Part Number: MSP430G2755
HI,
I just wanted to know if it is possible to invert the UART lines (non active low)?
Kind regards
Christian
HI,
Kind regards
Christian
Added this question also for another device. MSP430FR6989: Is it possible to setup the UART to inverted signal lines (nonactive low) - MSP low-power microcontroller forum - MSP low-power microcontrollers - TI E2E support forums. I just need the answer for MSP430G2755
Hi Tunguskar,
There is no signal inversion available for the UART in these devices.
If you just care about the idle state, you could reconfigure the pin as an output pin and drive it low when not using UART. If you want full inversion you could use a software UART, or you could add a hardware inverter.
Brandon Fisher
