I want to interface 2 gb SD card using SPI2 with TMS570LC4357 Hercules board so i generated SPI2 driver from Halcogen application but it is not working at all there is no output and how to configure field CSNR in SPIDAT1 register to make chip selection.
Other Parts Discussed in Thread: HALCOGEN
here is my code
/** @file spi.c
*   @brief SPI Driver Implementation File
*   @date 02-Mar-2016
*   @version 04.05.02
* Copyright (C) 2009-2016 Texas Instruments Incorporated - www.ti.com
*  Redistribution and use in source and binary forms, with or without
*  modification, are permitted provided that the following conditions
*  are met:
*    Redistributions of source code must retain the above copyright
*    notice, this list of conditions and the following disclaimer.
*    Redistributions in binary form must reproduce the above copyright
*    notice, this list of conditions and the following disclaimer in the
*    documentation and/or other materials provided with the
*    distribution.
*    Neither the name of Texas Instruments Incorporated nor the names of
*    its contributors may be used to endorse or promote products derived
*    from this software without specific prior written permission.
*  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
*  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
*  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
*  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
*  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
*  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
*  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
*  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
*  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
*  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
*  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/* USER CODE BEGIN (0) */
/* USER CODE END */
#include "HL_spi.h"
#include "HL_sys_vim.h"
/* USER CODE BEGIN (1) */
/* USER CODE END */
/** @struct g_spiPacket
*   @brief globals
static volatile struct g_spiPacket
    spiDAT1_t g_spiDataFormat;
    uint32  tx_length;
    uint32  rx_length;
    uint16  * txdata_ptr;
    uint16  * rxdata_ptr;
    SpiDataStatus_t tx_data_status;
    SpiDataStatus_t rx_data_status;
} g_spiPacket_t[5U];
/** @fn void spiInit(void)
*   @brief Initializes the SPI Driver
*   This function initializes the SPI module.
/* SourceId : SPI_SourceId_001 */
/* DesignId : SPI_DesignId_001 */
/* Requirements : HL_SR126 */
void spiInit(void)
/* USER CODE BEGIN (2) */
/* USER CODE END */
    /** @b initialize @b SPI2 */
    /** bring SPI out of reset */
    spiREG2->GCR0 = 0U;
    spiREG2->GCR0 = 1U;
    /** SPI2 master mode and clock configuration */
    spiREG2->GCR1 = (spiREG2->GCR1 & 0xFFFFFFFCU) | ((uint32)((uint32)1U << 1U)  /* CLOKMOD */
                  | 1U << 0U);  /* MASTER */
    /** SPI2 enable pin configuration */
    spiREG2->INT0 = (spiREG2->INT0 & 0xFEFFFFFFU)| (uint32)((uint32)0U << 24U);  /* ENABLE HIGHZ */
    /** - Delays */
    spiREG2->DELAY = (uint32)((uint32)50U << 24U)  /* C2TDELAY */
                   | (uint32)((uint32)50U << 16U)  /* T2CDELAY */
                   | (uint32)((uint32)10U << 8U)   /* T2EDELAY */
                   | (uint32)((uint32)50U << 0U);  /* C2EDELAY */
    /** - Data Format 0 */
    spiREG2->FMT0 = (uint32)((uint32)0U << 24U)  /* wdelay */
                  | (uint32)((uint32)0U << 23U)  /* parity Polarity */
                  | (uint32)((uint32)0U << 22U)  /* parity enable */
                  | (uint32)((uint32)0U << 21U)  /* wait on enable */
                  | (uint32)((uint32)0U << 20U)  /* shift direction */
                  | (uint32)((uint32)0U << 17U)  /* clock polarity */
                  | (uint32)((uint32)0U << 16U)  /* clock phase */
                  | (uint32)((uint32)74U << 8U) /* baudrate prescale */
                  | (uint32)((uint32)16U << 0U);  /* data word length */
    /** - Data Format 1 */
    spiREG2->FMT1 = (uint32)((uint32)0U << 24U)  /* wdelay */
    /** - Data Format 2 */
    spiREG2->FMT2 = (uint32)((uint32)0U << 24U)  /* wdelay */
    /** - Data Format 3 */
    spiREG2->FMT3 = (uint32)((uint32)0U << 24U)  /* wdelay */
    /** - set interrupt levels */
    spiREG2->LVL = (uint32)((uint32)0U << 9U)  /* TXINT */
                 | (uint32)((uint32)0U << 8U)  /* RXINT */
                 | (uint32)((uint32)0U << 6U)  /* OVRNINT */
                 | (uint32)((uint32)0U << 4U)  /* BITERR */
                 | (uint32)((uint32)0U << 3U)  /* DESYNC */
                 | (uint32)((uint32)0U << 2U)  /* PARERR */
                 | (uint32)((uint32)0U << 1U) /* TIMEOUT */
                 | (uint32)((uint32)0U << 0U);  /* DLENERR */
    /** - clear any pending interrupts */
    spiREG2->FLG |= 0xFFFFU;
    /** - enable interrupts */
    spiREG2->INT0 = (spiREG2->INT0 & 0xFFFF0000U)
                  | (uint32)((uint32)0U << 9U)  /* TXINT */
    /** @b initialize @b SPI2 @b Port */
    /** - SPI2 Port output values */
    spiREG2->PC3 =    (uint32)((uint32)1U << 0U)  /* SCS[0] */
                    | (uint32)((uint32)1U << 1U)  /* SCS[1] */
                    | (uint32)((uint32)0U << 8U)  /* ENA */
                    | (uint32)((uint32)0U << 9U)  /* CLK */
                    | (uint32)((uint32)0U << 10U)  /* SIMO */
                    | (uint32)((uint32)0U << 11U); /* SOMI */
    /** - SPI2 Port direction */
    spiREG2->PC1  =   (uint32)((uint32)1U << 0U)  /* SCS[0] */
                    | (uint32)((uint32)1U << 9U)  /* CLK */
                    | (uint32)((uint32)1U << 10U)  /* SIMO */
    /** - SPI2 Port open drain enable */
    spiREG2->PC6  =   (uint32)((uint32)0U << 0U)  /* SCS[0] */
                    | (uint32)((uint32)0U << 1U)  /* SCS[1] */
    /** - SPI2 Port pullup / pulldown enable*/
    spiREG2->PC7  =   (uint32)((uint32)0U << 0U)  /* SCS[0] */
    /** - SPI2 Port pullup / pulldown selection */
    spiREG2->PC8  =   (uint32)((uint32)1U << 0U)  /* SCS[0] */
                    | (uint32)((uint32)1U << 8U)  /* ENA */
                    | (uint32)((uint32)1U << 11U); /* SOMI */
    /* SPI2 set all pins to functional */
    spiREG2->PC0  =   (uint32)((uint32)1U << 0U)  /* SCS[0] */
    /** - Initialize TX and RX data buffer Status */
    g_spiPacket_t[1U].tx_data_status  = SPI_READY;
    g_spiPacket_t[1U].rx_data_status  = SPI_READY;
    /** - Finally start SPI2 */
    spiREG2->GCR1 = (spiREG2->GCR1 & 0xFEFFFFFFU) | 0x01000000U;
/* USER CODE BEGIN (3) */
/* USER CODE END */
/** @fn void spiSetFunctional(spiBASE_t *spi, uint32 port)
*   @brief Change functional behavior of pins at runtime.
*   @param[in] spi   - Spi module base address
*   @param[in] port  - Value to write to PC0 register
*   Change the value of the PC0 register at runtime, this allows to
*   dynamically change the functionality of the SPI pins between functional
*   and GIO mode.
/* SourceId : SPI_SourceId_002 */
/* DesignId : SPI_DesignId_002 */
/* Requirements : HL_SR128 */
/* USER CODE BEGIN (4) */
/* USER CODE END */
    spi->PC0 = port;
/* USER CODE BEGIN (5) */
/* USER CODE END */
/** @fn uint32 spiReceiveData(spiBASE_t *spi, spiDAT1_t *dataconfig_t, uint32 blocksize, uint16 * destbuff)
*   @brief Receives Data using polling method
*   @param[in] dataconfig_t    - Spi DAT1 register configuration
*   @param[in] blocksize    - number of data
*   @param[in] destbuff        - Pointer to the destination data (16 bit).
*   @return flag register value.
*   This function transmits blocksize number of data from source buffer using polling method.
/* SourceId : SPI_SourceId_003 */
/* DesignId : SPI_DesignId_007 */
/* Requirements : HL_SR133 */
/* USER CODE BEGIN (6) */
/* USER CODE END */
    uint32 Chip_Select_Hold = (dataconfig_t->CS_HOLD) ? 0x10000000U : 0U;
    uint32 WDelay = (dataconfig_t->WDEL) ? 0x04000000U : 0U;
    SPIDATAFMT_t DataFormat = dataconfig_t->DFSEL;
    uint8 ChipSelect = dataconfig_t->CSNR;
    while(blocksize != 0U)
        if((spi->FLG & 0x000000FFU) !=0U)
          break;
        if(blocksize == 1U)
           Chip_Select_Hold = 0U;
        /*SAFETYMCUSW 51 S MR:12.3 <APPROVED> "Needs shifting for 32-bit value" */
        spi->DAT1 = ((uint32)DataFormat << 24U) |
                    ((uint32)ChipSelect << 16U) |
                    (WDelay)            |
                    (Chip_Select_Hold)  |
                    (0x00000000U);
        /*SAFETYMCUSW 28 D MR:NA <APPROVED> "Hardware status bit read check" */
        while((spi->FLG & 0x00000100U) != 0x00000100U)
        } /* Wait */
        /*SAFETYMCUSW 45 D MR:21.1 <APPROVED> "Valid non NULL input parameters are only allowed in this driver" */
        *destbuff = (uint16)spi->BUF;
        /*SAFETYMCUSW 567 S MR:17.1,17.4 <APPROVED> "Pointer increment needed" */
        destbuff++;
        blocksize--;
/* USER CODE BEGIN (7) */
/* USER CODE END */
    return (spi->FLG & 0xFFU);
/** @fn uint32 spiGetData(spiBASE_t *spi, spiDAT1_t *dataconfig_t, uint32 blocksize, uint16 * destbuff)
*   @brief Receives Data using interrupt method
*   This function transmits blocksize number of data from source buffer using interrupt method.
/* SourceId : SPI_SourceId_004 */
/* DesignId : SPI_DesignId_008 */
/* Requirements : HL_SR134 */
void spiGetData(spiBASE_t *spi, spiDAT1_t *dataconfig_t, uint32 blocksize, uint16 * destbuff)
     uint32 index = (spi == spiREG1) ? 0U :((spi==spiREG2) ? 1U : ((spi==spiREG3) ? 2U:((spi==spiREG4) ? 3U:4U)));
/* USER CODE BEGIN (8) */
/* USER CODE END */
     g_spiPacket_t[index].rx_length = blocksize;
     g_spiPacket_t[index].rxdata_ptr   = destbuff;
     g_spiPacket_t[index].g_spiDataFormat = *dataconfig_t;
     g_spiPacket_t[index].rx_data_status = SPI_PENDING;
     spi->INT0 |= 0x0100U;
/* USER CODE BEGIN (9) */
/* USER CODE END */
/** @fn uint32 spiTransmitData(spiBASE_t *spi, spiDAT1_t *dataconfig_t, uint32 blocksize, uint16 * srcbuff)
*   @brief Transmits Data using polling method
*   @param[in] srcbuff        - Pointer to the source data ( 16 bit).
/* SourceId : SPI_SourceId_005 */
/* DesignId : SPI_DesignId_005 */
/* Requirements : HL_SR131 */
    volatile uint32 SpiBuf;
    uint16 Tx_Data;
/* USER CODE BEGIN (10) */
/* USER CODE END */
           break;
        if(blocksize == 1U)
        Tx_Data = *srcbuff;
                     (WDelay)           |
                     (uint32)Tx_Data;
        srcbuff++;
        } /* Wait */
        SpiBuf = spi->BUF;
        blocksize--;
/* USER CODE BEGIN (11) */
/* USER CODE END */
/** @fn void spiSendData(spiBASE_t *spi, spiDAT1_t *dataconfig_t, uint32 blocksize, uint16 * srcbuff)
*   @brief Transmits Data using interrupt method
/* SourceId : SPI_SourceId_006 */
/* DesignId : SPI_DesignId_006 */
/* Requirements : HL_SR132 */
/* USER CODE BEGIN (12) */
/* USER CODE END */
     g_spiPacket_t[index].tx_length = blocksize;
     g_spiPacket_t[index].txdata_ptr   = srcbuff;
     g_spiPacket_t[index].tx_data_status = SPI_PENDING;
     spi->INT0 |= 0x0200U;
/* USER CODE BEGIN (13) */
/* USER CODE END */
/** @fn uint32 spiTransmitAndReceiveData(spiBASE_t *spi, spiDAT1_t *dataconfig_t, uint32 blocksize, uint16 * srcbuff, uint16 * destbuff)
*   @brief Transmits and Receive Data using polling method
*   @param[in] destbuff        - Pointer to the destination data ( 16 bit).
*   This function transmits and receives blocksize number of data from source buffer using polling method.
/* SourceId : SPI_SourceId_007 */
/* DesignId : SPI_DesignId_009 */
/* Requirements : HL_SR135 */
    uint16 Tx_Data;
/* USER CODE BEGIN (14) */
/* USER CODE END */
        if((spi->FLG & 0x000000FFU) != 0U)
           break;
        if(blocksize == 1U)
        Tx_Data = *srcbuff;
        spi->DAT1 =((uint32)DataFormat << 24U) |
                   (WDelay)           |
                   (uint32)Tx_Data;
        srcbuff++;
        } /* Wait */
        destbuff++;
        blocksize--;
/* USER CODE BEGIN (15) */
/* USER CODE END */
/* USER CODE BEGIN (16) */
/* USER CODE END */
/** @fn void spiSendAndGetData(spiBASE_t *spi, spiDAT1_t *dataconfig_t, uint32 blocksize, uint16 * srcbuff, uint16 * destbuff)
*   @brief Initiate SPI Transmits and receive Data using Interrupt mode.
*   Initiate SPI Transmits and receive Data using Interrupt mode..
/* SourceId : SPI_SourceId_008 */
/* DesignId : SPI_DesignId_010 */
/* Requirements : HL_SR136 */
/* USER CODE BEGIN (17) */
/* USER CODE END */
    spi->INT0 |= 0x0300U;
/* USER CODE BEGIN (18) */
/* USER CODE END */
/** @fn SpiDataStatus_t SpiTxStatus(spiBASE_t *spi)
*   @brief Get the status of the SPI Transmit data block.
*   @return Spi Transmit block data status.
*   Get the status of the SPI Transmit data block.
/* SourceId : SPI_SourceId_009 */
/* DesignId : SPI_DesignId_013 */
/* Requirements : HL_SR139 */
/* USER CODE BEGIN (19) */
/* USER CODE END */
    return(g_spiPacket_t[index].tx_data_status);
/* USER CODE BEGIN (20) */
/* USER CODE END */
/** @fn SpiDataStatus_t SpiRxStatus(spiBASE_t *spi)
*   @brief Get the status of the SPI Receive data block.
*   @return Spi Receive block data status.
*   Get the status of the SPI Receive data block.
/* SourceId : SPI_SourceId_010 */
/* DesignId : SPI_DesignId_014 */
/* Requirements : HL_SR140 */
/* USER CODE BEGIN (21) */
/* USER CODE END */
    return(g_spiPacket_t[index].rx_data_status);
/* USER CODE BEGIN (22) */
/* USER CODE END */
/** @fn void spiEnableLoopback(spiBASE_t *spi, loopBackType_t Loopbacktype)
*   @brief Enable Loopback mode for self test
*   @param[in] spi        - spi module base address
*   @param[in] Loopbacktype  - Digital or Analog
*   This function enables the Loopback mode for self test.
/* SourceId : SPI_SourceId_011 */
/* DesignId : SPI_DesignId_011 */
/* Requirements : HL_SR137 */
/* USER CODE BEGIN (23) */
/* USER CODE END */
    /* Clear Loopback incase enabled already */
    spi->IOLPKTSTCR = 0U;
    /* Enable Loopback either in Analog or Digital Mode */
    spi->IOLPKTSTCR = (uint32)0x00000A00U
                    | (uint32)((uint32)Loopbacktype << 1U);
/* USER CODE BEGIN (24) */
/* USER CODE END */
/* USER CODE BEGIN (25) */
/* USER CODE END */
/** @fn void spiDisableLoopback(spiBASE_t *spi)
*   This function disable the Loopback mode.
/* SourceId : SPI_SourceId_012 */
/* DesignId : SPI_DesignId_012 */
/* Requirements : HL_SR138 */
/* USER CODE BEGIN (26) */
/* USER CODE END */
    /* Disable Loopback Mode */
    spi->IOLPKTSTCR = 0x00000500U;
/* USER CODE BEGIN (27) */
/* USER CODE END */
/* USER CODE BEGIN (28) */
/* USER CODE END */
/** @fn spiEnableNotification(spiBASE_t *spi, uint32 flags)
*   @brief Enable interrupts
*   @param[in] flags - Interrupts to be enabled, can be ored value of:
/* SourceId : SPI_SourceId_013 */
/* DesignId : SPI_DesignId_003 */
/* Requirements : HL_SR129 */
void spiEnableNotification(spiBASE_t *spi, uint32 flags)
/* USER CODE BEGIN (29) */
/* USER CODE END */
    spi->INT0 = (spi->INT0 & 0xFFFF0000U) | flags;
/* USER CODE BEGIN (30) */
/* USER CODE END */
/* USER CODE BEGIN (31) */
/* USER CODE END */
/** @fn spiDisableNotification(spiBASE_t *spi, uint32 flags)
/* SourceId : SPI_SourceId_014 */
/* DesignId : SPI_DesignId_004 */
/* Requirements : HL_SR130 */
void spiDisableNotification(spiBASE_t *spi, uint32 flags)
/* USER CODE BEGIN (32) */
/* USER CODE END */
    spi->INT0 = (spi->INT0 & (~(flags)));
/* USER CODE BEGIN (33) */
/* USER CODE END */
/** @fn void spi2GetConfigValue(spi_config_reg_t *config_reg, config_value_type_t type)
*   @brief Get the initial or current values of the configuration registers
*    @param[in] *config_reg: pointer to the struct to which the initial or current
*                           value of the configuration registers need to be stored
*    @param[in] type:     whether initial or current value of the configuration registers need to be stored
*                        - InitialValue: initial value of the configuration registers will be stored
*                                       in the struct pointed by config_reg
*                        - CurrentValue: initial value of the configuration registers will be stored
*   This function will copy the initial or current value (depending on the parameter 'type')
*   of the configuration registers to the struct pointed by config_reg
/* SourceId : SPI_SourceId_016 */
/* DesignId : SPI_DesignId_015 */
/* Requirements : HL_SR144 */
    if (type == InitialValue)
        config_reg->CONFIG_GCR1  = SPI2_GCR1_CONFIGVALUE;
        config_reg->CONFIG_INT0  = SPI2_INT0_CONFIGVALUE;
        config_reg->CONFIG_LVL   = SPI2_LVL_CONFIGVALUE;
        config_reg->CONFIG_PC0   = SPI2_PC0_CONFIGVALUE;
        config_reg->CONFIG_PC1   = SPI2_PC1_CONFIGVALUE;
        config_reg->CONFIG_PC6   = SPI2_PC6_CONFIGVALUE;
        config_reg->CONFIG_PC7   = SPI2_PC7_CONFIGVALUE;
        config_reg->CONFIG_PC8   = SPI2_PC8_CONFIGVALUE;
        config_reg->CONFIG_DELAY = SPI2_DELAY_CONFIGVALUE;
        config_reg->CONFIG_FMT0  = SPI2_FMT0_CONFIGVALUE;
        config_reg->CONFIG_FMT1  = SPI2_FMT1_CONFIGVALUE;
        config_reg->CONFIG_FMT2  = SPI2_FMT2_CONFIGVALUE;
        config_reg->CONFIG_FMT3  = SPI2_FMT3_CONFIGVALUE;
    else
    /*SAFETYMCUSW 134 S MR:12.2 <APPROVED> "LDRA Tool issue" */
        config_reg->CONFIG_GCR1  = spiREG2->GCR1;
        config_reg->CONFIG_INT0  = spiREG2->INT0;
        config_reg->CONFIG_LVL   = spiREG2->LVL;
        config_reg->CONFIG_PC0   = spiREG2->PC0;
        config_reg->CONFIG_PC1   = spiREG2->PC1;
        config_reg->CONFIG_PC6   = spiREG2->PC6;
        config_reg->CONFIG_PC7   = spiREG2->PC7;
        config_reg->CONFIG_PC8   = spiREG2->PC8;
        config_reg->CONFIG_DELAY = spiREG2->DELAY ;
        config_reg->CONFIG_FMT0  = spiREG2->FMT0;
        config_reg->CONFIG_FMT1  = spiREG2->FMT1;
        config_reg->CONFIG_FMT2  = spiREG2->FMT2;
        config_reg->CONFIG_FMT3  = spiREG2->FMT3;
  • First, in HALCoGen make sure you configure the following pins as MibSPI2 on the PINMUX tab: E2, N3, D1 and D2. To activate SPI2nCS[0] during the transfers set the CSNR field of SPIDAT1 to 0xFE (bit 16 of SPIDAT1 controls SPIxnCS[0]).
