MCU-PLUS-SDK-AM273X: build SDK demo with gmake all and get result : No rule to make target 'obj_am273x/mmwdemo_adcconfig.oer5f', needed by 'mssDemo'. Stop.
Part Number: MCU-PLUS-SDK-AM273X
hello,i install the SDK4.4.1 and want to bulid the am273x demo,first i set to the mmWave Build Environment Configured and then cd to the path "ti\mmwave_mcuplus_sdk_04_04_00_01\mmwave_mcuplus_sdk_04_04_00_01\ti\demo\am273x\mmw",i use the “gmake all”to build the demo,but get the error in cmd “No rule to make target 'obj_am273x/mmwdemo_adcconfig.oer5f', needed by 'mssDemo'.  Stop.”,i hope somebody can tell me how to build the am273x demo in correct。the error figure is as following:
    Let me try this at my end and help you in a day.
    Jitendra
    Here I have tried to build the same demo and you can see the build is successful.
    So, I'll suggest you to follow the below steps
        - Set MMWAVE_SDK_DEVICE=am273x in setenv.bat file(in mmwave_mcuplus_sdk_04_04_00_01/scripts/windows folder) and save it
        - Open command prompt, change directory to mmwave_mcuplus_sdk_04_04_00_01/scripts/windows folder
        - Run setenv.bat in the prompt
        - In the same prompt change the directory to mmwave_mcuplus_sdk_04_04_00_01/ti/demo/am273x/mmw folder
        - Run gmake clean
        - Run gmake all
    Please follow those steps and specially gmake clean
    Anirban
  • thanks a lot,by follow your steps i can build the demo with no error and i find the mistake is i get the wrong profile in setenv.bat .
