I am trying to insert a double bit error and expecting a DATA ABORT. I followed the below steps to introduce the double bit error.
1. Disable ECC in CPU
2. Disable ECC in RAM WRAPPER Congtrol Register
3. Set ECC Write Enable in control register.
4. Added 3 to the ECC value.
5. Enable ECC in RAM WRAPPER & Disable ECC Write Enable.
6. Enable ECC in CPU.
I did not observe the DATA Abort.
Please let me know that Is this the correct way to test or not.
Thanks & Regards
Krishna B
Hi Krishna,
Can you please confirm that you subsequently create a data access to the SRAM area you have modified? This may be obvious, but it is necessary to generate a memory access to the affected area for the ECC to be evaluated.
Karl
When i read back the ECC then i observed the DATA ABORT. I followed the below steps.
4. Changed the ECC value from 0x0C0C0C0C to 0x0A0A0A0A .
7. Read the ECC then observed the DATA ABORT.
Note: I am working on TCRAM.
