleUnlockMMR(uint32 domainId, uint32 partition);
    static void SOC_controlModuleLockMMR(uint32 domainId, uint32 partition);
    static inline void
    SOC_xbarSelectInterruptXBarInputSource
    (uint32 base, uint8 out, uint32 group0_mask, uint32 group1_mask,
     uint32 group2_mask, uint32 group3_mask, uint32 group4_mask,
     uint32 group5_mask, uint32 group6_mask);
    static inline void SOC_enableAdcReference(uint32 adcInstance);
    static void AdcApp_mainTest(void);
    static void Adc_Test(void);
    void AdcTest(uint32 vart);
    void Stop_Timer(uint8 Api_Id);
    void Start_Timer(void);
    static void AdcExample_PerformanceTest(void);
    static void AdcApp_Notification(uint32 grpIdx);
    static void Epwm_Enable(void);
    static uint32 AppUtils_GetAdcVoltage(uint32 adcValue);
    /*                            Global Variables                                */
    #endif
    volatile uint32  NotificationCount[20];
    Mcu_ClockConfigType AdcMcu_ClkConfig[] =
       [0] =
       { .Mcu_InitCfg       = TRUE,
        .Mcu_ClockModuleId = MCU_CLKSRC_MODULE_ID_RTI0,
        .Mcu_ClockSourceId = MCU_CLKSRC_2,
        .Mcu_ClockDiv = 0U // Source = Sysclk ie 200MHz, so (200/(0+1) = 200MHz with 200MHz clk)
       [1] =
        .Mcu_ClockModuleId = MCU_CLKSRC_MODULE_ID_RTI1,
       [2] =
        .Mcu_ClockModuleId = MCU_CLKSRC_MODULE_ID_RTI2,
        [3] =
        .Mcu_ClockModuleId = MCU_CLKSRC_MODULE_ID_RTI3,
        [4] =
        .Mcu_ClockModuleId = MCU_CLKSRC_MODULE_ID_SCI0,
        .Mcu_ClockSourceId = MCU_CLKSRC_3,
        .Mcu_ClockDiv = 3,
    static Mcu_ConfigType        gAdcAppMcuConfig =
        .Mcu_ResetMode           = MCU_PERFORM_RESET_MODE_WARM,
        .Mcu_ConfigRamSection    = (Mcu_RamConfigPtrType) NULL_PTR,
        .Mcu_NumberOfRamSectors  = 0,
        .Mcu_ClockConfig         = (Mcu_ClockConfigPtrType)&AdcMcu_ClkConfig,
        .Mcu_NumberOfClockConfig = ARRAYSIZE(AdcMcu_ClkConfig),
    AdcAppFxn_t                  AdcAppFxnTbl[] =
        &AdcApp_mainTest
    uint32              gTestPassed = E_OK;
    /**< Number of times App runs */
    Adc_ValueGroupType                Adc_AppBuffer[ADC_MAX_GROUP][ADC_APP_BUF_SIZE_WORD];
    /**< SetUp Result Buffer passed to driver */
    Adc_ValueGroupType                Adc_AppReadBuffer[ADC_MAX_GROUP][ADC_APP_READ_BUF_SIZE_WORD];
    /**< Output Result Buffer */
    volatile uint32                   Adc_AppRdBufCount[ADC_MAX_GROUP];
    /**< No of Samples Counter */
    volatile uint32                   Adc_AppGroupDone[ADC_MAX_GROUP];
    /**< Group Conversion Completion flag */
    extern const Adc_ConfigType *Adc_ConfigPtr;
    volatile uint32     gAdcAppGroupDone[ADC_MAX_GROUP];
    uint32 Adc_AppLoopCount = ADC_APP_LOOP_COUNT;
    /*                          Function Definitions                              */
    #if defined CLANG
    void  SchM_Enter_Mcu_MCU_EXCLUSIVE_AREA_0()
        AppUtils_SchM_Enter_EXCLUSIVE_AREA_0();
    void   SchM_Exit_Mcu_MCU_EXCLUSIVE_AREA_0()
         AppUtils_SchM_Exit_EXCLUSIVE_AREA_0();
    void  SchM_Enter_Adc_ADC_EXCLUSIVE_AREA_0()
    void   SchM_Exit_Adc_ADC_EXCLUSIVE_AREA_0()
    void  SchM_Enter_Port_PORT_EXCLUSIVE_AREA_0()
    void   SchM_Exit_Port_PORT_EXCLUSIVE_AREA_0()
    void  SchM_Enter_Cdd_Dma_DMA_EXCLUSIVE_AREA_0()
    void   SchM_Exit_Cdd_Dma_DMA_EXCLUSIVE_AREA_0()
    #endif
    int main(void)
        uint32 i;
        AppUtils_defaultInit();
    	AppUtils_sectionInit();
        /*Enable Domain clocks*/
        AdcApp_platformInit();
        /* Enable time base clock for the selected ePWM */
        //SOC_setEpwmTbClk(0, TRUE);
        //SOC_setEpwmGroup(0, 0);
        /* Setup Interrupt. */
        AdcApp_interruptInit();
    #if (ADC_APPL_TEST == STD_ON)
        /* Sample Application to Test ADC module. */
        AppUtils_printf(ADC_APP_NAME ": Sample Application - Initiated !!!\n\r");
        for (i = 0U; i < ARRAYSIZE(AdcAppFxnTbl); i++)
            AdcAppFxnTbl[i]();
    #endif
        GT_1trace(McalAppTrace, GT_INFO,
                  " ADC Stack Usage: %d bytes\n\r", AppUtils_getStackUsage());
        if (AppUtils_checkStackAndSectionCorruption() != E_OK)
            gTestPassed = E_NOT_OK;
            GT_0trace(McalAppTrace, GT_ERR, " ADC Stack/section corruption!!!\n\r");
    	AppUtils_TimerDeinit();
    	AppUtils_printf(ADC_APP_NAME ": Sample Application - Completed. !!!\n\r");
        return (0);
        uint32              grpIdx;
        uint32              testPassed = E_OK;
        Adc_StatusType      status;
        Std_ReturnType      retVal;
        char option;
        uint32 isPending;
        uint32 loopCount = 0U;
        uint32 loopCnt = 10U;
        uint16 data;
        const Adc_ConfigType *Adc_ConfigPtr = &AdcConfigSet;
    #if (ADC_VERSION_INFO_API == STD_ON)
        Std_VersionInfoType versioninfo;
        Adc_GetVersionInfo(&versioninfo);
        AppUtils_printf("ADC MCAL Version Info\n\r");
        AppUtils_printf("---------------------\n\r");
        AppUtils_printf("Vendor ID           : %d\n\r", versioninfo.vendorID);
        AppUtils_printf("Module ID           : %d\n\r", versioninfo.moduleID);
        AppUtils_printf("SW Major Version    : %d\n\r", versioninfo.sw_major_version);
        AppUtils_printf("SW Minor Version    : %d\n\r", versioninfo.sw_minor_version);
        AppUtils_printf("SW Patch Version    : %d\n\r", versioninfo.sw_patch_version);
        AppUtils_printf(" \n\r");
    #endif  /* #if (ADC_VERSION_INFO_API == STD_ON) */
        /* Initilize the timer. */
    	AppUtils_TimerInit();
    	Cdd_Dma_Init(NULL_PTR);
    #endif
    	/* Initialize the ADC module. */
        Adc_Init(Adc_ConfigPtr);
        /* Set the Buffer of ADC conversion. */
        for (grpIdx = 0U; grpIdx < Adc_ConfigPtr->maxGroup; grpIdx++)
            /* Reset read counter and buffer content */
            Adc_AppRdBufCount[grpIdx] = 0U;
            memset(
                &Adc_AppReadBuffer[grpIdx][0],
                0U,
                (sizeof (Adc_ValueGroupType) * ADC_APP_READ_BUF_SIZE_WORD));
            /* Check group status - it should be idle */
            status = Adc_GetGroupStatus(grpIdx);
            if (status != ADC_IDLE)
                testPassed = E_NOT_OK;
                AppUtils_printf(ADC_APP_NAME, " ADC Group %d is not IDLE!!\n\r", grpIdx);
            /* Memset result buffer and give to driver */
            memset(
                &Adc_AppBuffer[grpIdx][0],
                0U,
                (sizeof (Adc_ValueGroupType) * ADC_APP_BUF_SIZE_WORD));
            retVal = Adc_SetupResultBuffer(grpIdx, &Adc_AppBuffer[grpIdx][0]);
            if (retVal != E_OK)
                AppUtils_printf(ADC_APP_NAME, " ADC Group %d setup buffer failed!!\n\r",
                    grpIdx);
            #if (ADC_GRP_NOTIF_CAPABILITY_API == STD_ON)
            /* Enable notification */
            Adc_EnableGroupNotification(grpIdx);
            #endif      /* #if (ADC_GRP_NOTIF_CAPABILITY_API == STD_ON) */
        /* Hardware Triggered Group Testing. */
        AppUtils_printf( " Hardware Triggered Group Conversion started. !!!\r\n");
        AppUtils_printf( ADC_APP_NAME ": Hardware Triggered Group Notifiation count is : %d :)!!!\n\r",
                                  NotificationCount[AdcConf_AdcHwUnit_AdcHwUnit_0_AdcGroup_AdcGroup_2]);
        /* Enable Hardware Triggered Group for ADC. */
        Epwm_Enable();
        Adc_EnableHardwareTrigger(AdcConf_AdcHwUnit_AdcHwUnit_0_AdcGroup_AdcGroup_2);
        Adc_EnableHardwareTrigger(AdcConf_AdcHwUnit_AdcHwUnit_0_AdcGroup_AdcGroup_3);
        Adc_EnableHardwareTrigger(AdcConf_AdcHwUnit_AdcHwUnit_0_AdcGroup_AdcGroup_4);
        AppUtils_printf( " Wait for 10 seconds, Trigger is not applied. !!!\r\n");
        AppUtils_delay(10000U);
        /* External Trigger for ADC. */
        AppUtils_printf( " PWM trigger is applied. !!!\r\n");
        EPWM_setTimeBaseCounterMode(0x50000000ul, EPWM_COUNTER_MODE_UP);
        EPWM_setTimeBaseCounterMode(0x50001000ul, EPWM_COUNTER_MODE_UP);
        AppUtils_printf( " Disable the trigger source. !!!\r\n");
        EPWM_disableADCTrigger(0x50000000ul, EPWM_SOC_A);
        AppUtils_printf( ADC_APP_NAME ": Hardware Triggered Group Notifiation : %d :)!!!\n\r",
        Adc_DisableHardwareTrigger(AdcConf_AdcHwUnit_AdcHwUnit_0_AdcGroup_AdcGroup_2);
        /* Clear the counter. */
        NotificationCount[AdcConf_AdcHwUnit_AdcHwUnit_0_AdcGroup_AdcGroup_2] = 0;
        /* Polling Group Conversion.  */
        /*Adc_StartGroupConversion(AdcConf_AdcHwUnit_AdcHwUnit_0_AdcGroup_AdcGroup_4);
        Adc_ReadGroup(AdcConf_AdcHwUnit_AdcHwUnit_0_AdcGroup_AdcGroup_4, &Adc_AppReadBuffer[0][0]);
        AppUtils_printf( ADC_APP_NAME ": Polling Value Digital Value for %dmV input is %d :)!!!\n\r",
                   AppUtils_GetAdcVoltage(Adc_AppReadBuffer[0][0]), Adc_AppReadBuffer[0][0]);
        AppUtils_printf( ADC_APP_NAME ": Polling Group Notifiation count is : %d :)!!!\n\r",
                                  NotificationCount[AdcConf_AdcHwUnit_AdcHwUnit_0_AdcGroup_AdcGroup_4]);*/
        AppUtils_printf( " Software Group Conversion Initiated in DMA Group ONE SHOT MODE. !!!\r\n");
        #if (ADC_ENABLE_START_STOP_GROUP_API == STD_ON)
        Adc_StartGroupConversion(AdcConf_AdcHwUnit_AdcHwUnit_1_AdcGroup_AdcGroup_5);
        #endif      /* #if (ADC_ENABLE_START_STOP_GROUP_API == STD_ON) */
        /* Wait for all group conversion to get over */
        /* Check the Status of ADC Group. */
        while(ADC_BUSY == Adc_GetGroupStatus(AdcConf_AdcHwUnit_AdcHwUnit_1_AdcGroup_AdcGroup_5))
        AppUtils_printf( " Conversion Completed. !!!\r\n");
        AppUtils_printf( ADC_APP_NAME ": One Shot AdcGroup Notifiation count is : %d :)!!!\n\r",
                                  NotificationCount[AdcConf_AdcHwUnit_AdcHwUnit_1_AdcGroup_AdcGroup_5]);
        /* Note: Stop not required as read group API we are calling from
             * ISR callback will move state to idle automatically */
        Adc_DisableGroupNotification(AdcConf_AdcHwUnit_AdcHwUnit_1_AdcGroup_AdcGroup_5);
        /* Start Conversion for ADC module. */
        Adc_StopGroupConversion(AdcConf_AdcHwUnit_AdcHwUnit_1_AdcGroup_AdcGroup_5);
        NotificationCount[AdcConf_AdcHwUnit_AdcHwUnit_1_AdcGroup_AdcGroup_5] = 0;
        return;
        uint16 mss_uart_tx_pin, mss_uart_rx_pin;
        uint32 sys_clk_freq_vclk_const;
        /* MCU PLL Config */
        gAdcAppMcuConfig.Mcu_PllConfig = McuModuleConfiguration.Mcu_PllConfig;
        gAdcAppMcuConfig.Mcu_PllSourceId = McuModuleConfiguration.Mcu_PllSourceId;
    #endif
        Mcu_Init(&McuModuleConfiguration);
        Port_Init(&PortConfigSet_0);
        mss_uart_tx_pin = 13;
        mss_uart_rx_pin = 14;
        Port_SetPinMode(mss_uart_tx_pin, PORT_PIN_MODE_LIN0);
        /* Set up the pinmux for UART rx */
        Port_SetPinMode(mss_uart_rx_pin, PORT_PIN_MODE_LIN0);
        Port_SetPinDirection(mss_uart_rx_pin, PORT_PIN_IN);
        if(McuModuleConfiguration.Mcu_PllSourceId == MCU_CLKSRC_DPLL)
            sys_clk_freq_vclk_const = (McuModuleConfiguration.
            Mcu_PllConfig[MCU_CLKSRC_DPLL].Mcu_PllClk1.MCU_PLL_HSDIV2 / (2e6)) * 30;
        else
            Mcu_PllConfig[MCU_CLKSRC_APLL].Mcu_PllClk1.MCU_PLL_HSDIV0 / (2e6)) * 30;
        Enable_Uart();
        #else
        Enable_Uart();
        #endif
        return;
        Vim_IntCfg intCfg;
        intCfg.map = VIM_INTTYPE_IRQ;
        intCfg.type = VIM_INTTRIGTYPE_PULSE;
        intCfg.intNum = ADC_CORE0_CONTROLSS_INTRXBAR0_OUT_2;
        intCfg.handler = Adc_ADCINT1_IrqUnit0;
        intCfg.priority = VIM_PRIORITY_15;
        vimRegisterInterrupt(&intCfg);
        intCfg.intNum = ADC_CORE0_CONTROLSS_INTRXBAR0_OUT_3;
        intCfg.handler = Adc_ADCINT2_IrqUnit0;
        intCfg.priority = VIM_PRIORITY_14;
        intCfg.handler = Adc_ADCINT3_IrqUnit0;
        intCfg.priority = VIM_PRIORITY_13;
        /*intCfg.intNum = ADC_CORE0_CONTROLSS_INTRXBAR0_OUT_4;
        intCfg.handler = Adc_ADCINT4_IrqUnit1;
        intCfg.priority = VIM_PRIORITY_12;
        intCfg.intNum = 72;
        intCfg.handler = Adc_DMA_IrqChannel;
        intCfg.priority = VIM_PRIORITY_4;
    #endif
        vimInit();
        AdcApp_interruptConfig();
    void Dem_ReportErrorStatus(Dem_EventIdType     eventId,
                               Dem_EventStatusType eventStatus)
        if (DEM_EVENT_STATUS_FAILED == eventStatus)
            assert(FALSE);
        NotificationCount[ADC_GROUP_ID_0]++;
        AppUtils_printf( ADC_APP_NAME ": Group 0 Channel 0 Conversion Completed. Notification count is  %d :)!!!\n\r", NotificationCount[ADC_GROUP_ID_0]);
        AppUtils_printf( ADC_APP_NAME ": Digital Value for input volatge %dmv is %d:)!!!\n\r", AppUtils_GetAdcVoltage(Adc_AppBuffer[ADC_GROUP_ID_0][0U]), Adc_AppBuffer[ADC_GROUP_ID_0][0U]);
        AdcApp_Notification(ADC_GROUP_ID_0);
        NotificationCount[ADC_GROUP_ID_1]++;
        AppUtils_printf( ADC_APP_NAME ": Group 1 Channel 0 Conversion Completed. Notification count is  %d :)!!!\n\r", NotificationCount[ADC_GROUP_ID_1]);
        AppUtils_printf( ADC_APP_NAME ": Digital Value for input volatge %dmv is %d:)!!!\n\r", AppUtils_GetAdcVoltage(Adc_AppBuffer[ADC_GROUP_ID_1][0U]), Adc_AppBuffer[ADC_GROUP_ID_1][0U]);
    	AdcApp_Notification(ADC_GROUP_ID_1);
        /* Check the Notification. */
        if(NotificationCount[ADC_GROUP_ID_1] == 100)
           Adc_StopGroupConversion(AdcConf_AdcHwUnit_AdcHwUnit_0_AdcGroup_AdcGroup_1);
        NotificationCount[ADC_GROUP_ID_2]++;
        AppUtils_printf( ADC_APP_NAME ": Group 2 Channel 0 , 1, 2 Conversion Completed. Notification count is  %d :)!!!\n\r", NotificationCount[ADC_GROUP_ID_2]);
        AppUtils_printf( ADC_APP_NAME ": Digital Value for input volatge %dmv is %d:)!!!\n\r", AppUtils_GetAdcVoltage(Adc_AppBuffer[ADC_GROUP_ID_2][0U]), Adc_AppBuffer[ADC_GROUP_ID_2][0U]);
    	AdcApp_Notification(ADC_GROUP_ID_2);
        NotificationCount[ADC_GROUP_ID_3]++;
        AppUtils_printf( ADC_APP_NAME ": Group 1 Channel 0 Conversion Completed. Notification count is  %d :)!!!\n\r", NotificationCount[ADC_GROUP_ID_3]);
        AppUtils_printf( ADC_APP_NAME ": Digital Value for input volatge %dmv is %d:)!!!\n\r", AppUtils_GetAdcVoltage(Adc_AppBuffer[ADC_GROUP_ID_3][0U]), Adc_AppBuffer[ADC_GROUP_ID_3][0U]);
        AdcApp_Notification(ADC_GROUP_ID_3);
        NotificationCount[ADC_GROUP_ID_5]++;
        AppUtils_printf( ADC_APP_NAME ": Group 1 Channel 0 Conversion Completed. Notification count is  %d :)!!!\n\r", NotificationCount[ADC_GROUP_ID_5]);
        AppUtils_printf( ADC_APP_NAME ": Digital Value for input volatge %dmv is %d:)!!!\n\r", AppUtils_GetAdcVoltage(Adc_AppBuffer[ADC_GROUP_ID_5][0U]), Adc_AppBuffer[ADC_GROUP_ID_5][0U]);
        AdcApp_Notification(ADC_GROUP_ID_5);
        /* Indication as all Groups are completed. */
        Adc_AppGroupDone[grpIdx] = TRUE;
        return;
    /*                          Function Definitions  to Initialize the ADC Module.                   */
        uint32            baseAddr;
        volatile uint32  *kickAddr;
        if(partition==TOP_CTRL_PARTITION0)
            /*Lock TOP_CTRL*/
            baseAddr = (uint32) CSL_TOP_CTRL_U_BASE;
            kickAddr = (volatile uint32 *) (baseAddr + CSL_TOP_CTRL_LOCK0_KICK0);
            HW_WR_REG32(kickAddr, TEST_KICK_LOCK_VAL);      /* KICK 0 */
            kickAddr = (volatile uint32 *) (baseAddr + CSL_TOP_CTRL_LOCK0_KICK1);
            HW_WR_REG32(kickAddr, TEST_KICK_LOCK_VAL);      /* KICK 1 */
        if(partition==CONTROLSS_CTRL_PARTITION0)
            /*Lock CONTROLSS_CTRL*/
            baseAddr = (uint32) CSL_CONTROLSS_CTRL_U_BASE;
            kickAddr = (volatile uint32 *) (baseAddr + CSL_CONTROLSS_CTRL_LOCK0_KICK0);
            kickAddr = (volatile uint32 *) (baseAddr + CSL_CONTROLSS_CTRL_LOCK0_KICK1);
        return;
        return;
        uint32            baseAddr;
            /*Unlock TOP_CTRL*/
            HW_WR_REG32(kickAddr, TEST_KICK0_UNLOCK_VAL);      /* KICK 0 */
            HW_WR_REG32(kickAddr, TEST_KICK1_UNLOCK_VAL);      /* KICK 1 */
            /*Unlock CONTROLSS_CTRL*/
        return;
        if(epwmInstance < CSL_ETPWM_PER_CNT)
            /* Time base clock enable register belongs to partition 1 of the CTRL MMR */
            /* Unlock CONTROLSS_CTRL registers */
            SOC_controlModuleUnlockMMR(0, CONTROLSS_CTRL_PARTITION0);
            if(TRUE == enable)
                /* Enable Time base clock in CTRL MMR */
                HW_WR_REG32(CSL_CONTROLSS_CTRL_U_BASE + CSL_CONTROLSS_CTRL_EPWM_CLKSYNC,
                    ((HW_RD_REG32(CSL_CONTROLSS_CTRL_U_BASE +
                      CSL_CONTROLSS_CTRL_EPWM_CLKSYNC) & CSL_CONTROLSS_CTRL_EPWM_CLKSYNC_BIT_MASK) | (1 << epwmInstance)));
            else
                /* Disable Time base clock in CTRL MMR */
                      CSL_CONTROLSS_CTRL_EPWM_CLKSYNC) & CSL_CONTROLSS_CTRL_EPWM_CLKSYNC_BIT_MASK) & ~(1 << epwmInstance)));
            /* Lock CONTROLSS_CTRL registers */
            SOC_controlModuleLockMMR(0, CONTROLSS_CTRL_PARTITION0);
        uint32 baseAddr = CSL_CONTROLSS_CTRL_U_BASE + CSL_CONTROLSS_CTRL_EPWM_STATICXBAR_SEL0;
        uint32 mask, shift;
        /* Choose the correct base address depending on which ePWM instance is selected*/
        if(epwmInstance > 15)
            baseAddr = baseAddr + 0x4;
            epwmInstance = epwmInstance - 16;
        shift = (epwmInstance << 1);
        /* Create the mask to be written to register */
        mask = (0x3 << shift);
        /* Configure the group for the ePWM instance */
        HW_WR_REG32(baseAddr, (( HW_RD_REG32(baseAddr) & ~mask) | (group <<shift)));
        /* CONFIG_EPWM0 initialization */
        uint32 CONFIG_EPWM0_BASE_ADDR = 0x50000000ul;
        uint32 CONFIG_EPWM1_BASE_ADDR = 0x50001000ul;
        /* Time Base */
        EPWM_setClockPrescaler(CONFIG_EPWM0_BASE_ADDR, EPWM_CLOCK_DIVIDER_4, EPWM_HSCLOCK_DIVIDER_1);
        EPWM_setTimeBasePeriod(CONFIG_EPWM0_BASE_ADDR, 2000);
        EPWM_disableGlobalLoadRegisters(CONFIG_EPWM0_BASE_ADDR, EPWM_GL_REGISTER_TBPRD_TBPRDHR);
        EPWM_setPeriodLoadMode(CONFIG_EPWM0_BASE_ADDR, EPWM_PERIOD_SHADOW_LOAD);
        EPWM_setTimeBaseCounter(CONFIG_EPWM0_BASE_ADDR, 0);
        EPWM_setTimeBaseCounterMode(CONFIG_EPWM0_BASE_ADDR, EPWM_COUNTER_MODE_STOP_FREEZE);
        EPWM_setCountModeAfterSync(CONFIG_EPWM0_BASE_ADDR, EPWM_COUNT_MODE_DOWN_AFTER_SYNC);
        EPWM_disablePhaseShiftLoad(CONFIG_EPWM0_BASE_ADDR);
        EPWM_setPhaseShift(CONFIG_EPWM0_BASE_ADDR, 0);
        EPWM_enableSyncOutPulseSource(CONFIG_EPWM0_BASE_ADDR, 0);
        EPWM_setSyncInPulseSource(CONFIG_EPWM0_BASE_ADDR, EPWM_SYNC_IN_PULSE_SRC_DISABLE);
        EPWM_setOneShotSyncOutTrigger(CONFIG_EPWM0_BASE_ADDR, EPWM_OSHT_SYNC_OUT_TRIG_SYNC);
        EPWM_setClockPrescaler(CONFIG_EPWM1_BASE_ADDR, EPWM_CLOCK_DIVIDER_4, EPWM_HSCLOCK_DIVIDER_1);
        EPWM_setTimeBasePeriod(CONFIG_EPWM1_BASE_ADDR, 2000);
        EPWM_disableGlobalLoadRegisters(CONFIG_EPWM1_BASE_ADDR, EPWM_GL_REGISTER_TBPRD_TBPRDHR);
        EPWM_setPeriodLoadMode(CONFIG_EPWM1_BASE_ADDR, EPWM_PERIOD_SHADOW_LOAD);
        EPWM_setTimeBaseCounter(CONFIG_EPWM1_BASE_ADDR, 0);
        EPWM_setTimeBaseCounterMode(CONFIG_EPWM1_BASE_ADDR, EPWM_COUNTER_MODE_STOP_FREEZE);
        EPWM_setCountModeAfterSync(CONFIG_EPWM1_BASE_ADDR, EPWM_COUNT_MODE_DOWN_AFTER_SYNC);
        EPWM_disablePhaseShiftLoad(CONFIG_EPWM1_BASE_ADDR);
        EPWM_setPhaseShift(CONFIG_EPWM1_BASE_ADDR, 0);
        EPWM_enableSyncOutPulseSource(CONFIG_EPWM1_BASE_ADDR, 0);
        EPWM_setSyncInPulseSource(CONFIG_EPWM1_BASE_ADDR, EPWM_SYNC_IN_PULSE_SRC_DISABLE);
        EPWM_setOneShotSyncOutTrigger(CONFIG_EPWM1_BASE_ADDR, EPWM_OSHT_SYNC_OUT_TRIG_SYNC);
        /* Counter Compare */
        EPWM_setCounterCompareValue(CONFIG_EPWM0_BASE_ADDR, EPWM_COUNTER_COMPARE_A, 1000);
        EPWM_disableGlobalLoadRegisters(CONFIG_EPWM0_BASE_ADDR, EPWM_GL_REGISTER_CMPA_CMPAHR);
        EPWM_setCounterCompareValue(CONFIG_EPWM1_BASE_ADDR, EPWM_COUNTER_COMPARE_A, 1000);
        EPWM_disableGlobalLoadRegisters(CONFIG_EPWM1_BASE_ADDR, EPWM_GL_REGISTER_CMPA_CMPAHR);
        EPWM_setCounterCompareShadowLoadMode(CONFIG_EPWM1_BASE_ADDR, EPWM_COUNTER_COMPARE_A, EPWM_COMP_LOAD_ON_CNTR_ZERO);
        EPWM_setCounterCompareShadowLoadMode(CONFIG_EPWM0_BASE_ADDR, EPWM_COUNTER_COMPARE_A, EPWM_COMP_LOAD_ON_CNTR_ZERO);
        EPWM_setCounterCompareValue(CONFIG_EPWM0_BASE_ADDR, EPWM_COUNTER_COMPARE_B, 0);
        EPWM_disableGlobalLoadRegisters(CONFIG_EPWM0_BASE_ADDR, EPWM_GL_REGISTER_CMPB_CMPBHR);
        EPWM_setCounterCompareShadowLoadMode(CONFIG_EPWM0_BASE_ADDR, EPWM_COUNTER_COMPARE_B, EPWM_COMP_LOAD_ON_CNTR_ZERO);
        EPWM_setCounterCompareValue(CONFIG_EPWM0_BASE_ADDR, EPWM_COUNTER_COMPARE_C, 1000);
        EPWM_disableGlobalLoadRegisters(CONFIG_EPWM0_BASE_ADDR, EPWM_GL_REGISTER_CMPC);
        EPWM_setCounterCompareShadowLoadMode(CONFIG_EPWM0_BASE_ADDR, EPWM_COUNTER_COMPARE_C, EPWM_COMP_LOAD_ON_CNTR_ZERO);
        EPWM_setCounterCompareValue(CONFIG_EPWM0_BASE_ADDR, EPWM_COUNTER_COMPARE_D, 0);
        EPWM_disableGlobalLoadRegisters(CONFIG_EPWM0_BASE_ADDR, EPWM_GL_REGISTER_CMPD);
        EPWM_setCounterCompareShadowLoadMode(CONFIG_EPWM0_BASE_ADDR, EPWM_COUNTER_COMPARE_D, EPWM_COMP_LOAD_ON_CNTR_ZERO);
        /* Action Qualifier */
        EPWM_disableGlobalLoadRegisters(CONFIG_EPWM0_BASE_ADDR, EPWM_GL_REGISTER_AQCSFRC);
        EPWM_setActionQualifierContSWForceShadowMode(CONFIG_EPWM0_BASE_ADDR, EPWM_AQ_SW_SH_LOAD_ON_CNTR_ZERO);
        EPWM_disableGlobalLoadRegisters(CONFIG_EPWM0_BASE_ADDR, EPWM_GL_REGISTER_AQCTLA_AQCTLA2);
        EPWM_disableActionQualifierShadowLoadMode(CONFIG_EPWM0_BASE_ADDR, EPWM_ACTION_QUALIFIER_A);
        EPWM_setActionQualifierShadowLoadMode(CONFIG_EPWM0_BASE_ADDR, EPWM_ACTION_QUALIFIER_A, EPWM_AQ_LOAD_ON_CNTR_ZERO);
        EPWM_setActionQualifierT1TriggerSource(CONFIG_EPWM0_BASE_ADDR, EPWM_AQ_TRIGGER_EVENT_TRIG_DCA_1);
        EPWM_setActionQualifierT2TriggerSource(CONFIG_EPWM0_BASE_ADDR, EPWM_AQ_TRIGGER_EVENT_TRIG_DCA_1);
        EPWM_setActionQualifierSWAction(CONFIG_EPWM0_BASE_ADDR, EPWM_AQ_OUTPUT_A, EPWM_AQ_OUTPUT_NO_CHANGE);
        EPWM_setActionQualifierContSWForceAction(CONFIG_EPWM0_BASE_ADDR, EPWM_AQ_OUTPUT_A, EPWM_AQ_SW_DISABLED);
        EPWM_disableGlobalLoadRegisters(CONFIG_EPWM0_BASE_ADDR, EPWM_GL_REGISTER_AQCTLB_AQCTLB2);
        EPWM_disableActionQualifierShadowLoadMode(CONFIG_EPWM0_BASE_ADDR, EPWM_ACTION_QUALIFIER_B);
        EPWM_setActionQualifierShadowLoadMode(CONFIG_EPWM0_BASE_ADDR, EPWM_ACTION_QUALIFIER_B, EPWM_AQ_LOAD_ON_CNTR_ZERO);
        EPWM_setActionQualifierSWAction(CONFIG_EPWM0_BASE_ADDR, EPWM_AQ_OUTPUT_B, EPWM_AQ_OUTPUT_NO_CHANGE);
        EPWM_setActionQualifierContSWForceAction(CONFIG_EPWM0_BASE_ADDR, EPWM_AQ_OUTPUT_B, EPWM_AQ_SW_DISABLED);
        /* Events */
        EPWM_setActionQualifierAction(CONFIG_EPWM0_BASE_ADDR, EPWM_AQ_OUTPUT_A, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_TIMEBASE_ZERO);
        EPWM_setActionQualifierAction(CONFIG_EPWM0_BASE_ADDR, EPWM_AQ_OUTPUT_A, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_TIMEBASE_PERIOD);
        EPWM_setActionQualifierAction(CONFIG_EPWM0_BASE_ADDR, EPWM_AQ_OUTPUT_A, EPWM_AQ_OUTPUT_HIGH, EPWM_AQ_OUTPUT_ON_TIMEBASE_UP_CMPA);
        EPWM_setActionQualifierAction(CONFIG_EPWM0_BASE_ADDR, EPWM_AQ_OUTPUT_A, EPWM_AQ_OUTPUT_LOW, EPWM_AQ_OUTPUT_ON_TIMEBASE_DOWN_CMPA);
        EPWM_setActionQualifierAction(CONFIG_EPWM0_BASE_ADDR, EPWM_AQ_OUTPUT_A, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_TIMEBASE_UP_CMPB);
        EPWM_setActionQualifierAction(CONFIG_EPWM0_BASE_ADDR, EPWM_AQ_OUTPUT_A, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_TIMEBASE_DOWN_CMPB);
        EPWM_setActionQualifierAction(CONFIG_EPWM0_BASE_ADDR, EPWM_AQ_OUTPUT_A, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_T1_COUNT_UP);
        EPWM_setActionQualifierAction(CONFIG_EPWM0_BASE_ADDR, EPWM_AQ_OUTPUT_A, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_T1_COUNT_DOWN);
        EPWM_setActionQualifierAction(CONFIG_EPWM0_BASE_ADDR, EPWM_AQ_OUTPUT_A, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_T2_COUNT_UP);
        EPWM_setActionQualifierAction(CONFIG_EPWM0_BASE_ADDR, EPWM_AQ_OUTPUT_A, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_T2_COUNT_DOWN);
        EPWM_setActionQualifierAction(CONFIG_EPWM0_BASE_ADDR, EPWM_AQ_OUTPUT_B, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_TIMEBASE_ZERO);
        EPWM_setActionQualifierAction(CONFIG_EPWM0_BASE_ADDR, EPWM_AQ_OUTPUT_B, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_TIMEBASE_PERIOD);
        EPWM_setActionQualifierAction(CONFIG_EPWM0_BASE_ADDR, EPWM_AQ_OUTPUT_B, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_TIMEBASE_UP_CMPA);
        EPWM_setActionQualifierAction(CONFIG_EPWM0_BASE_ADDR, EPWM_AQ_OUTPUT_B, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_TIMEBASE_DOWN_CMPA);
        EPWM_setActionQualifierAction(CONFIG_EPWM0_BASE_ADDR, EPWM_AQ_OUTPUT_B, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_TIMEBASE_UP_CMPB);
        EPWM_setActionQualifierAction(CONFIG_EPWM0_BASE_ADDR, EPWM_AQ_OUTPUT_B, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_TIMEBASE_DOWN_CMPB);
        EPWM_setActionQualifierAction(CONFIG_EPWM0_BASE_ADDR, EPWM_AQ_OUTPUT_B, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_T1_COUNT_UP);
        EPWM_setActionQualifierAction(CONFIG_EPWM0_BASE_ADDR, EPWM_AQ_OUTPUT_B, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_T1_COUNT_DOWN);
        EPWM_setActionQualifierAction(CONFIG_EPWM0_BASE_ADDR, EPWM_AQ_OUTPUT_B, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_T2_COUNT_UP);
        EPWM_setActionQualifierAction(CONFIG_EPWM0_BASE_ADDR, EPWM_AQ_OUTPUT_B, EPWM_AQ_OUTPUT_NO_CHANGE, EPWM_AQ_OUTPUT_ON_T2_COUNT_DOWN);
        /* Event Trigger */
        EPWM_disableInterrupt(CONFIG_EPWM0_BASE_ADDR);
        EPWM_setInterruptSource(CONFIG_EPWM0_BASE_ADDR, EPWM_INT_TBCTR_ZERO, EPWM_INT_TBCTR_ZERO);
        EPWM_setInterruptEventCount(CONFIG_EPWM0_BASE_ADDR, 0);
        EPWM_disableInterruptEventCountInit(CONFIG_EPWM0_BASE_ADDR);
        EPWM_setInterruptEventCountInitValue(CONFIG_EPWM0_BASE_ADDR, 0);
        EPWM_enableADCTrigger(CONFIG_EPWM0_BASE_ADDR, EPWM_SOC_A);
        EPWM_setADCTriggerSource(CONFIG_EPWM0_BASE_ADDR, EPWM_SOC_A, EPWM_SOC_TBCTR_U_CMPA, EPWM_SOC_TBCTR_U_CMPA);
        EPWM_setADCTriggerEventPrescale(CONFIG_EPWM0_BASE_ADDR, EPWM_SOC_A, 1);
        EPWM_disableADCTriggerEventCountInit(CONFIG_EPWM0_BASE_ADDR, EPWM_SOC_A);
        EPWM_setADCTriggerEventCountInitValue(CONFIG_EPWM0_BASE_ADDR, EPWM_SOC_A, 0);
        EPWM_enableADCTrigger(CONFIG_EPWM0_BASE_ADDR, EPWM_SOC_B);//ETSEL:SOCBEN
        EPWM_setADCTriggerSource(CONFIG_EPWM0_BASE_ADDR, EPWM_SOC_B, EPWM_SOC_TBCTR_U_CMPC, EPWM_SOC_TBCTR_U_CMPA); //ETSEL:SOCBSEL/SOCBSELCMP
        EPWM_enableADCTrigger(CONFIG_EPWM1_BASE_ADDR, EPWM_SOC_A);
        EPWM_setADCTriggerSource(CONFIG_EPWM1_BASE_ADDR, EPWM_SOC_A, EPWM_SOC_TBCTR_U_CMPA, EPWM_SOC_TBCTR_U_CMPA);
        EPWM_setADCTriggerEventPrescale(CONFIG_EPWM1_BASE_ADDR, EPWM_SOC_A, 1);
        EPWM_disableADCTriggerEventCountInit(CONFIG_EPWM1_BASE_ADDR, EPWM_SOC_A);
        EPWM_setADCTriggerEventCountInitValue(CONFIG_EPWM1_BASE_ADDR, EPWM_SOC_A, 0);
        //EPWM_disableADCTrigger(CONFIG_EPWM0_BASE_ADDR, EPWM_SOC_B);
        //EPWM_setADCTriggerSource(CONFIG_EPWM0_BASE_ADDR, EPWM_SOC_B, EPWM_SOC_DCxEVT1, EPWM_SOC_DCxEVT1);
        EPWM_setADCTriggerEventPrescale(CONFIG_EPWM0_BASE_ADDR, EPWM_SOC_B, 1);
        EPWM_disableADCTriggerEventCountInit(CONFIG_EPWM0_BASE_ADDR, EPWM_SOC_B);
        EPWM_setADCTriggerEventCountInitValue(CONFIG_EPWM0_BASE_ADDR, EPWM_SOC_B, 0);
        /* Global Load */
        EPWM_disableGlobalLoad(CONFIG_EPWM0_BASE_ADDR);
        EPWM_setGlobalLoadTrigger(CONFIG_EPWM0_BASE_ADDR, EPWM_GL_LOAD_PULSE_CNTR_ZERO);
        EPWM_setGlobalLoadEventPrescale(CONFIG_EPWM0_BASE_ADDR, 0);
        EPWM_disableGlobalLoadOneShotMode(CONFIG_EPWM0_BASE_ADDR);
        /* EPWM Module */
        EPWM_lockRegisters(CONFIG_EPWM0_BASE_ADDR, 0);
        uint32 refVoltage    = 3300U;
        uint32 maxResolution = 4095U;
        return ((adcValue * refVoltage) / maxResolution);
    /*****************************************EoF******************************************************/
    I have set up 2 more HW triggers by updating  Adc_PBCfg.c manually in the shared files for covering the below scenarios :
    • Adc Grp3 -> Triggered based on PWM0_SOCB -> Triggering XBAR 149 -> Triggering ISR Adc_ADCINT2_IrqUnit0
    • Adc Grp4 -> Triggered based on PWM1_SOCA -> Triggering XBAR 150 -> Triggering ISR Adc_ADCINT3_IrqUnit0
    In both these cases I have kept the break points at new ISRs; but the control does not reach the ISRs.
  • Hi Ashish,
    Please find the patch attached modified according to your testcase and verified.
    /cfs-file/__key/communityserver-discussions-components-files/908/Adc_5F00_Testing.zip
    Thanks And Regards,
    Sunil Kumar M S
  • Just an update wrt the HW/SW triggered ADC EoC handing of the SoC Subsystem of the ADC module as I understood from TI. Thanks for Clarifying the concept Pratik.
    It would be helpful to capture it in release notes or delivery notes of the ADC delivery; so that it would be easier to understand the MCAL design decisions; that could be helpful during debugging.
  • ADC Cat2 interrupts are getting triggered with the MCAL package 8.6.2.1, based on the above concept. Closing the ticket.
