MSP430FR59941: trying to debug using CCS: Getting error "MSP430: Trouble Writing Memory Block at 0x1000 on Page 0 of Length 0x354: Could not write device memory"
Part Number: MSP430FR59941
i am trying to debug my program but im getting this error.
MSP430: File Loader: Verification failed: Target failed to write 0x01000
MSP430: GEL: File: C:\sandbox\i4pd-Batteryless-EarDefender\EarDefender\Debug\amcu_EarDefender.out: Load failed.
0x1000 is the BSL.  as far as i was concerned i dont want to overwrite the BSL, is it normally the case that the BSL is written every time you load your code?
I have looked on the forums, only thing i could find was to tick the box saying "allow read/write/erase access to BSL memory", which i tried but didnt help.
looked through the project properties but cant see anything else to try
Any ideas what to try?
michael.
  • Hi Michael,
    To clarify exactly what you are asking--are you trying to write to BSL or not? This will change how the error is interpreted.
    Amruta
    No I'm not trying to write to BSL.
    I am trying to debug / load an application.
    Michael
  • Got it, it might be an issue with your linker file then. Can you send it?
    Amruta
  • thanks.  its just the default cmd file for the part, lnk_msp430fr59941.cmd.  Inserted below anyway:
    * Copyright (C) 2012 - 2021 Texas Instruments Incorporated - http://www.ti.com/
    * Redistribution and use in source and binary forms, with or without
    * modification, are permitted provided that the following conditions
    * are met:
    *  Redistributions of source code must retain the above copyright
    *  notice, this list of conditions and the following disclaimer.
    *  Redistributions in binary form must reproduce the above copyright
    *  notice, this list of conditions and the following disclaimer in the
    *  documentation and/or other materials provided with the
    *  distribution.
    *  Neither the name of Texas Instruments Incorporated nor the names of
    *  its contributors may be used to endorse or promote products derived
    *  from this software without specific prior written permission.
    * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
    * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
    * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
    * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
    * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
    * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
    * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
    * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
    * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
    * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
    * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    * Default linker command file for Texas Instruments MSP430FR59941
    /*   Usage:  lnk430 <obj files...>    -o <out file> -m <map file> lnk.cmd     */
    /*           cl430  <src files...> -z -o <out file> -m <map file> lnk.cmd     */
    /* These linker options are for command line linking only.  For IDE linking,  */
    /* you should set your linker options in Project Properties                   */
    /* -c                                               LINK USING C CONVENTIONS  */
    /* -stack  0x0100                                   SOFTWARE STACK SIZE       */
    /* -heap   0x0100                                   HEAP AREA SIZE            */
    /* 1.212 */
    /* SPECIFY THE SYSTEM MEMORY MAP                                            */
    MEMORY
        TINYRAM                 : origin = 0xA, length = 0x16
        BSL                     : origin = 0x1000, length = 0x800
        INFOD                   : origin = 0x1800, length = 0x80
        INFOC                   : origin = 0x1880, length = 0x80
        INFOB                   : origin = 0x1900, length = 0x80
        INFOA                   : origin = 0x1980, length = 0x80
        RAM                     : origin = 0x1C00, length = 0x1000
        FRAM                    : origin = 0x4000, length = 0xBF80
        FRAM2                   : origin = 0x10000,length = 0x33FF8 /* Boundaries changed to fix CPU47 */
        JTAGSIGNATURE           : origin = 0xFF80, length = 0x0004, fill = 0xFFFF
        BSLSIGNATURE            : origin = 0xFF84, length = 0x0004, fill = 0xFFFF
        IPESIGNATURE            : origin = 0xFF88, length = 0x0008, fill = 0xFFFF
        INT00                   : origin = 0xFF90, length = 0x0002
        INT01                   : origin = 0xFF92, length = 0x0002
        INT02                   : origin = 0xFF94, length = 0x0002
        INT03                   : origin = 0xFF96, length = 0x0002
        INT04                   : origin = 0xFF98, length = 0x0002
        INT05                   : origin = 0xFF9A, length = 0x0002
        INT06                   : origin = 0xFF9C, length = 0x0002
        INT07                   : origin = 0xFF9E, length = 0x0002
        INT08                   : origin = 0xFFA0, length = 0x0002
        INT09                   : origin = 0xFFA2, length = 0x0002
        INT10                   : origin = 0xFFA4, length = 0x0002
        INT11                   : origin = 0xFFA6, length = 0x0002
        INT12                   : origin = 0xFFA8, length = 0x0002
        INT13                   : origin = 0xFFAA, length = 0x0002
        INT14                   : origin = 0xFFAC, length = 0x0002
        INT15                   : origin = 0xFFAE, length = 0x0002
        INT16                   : origin = 0xFFB0, length = 0x0002
        INT17                   : origin = 0xFFB2, length = 0x0002
        INT18                   : origin = 0xFFB4, length = 0x0002
        INT19                   : origin = 0xFFB6, length = 0x0002
        INT20                   : origin = 0xFFB8, length = 0x0002
        INT21                   : origin = 0xFFBA, length = 0x0002
        INT22                   : origin = 0xFFBC, length = 0x0002
        INT23                   : origin = 0xFFBE, length = 0x0002
        INT24                   : origin = 0xFFC0, length = 0x0002
        INT25                   : origin = 0xFFC2, length = 0x0002
        INT26                   : origin = 0xFFC4, length = 0x0002
        INT27                   : origin = 0xFFC6, length = 0x0002
        INT28                   : origin = 0xFFC8, length = 0x0002
        INT29                   : origin = 0xFFCA, length = 0x0002
        INT30                   : origin = 0xFFCC, length = 0x0002
        INT31                   : origin = 0xFFCE, length = 0x0002
        INT32                   : origin = 0xFFD0, length = 0x0002
        INT33                   : origin = 0xFFD2, length = 0x0002
        INT34                   : origin = 0xFFD4, length = 0x0002
        INT35                   : origin = 0xFFD6, length = 0x0002
        INT36                   : origin = 0xFFD8, length = 0x0002
        INT37                   : origin = 0xFFDA, length = 0x0002
        INT38                   : origin = 0xFFDC, length = 0x0002
        INT39                   : origin = 0xFFDE, length = 0x0002
        INT40                   : origin = 0xFFE0, length = 0x0002
        INT41                   : origin = 0xFFE2, length = 0x0002
        INT42                   : origin = 0xFFE4, length = 0x0002
        INT43                   : origin = 0xFFE6, length = 0x0002
        INT44                   : origin = 0xFFE8, length = 0x0002
        INT45                   : origin = 0xFFEA, length = 0x0002
        INT46                   : origin = 0xFFEC, length = 0x0002
        INT47                   : origin = 0xFFEE, length = 0x0002
        INT48                   : origin = 0xFFF0, length = 0x0002
        INT49                   : origin = 0xFFF2, length = 0x0002
        INT50                   : origin = 0xFFF4, length = 0x0002
        INT51                   : origin = 0xFFF6, length = 0x0002
        INT52                   : origin = 0xFFF8, length = 0x0002
        INT53                   : origin = 0xFFFA, length = 0x0002
        INT54                   : origin = 0xFFFC, length = 0x0002
        RESET                   : origin = 0xFFFE, length = 0x0002
    /* Specify the LEA memory map                                               */
    #define LEASTACK_SIZE   0x138
    MEMORY
        LEARAM                  : origin = 0x2C00, length = 0x1000 - LEASTACK_SIZE
        LEASTACK                : origin = 0x3C00 - LEASTACK_SIZE, length = LEASTACK_SIZE
    /* SPECIFY THE SECTIONS ALLOCATION INTO MEMORY                              */
    SECTIONS
        GROUP(RW_IPE)
            GROUP(READ_WRITE_MEMORY)
                .TI.persistent : {}              /* For #pragma persistent            */
                .cio           : {}              /* C I/O Buffer                      */
                .sysmem        : {}              /* Dynamic memory allocation area    */
            } PALIGN(0x0400), RUN_START(fram_rw_start)
            GROUP(IPENCAPSULATED_MEMORY)
                .ipestruct     : {}              /* IPE Data structure             */
                .ipe           : {}              /* IPE                            */
                .ipe_const     : {}              /* IPE Protected constants        */
                .ipe:_isr      : {}              /* IPE ISRs                       */
            } PALIGN(0x0400), RUN_START(fram_ipe_start) RUN_END(fram_ipe_end) RUN_END(fram_rx_start)
        } > 0x4000
        .cinit            : {}  > FRAM          /* Initialization tables             */
        .binit            : {}  > FRAM          /* Boot-time Initialization tables   */
        .pinit            : {}  > FRAM          /* C++ Constructor tables            */
        .init_array       : {}  > FRAM          /* C++ Constructor tables            */
        .mspabi.exidx     : {}  > FRAM          /* C++ Constructor tables            */
        .mspabi.extab     : {}  > FRAM          /* C++ Constructor tables            */
        .text:_isr        : {}  > FRAM          /* Code ISRs                         */
    #ifndef __LARGE_DATA_MODEL__
        .const            : {} > FRAM           /* Constant data                     */
    #else
        .const            : {} >> FRAM | FRAM2  /* Constant data                     */
    #endif
    #ifndef __LARGE_CODE_MODEL__
        .text             : {} > FRAM           /* Code                              */
    #else
        .text             : {} >> FRAM2 | FRAM  /* Code                              */
    #endif
        #ifdef __TI_COMPILER_VERSION__
            #if __TI_COMPILER_VERSION__ >= 15009000
                    .TI.ramfunc : {} load=FRAM, run=RAM, table(BINIT)
                #else
                    .TI.ramfunc : {} load=FRAM | FRAM2, run=RAM, table(BINIT)
                #endif
            #endif
        #endif
        .jtagsignature      : {} > JTAGSIGNATURE
        .bslsignature       : {} > BSLSIGNATURE
        GROUP(SIGNATURE_SHAREDMEMORY)
            .ipesignature       : {}            /* IPE Signature                     */
            .jtagpassword       : {}            /* JTAG Password                     */
        } > IPESIGNATURE
        .bss        : {} > RAM                  /* Global & static vars              */
        .data       : {} > RAM                  /* Global & static vars              */
        .TI.noinit  : {} > RAM                  /* For #pragma noinit                */
        .stack      : {} > RAM (HIGH)           /* Software system stack             */
        .tinyram    : {} > TINYRAM              /* Tiny RAM                          */
        /* MSP430 INFO memory segments */
        .infoA : type = NOINIT{} > INFOA
        .infoB : type = NOINIT{} > INFOB
        .infoC : type = NOINIT{} > INFOC
        .infoD : type = NOINIT{} > INFOD
        .leaRAM      : {} > LEARAM               /* LEA RAM                           */
        .leaStack    : {} > LEASTACK (HIGH)      /* LEA STACK                         */
        /* MSP430 interrupt vectors */
        .int00       : {}               > INT00
        .int01       : {}               > INT01
        .int02       : {}               > INT02
        .int03       : {}               > INT03
        .int04       : {}               > INT04
        .int05       : {}               > INT05
        .int06       : {}               > INT06
        .int07       : {}               > INT07
        .int08       : {}               > INT08
        .int09       : {}               > INT09
        .int10       : {}               > INT10
        .int11       : {}               > INT11
        .int12       : {}               > INT12
        .int13       : {}               > INT13
        .int14       : {}               > INT14
        .int15       : {}               > INT15
        .int16       : {}               > INT16
        .int17       : {}               > INT17
        LEA          : { * ( .int18 ) } > INT18 type = VECT_INIT
        PORT8        : { * ( .int19 ) } > INT19 type = VECT_INIT
        PORT7        : { * ( .int20 ) } > INT20 type = VECT_INIT
        EUSCI_B3     : { * ( .int21 ) } > INT21 type = VECT_INIT
        EUSCI_B2     : { * ( .int22 ) } > INT22 type = VECT_INIT
        EUSCI_B1     : { * ( .int23 ) } > INT23 type = VECT_INIT
        EUSCI_A3     : { * ( .int24 ) } > INT24 type = VECT_INIT
        EUSCI_A2     : { * ( .int25 ) } > INT25 type = VECT_INIT
        PORT6        : { * ( .int26 ) } > INT26 type = VECT_INIT
        PORT5        : { * ( .int27 ) } > INT27 type = VECT_INIT
        TIMER4_A1    : { * ( .int28 ) } > INT28 type = VECT_INIT
        TIMER4_A0    : { * ( .int29 ) } > INT29 type = VECT_INIT
        AES256       : { * ( .int30 ) } > INT30 type = VECT_INIT
        RTC_C        : { * ( .int31 ) } > INT31 type = VECT_INIT
        PORT4        : { * ( .int32 ) } > INT32 type = VECT_INIT
        PORT3        : { * ( .int33 ) } > INT33 type = VECT_INIT
        TIMER3_A1    : { * ( .int34 ) } > INT34 type = VECT_INIT
        TIMER3_A0    : { * ( .int35 ) } > INT35 type = VECT_INIT
        PORT2        : { * ( .int36 ) } > INT36 type = VECT_INIT
        TIMER2_A1    : { * ( .int37 ) } > INT37 type = VECT_INIT
        TIMER2_A0    : { * ( .int38 ) } > INT38 type = VECT_INIT
        PORT1        : { * ( .int39 ) } > INT39 type = VECT_INIT
        TIMER1_A1    : { * ( .int40 ) } > INT40 type = VECT_INIT
        TIMER1_A0    : { * ( .int41 ) } > INT41 type = VECT_INIT
        DMA          : { * ( .int42 ) } > INT42 type = VECT_INIT
        EUSCI_A1     : { * ( .int43 ) } > INT43 type = VECT_INIT
        TIMER0_A1    : { * ( .int44 ) } > INT44 type = VECT_INIT
        TIMER0_A0    : { * ( .int45 ) } > INT45 type = VECT_INIT
        ADC12_B      : { * ( .int46 ) } > INT46 type = VECT_INIT
        EUSCI_B0     : { * ( .int47 ) } > INT47 type = VECT_INIT
        EUSCI_A0     : { * ( .int48 ) } > INT48 type = VECT_INIT
        WDT          : { * ( .int49 ) } > INT49 type = VECT_INIT
        TIMER0_B1    : { * ( .int50 ) } > INT50 type = VECT_INIT
        TIMER0_B0    : { * ( .int51 ) } > INT51 type = VECT_INIT
        COMP_E       : { * ( .int52 ) } > INT52 type = VECT_INIT
        UNMI         : { * ( .int53 ) } > INT53 type = VECT_INIT
        SYSNMI       : { * ( .int54 ) } > INT54 type = VECT_INIT
        .reset       : {}               > RESET  /* MSP430 reset vector         */
    /* MPU/IPE SPECIFIC MEMORY SEGMENT DEFINITONS                               */
    #ifdef _IPE_ENABLE
        #define IPE_MPUIPLOCK 0x0080
        #define IPE_MPUIPENA 0x0040
        #define IPE_MPUIPPUC 0x0020
        // Evaluate settings for the control setting of IP Encapsulation
        #if defined(_IPE_ASSERTPUC1)
            #if defined(_IPE_LOCK ) && (_IPE_ASSERTPUC1 == 0x08))
                fram_ipe_enable_value = (IPE_MPUIPENA | IPE_MPUIPPUC |IPE_MPUIPLOCK);
            #elif defined(_IPE_LOCK )
                fram_ipe_enable_value = (IPE_MPUIPENA | IPE_MPUIPLOCK);
            #elif (_IPE_ASSERTPUC1 == 0x08)
                fram_ipe_enable_value = (IPE_MPUIPENA | IPE_MPUIPPUC);
            #else
                fram_ipe_enable_value = (IPE_MPUIPENA);
            #endif
        #else
            #else
            #endif
        #endif
        // Segment definitions
        #ifdef _IPE_MANUAL                  // For custom sizes selected in the GUI
            fram_ipe_border1 = (_IPE_SEGB1>>4);
            fram_ipe_border2 = (_IPE_SEGB2>>4);
        #else                           // Automated sizes generated by the Linker
            fram_ipe_border2 = fram_ipe_end >> 4;
            fram_ipe_border1 = fram_ipe_start >> 4;
        #endif
        fram_ipe_settings_struct_address = Ipe_settingsStruct >> 4;
        fram_ipe_checksum = ~((fram_ipe_enable_value & fram_ipe_border2 & fram_ipe_border1) | (fram_ipe_enable_value & ~fram_ipe_border2 & ~fram_ipe_border1) | (~fram_ipe_enable_value & fram_ipe_border2 & ~fram_ipe_border1) | (~fram_ipe_enable_value & ~fram_ipe_border2 & fram_ipe_border1));
    #endif
    #ifdef _MPU_ENABLE
        #define MPUPW (0xA500)    /* MPU Access Password */
        #define MPUENA (0x0001)   /* MPU Enable */
        #define MPULOCK (0x0002)  /* MPU Lock */
        #define MPUSEGIE (0x0010) /* MPU Enable NMI on Segment violation */
        __mpu_enable = 1;
        #ifdef _MPU_MANUAL // For custom sizes selected in the GUI
            mpu_segment_border1 = _MPU_SEGB1 >> 4;
            mpu_segment_border2 = _MPU_SEGB2 >> 4;
            mpu_sam_value = (_MPU_SAM0 << 12) | (_MPU_SAM3 << 8) | (_MPU_SAM2 << 4) | _MPU_SAM1;
        #else // Automated sizes generated by Linker
            #ifdef _IPE_ENABLE //if IPE is used in project too
            //seg1 = any read + write persistent variables
            //seg2 = ipe = read + write + execute access
            //seg3 = code, read + execute only
        	       mpu_segment_border1 = fram_ipe_start >> 4;
        	       mpu_segment_border2 = fram_rx_start >> 4;
        	       mpu_sam_value = 0x1573; // Info R, Seg3 RX, Seg2 RWX, Seg1 RW
            #else
        	       mpu_segment_border1 = fram_rx_start >> 4;
        	       mpu_sam_value = 0x1513; // Info R, Seg3 RX, Seg2 R, Seg1 RW
            #endif
        #endif
        #ifdef _MPU_LOCK
            #ifdef _MPU_ENABLE_NMI
                mpu_ctl0_value = MPUPW | MPUENA | MPULOCK | MPUSEGIE;
            #else
                mpu_ctl0_value = MPUPW | MPUENA | MPULOCK;
            #endif
        #else
                mpu_ctl0_value = MPUPW | MPUENA | MPUSEGIE;
            #else
                mpu_ctl0_value = MPUPW | MPUENA;
            #endif
        #endif
    #endif
    /* INCLUDE PERIPHERALS MEMORY MAP                                           */
    -l msp430fr59941.cmd
  • 0x1000 is the BSL.  as far as i was concerned i dont want to overwrite the BSL
    Do you get any linker warnings of the form "creating output section "<SECTION_NAME>" without a SECTIONS specification"?
    Such a linker warning would mean the linker could be placing some sections in the BSL memory region in the cmd file.
    Also, does the linker map file show anything being placed in the BSL memory region?
  • I found the issue. I had a couple of functions that were using #pragma code_section to place in a specific memory location (in upper fram) but I had forgot to add this to the linker file.  Now working thanks for the help.
