Part Number: MCU-PLUS-SDK-AM243X
Other Parts Discussed in Thread: UNIFLASH, SYSCONFIG
Hello.
OSPI Multi-Partition bootloader does not succeed. Could you please tell me what is the cause?
Operating environment:
AM243x MCU+SDK 09.02.01.05
Reference documents:
SBL OSPI Multi-Partition
software-dl.ti.com/.../EXAMPLES_DRIVERS_SBL_OSPI_MULTI_PARTITION.html
phenomenon:
Bootloader_parseMultiCoreAppImage() fails.
SBL build:
1. Import sample code SBL OSPI Multi-Partition
2. Turn on the "Enable PHY Mode" checkbox for OSPI in example.syscfg
3. Build execution (add DebugP_log() for debugging)
4. python uart_uniflash.py -p COM4 --cfg=<installation folder>/custom_sbl_ospi_multi_partition.cfg
After Bootloader_parseMultiCoreAppImage() fails, the following message is displayed:
"Some tests have failed!!"
In addition,
Turning on the OSPI "Enable DMA" checkbox does not improve the problem.
If the OSPI "Enable PHY Mode" checkbox is OFF (if 2. is not executed), Bootloader_parseMultiCoreAppImage() will freeze.
