Part Number: MCU-PLUS-SDK-AM273X
Is there a way to prevent from rebuilding when a Debug session is started? I'm using CCS 12.7.1
Hi Kacper,
If you prefer to debug a system project (for multicore), there is no way you can avoid it. If you manually launch the target configuration, connect to individual core, load and run the program on that core, then the rebuild can be avoid.
Ming
