Hi Team,
signalFreq = (1000000 / sum) * 0.97; //calculate frequency (SMCLK/difference)
In this code, why multiply to 0.97?
Thanks & Regards
Yale Li
Hi Team,
Thanks & Regards
Yale Li
Hi Yale,
It looks like the multiplication by 0.97 was added in order to bring the achieved signal frequency value closer to the real frequency value of the input signal. Lots of small things with using the debugger can cause slight inaccuracies, and the developer of the example likely just included it for the sake of making the result in the demonstration more accurate. In my opinion the multiplication by 0.97 is not something that needs to be taken into account or utilized in your designs. If anything, you may want to insert a different adjustment factor in order to end with the most accurate reading.
