Part Number: MSPM0G1507
Other Parts Discussed in Thread: SYSCONFIG,
Whenever I flash the firmware, I have to invoke the BSL by performing a Power-On Reset (POR), which involves shorting the BSL PA18 pin to VCC before powering up the device. However, I use JLink for flashing, which operates via the SWDIO and SWDCLK pins.
Based on the information provided in the datasheet and user manual, BSL is typically required only when programming via UART or I2C. I am not using either of these interfaces for programming; instead, I rely solely on JLink( SWDIO, SWDCLK, NRST and VCC and GND pins).
