Hi TI,
Can you provide the formal documentation on the list of errors and warnings for the C28x Compiler. We are using C2000 Compiler v18.12.0 LTS.
For instance:
diag_Error = 225,
We need list of all possible Error# and warning# numbers with description.
Thanks and Regards,
Akanksha
Honeywell
Akanksha,
Please take a look at:
https://processors.wiki.ti.com/images/5/55/TICompiler_C28_ErrorList.pdf
https://software-dl.ti.com/ccs/esd/documents/c2000_c28x-compiler-error-and-warning-messages.html
Thanks & Regards,
Santosh
Please see this forum thread. Unfortunately, the status has not changed. I'll add your details to the existing ticket.
Thanks and regards,
-George
Hi Santosh,
The link provided above: "https://processors.wiki.ti.com/images/5/55/TICompiler_C28_ErrorList.pdf" is a broken link. Even in the second link, the referred error and warning lists link is also broken. Can you please attach the PDF document in this thread?
Attached below. Please understand this document is 12 years old. As far as I can tell, nothing in it is incorrect. But it is incomplete in that several diagnostics have been added since that time. Furthermore, this only lists the diagnostics which may come from the first phase of compilation, called the parser. The remaining phases of compilation issue far fewer diagnostics. But there are some, and they are not listed in this document.
Thanks and regards,
-George
