[FAQ] How to assert breakpoints before the main() function in CCS
I want to add breakpoints before the main() function as currently the program automatically runs to main and breakpoints in the startup code before main don’t work. How can I configure my projects to not run to main and stop at any breakpoint added before that?
    To do this via CCS:
    • Select the project that you want to put a breakpoint before main() on
    • Go-to Project in the menu bar
    • Select Properties
    • Go-to Debug -> Auto Run and Launch Options
    • Untick “On a program load or restart”
    • Resume the Program with ‘F5’. It can be seen that the program doesn’t run to main.
      Note:  the symbols may not be linked correctly for 0x0 so single step is recommended for correct debug information
    • Now select and set a Breakpoint as shown below. Here we’ll choose the hello_world_main() function in the hello_world example.
    • The program now stops at breakpoints you set before the main() function.
    See slides 33 & 35 of the tips and tricks.
