Part Number: LP-AM243
To test encryption/decryption, I created a new SMEK using "gen_keywr_cert.sh -g".
I used that SMEK to build "hello_world" and created "hello_world_am243x-lp_r5fss0-0_freertos_ti-arm-clang.appimage.hs".
I wanted to start the created appimage with SBL UART and check that the appimage failed to start, but an error occurred while running "uart_bootloader.py".
I was expecting an error in the bootloader, but is this the correct process?
Did I do something wrong?
1. Create a key to make decryption fail
2. Convert smek.key to smek.txt
xxd -p -c 10000 smek.key | tr -d $'\n' > smek.txt
3. Edit devconfig.mk
#CUST_MEK=$(SIGNING_TOOL_PATH)/custMek_am64x_am243x.txt
CUST_MEK=$(SIGNING_TOOL_PATH)/smek.txt
4. Build hello_world
5. Boot with SBL UART
C:\ti\mcu_plus_sdk_am243x_09_02_01_05\tools\boot>python uart_bootloader.py -p COM4 --bootloader=../../../../Users/hasinoguti/workspace_v12/sbl_uart_am243x-lp_r5fss0-0_nortos_ti-arm-clang/sbl_uart.Debug.hs.tiimage --file=../../../../Users/hasinoguti/workspace_v12/hello_world_am243x-lp_r5fss0-0_freertos_ti-arm-clang/Debug/hello_world_am243x-lp_r5fss0-0_freertos_ti-arm-clang.appimage.hs
Sending the UART bootloader ../../../../Users/hasinoguti/workspace_v12/sbl_uart_am243x-lp_r5fss0-0_nortos_ti-arm-clang/sbl_uart.Debug.hs.tiimage ...
Sent bootloader ../../../../Users/hasinoguti/workspace_v12/sbl_uart_am243x-lp_r5fss0-0_nortos_ti-arm-clang/sbl_uart.Debug.hs.tiimage of size 330996 bytes in 31.0667002s.
Sending the application ../../../../Users/hasinoguti/workspace_v12/hello_world_am243x-lp_r5fss0-0_freertos_ti-arm-clang/Debug/hello_world_am243x-lp_r5fss0-0_freertos_ti-arm-clang.appimage.hs ...
Sending ../../../../Users/hasinoguti/workspace_v12/hello_world_am243x-lp_r5fss0-0_freertos_ti-arm-clang/Debug/hello_world_am243x-lp_r5fss0-0_freertos_ti-arm-clang.apSending
Sent application ../../../../Users/hasinoguti/workspace_v12/hello_world_am243x-lp_r5fss0-0_freertos_ti-arm-clang/Debug/hello_world_am243x-lp_r5fss0-0_freertos_ti-arm-clang.appimage.hs of size 104372 bytes in 10.8174202s.
[STATUS] ERROR: Application load FAILED !!!
Yukinobu
