as we are working on FOTA for our product and presently we tried to test DUAL IMAGE/ SINGLE IMAGE FOTA on MSP430FR6989 by referring to MSP430FRBoot – Main Memory Bootloader and Over-the-Air Updates for MSP430 FRAM Large Memory Model Devices https://www.ti.com/lit/pdf/slaa721 and also downloaded the example code from below link https://software-dl.ti.com/msp430/msp430_public_sw/mcu/msp430/MSP430FRBoot/latest/index_FDS.html
as per the document i am trying to build the code APP1 & App2 code for Msp430FR6989 but adding linker file and also generated the linker as per the document
but after adding the above files when i tried to build i am getting lots of errors. please help to solve the errors.
"E:/ti/ccs/tools/compiler/ti-cgt-msp430_21.6.1.LTS/include" -i"E:/ti/ccs/ccs_base/msp430/lib" -i"E:/ti/ccs/ccs_base/msp430/lib/5xx_6xx_FRxx" -i"E:/ti/ccs/ccs_base/msp430/lib/FR59xx" --priority --reread_libs --display_error_number --warn_sections --xml_link_info="App1_MSPBoot_FR5969_UART_linkInfo.xml" --use_hw_mpy=F5 --rom_model -o "App1_MSPBoot_FR5969_UART.out" "./TI_MSPBoot_Mgr_Vectors_FR59xx.obj" "./main1.obj" "../lnk_msp430fr6989.cmd" "../Config_App/lnk_fr6989_single_2k_App.cmd" -llibc.a -llibmath.a
<Linking>
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 41: error #10264: SFR memory
range overlaps existing memory range TINYRAM
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 42: error #10264:
PERIPHERALS_8BIT memory range overlaps existing memory range TINYRAM
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 42: error #10263:
PERIPHERALS_8BIT memory range has already been specified
PERIPHERALS_8BIT
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 43: error #10263:
PERIPHERALS_16BIT memory range has already been specified
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 43: error #10264:
PERIPHERALS_16BIT memory range overlaps existing memory range
PERIPHERALS_16BIT
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 45: error #10263: RAM memory
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 45: error #10264: RAM memory
range overlaps existing memory range RAM
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 47: error #10264: FLASH
memory range overlaps existing memory range FRAM
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 48: error #10264: FLASH2
memory range overlaps existing memory range FRAM2
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 50: error #10264: INT00
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 50: error #10263: INT00
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 51: error #10264: INT01
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 51: error #10263: INT01
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 52: error #10264: INT02
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 52: error #10263: INT02
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 53: error #10264: INT03
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 53: error #10263: INT03
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 54: error #10264: INT04
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 54: error #10263: INT04
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 55: error #10264: INT05
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 55: error #10263: INT05
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 56: error #10264: INT06
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 56: error #10263: INT06
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 57: error #10264: INT07
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 57: error #10263: INT07
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 58: error #10264: INT08
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 58: error #10263: INT08
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 59: error #10264: INT09
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 59: error #10263: INT09
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 60: error #10264: INT10
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 60: error #10263: INT10
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 61: error #10264: INT11
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 61: error #10263: INT11
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 62: error #10264: INT12
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 62: error #10263: INT12
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 63: error #10264: INT13
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 63: error #10263: INT13
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 64: error #10264: INT14
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 64: error #10263: INT14
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 65: error #10264: INT15
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 65: error #10263: INT15
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 66: error #10264: INT16
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 66: error #10263: INT16
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 67: error #10264: INT17
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 67: error #10263: INT17
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 68: error #10264: INT18
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 68: error #10263: INT18
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 69: error #10264: INT19
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 69: error #10263: INT19
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 70: error #10264: INT20
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 70: error #10263: INT20
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 71: error #10264: INT21
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 71: error #10263: INT21
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 72: error #10264: INT22
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 72: error #10263: INT22
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 73: error #10264: INT23
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 73: error #10263: INT23
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 74: error #10264: INT24
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 74: error #10263: INT24
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 75: error #10264: INT25
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 75: error #10263: INT25
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 76: error #10264: INT26
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 76: error #10263: INT26
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 77: error #10264: INT27
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 77: error #10263: INT27
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 78: error #10264: INT28
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 78: error #10263: INT28
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 79: error #10264: INT29
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 79: error #10263: INT29
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 80: error #10264: INT30
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 80: error #10263: INT30
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 81: error #10264: INT31
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 81: error #10263: INT31
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 82: error #10264: INT32
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 82: error #10263: INT32
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 83: error #10264: INT33
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 83: error #10263: INT33
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 84: error #10264: INT34
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 84: error #10263: INT34
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 85: error #10264: INT35
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 85: error #10263: INT35
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 86: error #10264: INT36
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 86: error #10263: INT36
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 87: error #10264: INT37
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 87: error #10263: INT37
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 88: error #10264: INT38
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 88: error #10263: INT38
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 89: error #10264: INT39
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 89: error #10263: INT39
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 90: error #10264: INT40
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 90: error #10263: INT40
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 91: error #10264: INT41
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 91: error #10263: INT41
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 92: error #10264: INT42
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 92: error #10263: INT42
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 93: error #10264: INT43
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 93: error #10263: INT43
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 94: error #10264: INT44
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 94: error #10263: INT44
"../Config_App/lnk_fr6989_single_2k_App.cmd", line 95: error #10264: INT45
fatal error #99900: error limit reached; 100 errors detected
>> Compilation failure
makefile:145: recipe for target 'App1_MSPBoot_FR5969_UART.out' failed
gmake: *** [App1_MSPBoot_FR5969_UART.out] Error 1
gmake: Target 'all' not remade because of errors.
<Linking>
PERIPHERALS_8BIT
PERIPHERALS_16BIT
>> Compilation failure
