Part Number: RM48L952
Our loopback compliance test for HET2 fails, while a similar test for HET1 passes. For most parts, our configuration of HET1 and HET2 are rather similar. However, HET1-pins used in the loopback test are default in PinMux. HET2 are not, and are instead placed under Mux Option 1. However, in our setup, the relevant pins (pin4 and 5) are enabled.
Could these differences somehow explain why HET1 loopback works, while HET2 fails? Is there some other possible explanations for this loopback test failing?
