Other Parts Discussed in Thread: LP-MSPM0G3507, UNIFLASH, MSPM0G3507
Dear expert,
My customer is using MSP-GANG as programming tool for LP-MSPM0G3507.
they faced the issue when programming, see the status below.
But they are able to program MCU with XDS110, so the MCU works well.
This is the way they connect the board, follow the way from our SOP.
But they can program anything into MCU.
Do you know anything we have to take a look on?
The self test report is also fine. See this.
=== MSP-GANG Self test results ( Wednesday, November 27, 2024, 11:38:25 ) === Adapter SN ------: 17080743 Hardware --------: G430: 01.04 Access key ------: MSP-GANG Programmer Silicon Number --: 8DC0 B06F 2300 0A00 API Firmware ----: MSP-Gang A430: 01.03.09.00 BOOT Firmware ---: G430BOOT B430: 01.00.02.00 GUI Software ----: MSP-Gang-GUI G430: 01.03.09.00 DLL Software ----: MSP-Gang-DLL D430: 01.03.09.00 ================ Test results ============= No. name parameter limits result status 1: Data Bus (ALL LOW) 0x0000 (0x0000 - 0x0000) Result: 0x00 ... >> OK << 2: Data Bus (ALL HIGH) 0x00FF (0xFFFF - 0xFFFF) Result: 0xFFFF ... >> OK << 3: Data Bus (D-0 HI ) 0x0001 (0x0101 - 0x0101) Result: 0x0101 ... >> OK << 4: Data Bus (D-1 HI ) 0x0002 (0x0202 - 0x0202) Result: 0x0202 ... >> OK << 5: Data Bus (D-2 HI ) 0x0004 (0x0404 - 0x0404) Result: 0x0404 ... >> OK << 6: Data Bus (D-3 HI ) 0x0008 (0x0808 - 0x0808) Result: 0x0808 ... >> OK << 7: Data Bus (D-4 HI ) 0x0010 (0x1010 - 0x1010) Result: 0x1010 ... >> OK << 8: Data Bus (D-5 HI ) 0x0020 (0x2020 - 0x2020) Result: 0x2020 ... >> OK << 9: Data Bus (D-6 HI ) 0x0040 (0x4040 - 0x4040) Result: 0x4040 ... >> OK << 10: Data Bus (D-7 HI ) 0x0080 (0x8080 - 0x8080) Result: 0x8080 ... >> OK << 11: Data-2 Bus (ALL LOW) 0x0000 (0x0000 - 0x0000) Result: 0x00 ... >> OK << 12: Data-2 Bus (ALL HIGH) 0x00FF (0xFFFF - 0xFFFF) Result: 0xFFFF ... >> OK << 13: Data-2 Bus (D2-0 HI ) 0x0001 (0x0101 - 0x0101) Result: 0x0101 ... >> OK << 14: Data-2 Bus (D2-1 HI ) 0x0002 (0x0202 - 0x0202) Result: 0x0202 ... >> OK << 15: Data-2 Bus (D2-2 HI ) 0x0004 (0x0404 - 0x0404) Result: 0x0404 ... >> OK << 16: Data-2 Bus (D2-3 HI ) 0x0008 (0x0808 - 0x0808) Result: 0x0808 ... >> OK << 17: Data-2 Bus (D2-4 HI ) 0x0010 (0x1010 - 0x1010) Result: 0x1010 ... >> OK << 18: Data-2 Bus (D2-5 HI ) 0x0020 (0x2020 - 0x2020) Result: 0x2020 ... >> OK << 19: Data-2 Bus (D2-6 HI ) 0x0040 (0x4040 - 0x4040) Result: 0x4040 ... >> OK << 20: Data-2 Bus (D2-7 HI ) 0x0080 (0x8080 - 0x8080) Result: 0x8080 ... >> OK << 21: Vcc Target-1 (ALL OFF) 0.00 V ( 0.00 to 0.30) Result: 0.02 V ... >> OK << 22: Vcc Target-2 (ALL OFF) 0.00 V ( 0.00 to 0.30) Result: 0.01 V ... >> OK << 23: Vcc Target-3 (ALL OFF) 0.00 V ( 0.00 to 0.30) Result: 0.01 V ... >> OK << 24: Vcc Target-4 (ALL OFF) 0.00 V ( 0.00 to 0.30) Result: 0.01 V ... >> OK << 25: Vcc Target-5 (ALL OFF) 0.00 V ( 0.00 to 0.30) Result: 0.01 V ... >> OK << 26: Vcc Target-6 (ALL OFF) 0.00 V ( 0.00 to 0.30) Result: 0.01 V ... >> OK << 27: Vcc Target-7 (ALL OFF) 0.00 V ( 0.00 to 0.30) Result: 0.01 V ... >> OK << 28: Vcc Target-8 (ALL OFF) 0.00 V ( 0.00 to 0.30) Result: 0.01 V ... >> OK << 29: Translators VT (OFF) 0.00 V ( 0.00 to 0.50) Result: 0.01 V ... >> OK << 30: Translators VT (ON 1.8V) 1.80 V ( 1.60 to 2.00) Result: 1.77 V ... >> OK << 31: Translators VT (ON 2.7V) 2.70 V ( 2.50 to 2.90) Result: 2.68 V ... >> OK << 32: Translators VT (ON 3.6V) 3.60 V ( 3.40 to 3.80) Result: 3.58 V ... >> OK << 33: Vpp Voltage-in 10.00 V ( 8.00 to 12.00) Result: 9.99 V ... >> OK << 34: Vpp Voltage 7.00 V ( 6.50 to 7.30) Result: 6.88 V ... >> OK << 35: Internal Vcc-3.3V 3.30 V ( 3.20 to 3.40) Result: 3.31 V ... >> OK << 36: Vcc Target-1 (ALL ON 1.8V) 1.80 V ( 1.60 to 2.00) Result: 1.80 V ... >> OK << 37: Vcc Target-2 (ALL ON 1.8V) 1.80 V ( 1.60 to 2.00) Result: 1.81 V ... >> OK << 38: Vcc Target-3 (ALL ON 1.8V) 1.80 V ( 1.60 to 2.00) Result: 1.82 V ... >> OK << 39: Vcc Target-4 (ALL ON 1.8V) 1.80 V ( 1.60 to 2.00) Result: 1.81 V ... >> OK << 40: Vcc Target-5 (ALL ON 1.8V) 1.80 V ( 1.60 to 2.00) Result: 1.80 V ... >> OK << 41: Vcc Target-6 (ALL ON 1.8V) 1.80 V ( 1.60 to 2.00) Result: 1.79 V ... >> OK << 42: Vcc Target-7 (ALL ON 1.8V) 1.80 V ( 1.60 to 2.00) Result: 1.80 V ... >> OK << 43: Vcc Target-8 (ALL ON 1.8V) 1.80 V ( 1.60 to 2.00) Result: 1.80 V ... >> OK << 44: Vcc Target-1 (ALL ON 2.7V) 2.70 V ( 2.50 to 2.90) Result: 2.69 V ... >> OK << 45: Vcc Target-2 (ALL ON 2.7V) 2.70 V ( 2.50 to 2.90) Result: 2.70 V ... >> OK << 46: Vcc Target-3 (ALL ON 2.7V) 2.70 V ( 2.50 to 2.90) Result: 2.72 V ... >> OK << 47: Vcc Target-4 (ALL ON 2.7V) 2.70 V ( 2.50 to 2.90) Result: 2.72 V ... >> OK << 48: Vcc Target-5 (ALL ON 2.7V) 2.70 V ( 2.50 to 2.90) Result: 2.69 V ... >> OK << 49: Vcc Target-6 (ALL ON 2.7V) 2.70 V ( 2.50 to 2.90) Result: 2.69 V ... >> OK << 50: Vcc Target-7 (ALL ON 2.7V) 2.70 V ( 2.50 to 2.90) Result: 2.70 V ... >> OK << 51: Vcc Target-8 (ALL ON 2.7V) 2.70 V ( 2.50 to 2.90) Result: 2.70 V ... >> OK << 52: Vcc Target-1 (ALL ON 3.6V) 3.60 V ( 3.40 to 3.80) Result: 3.58 V ... >> OK << 53: Vcc Target-2 (ALL ON 3.6V) 3.60 V ( 3.40 to 3.80) Result: 3.59 V ... >> OK << 54: Vcc Target-3 (ALL ON 3.6V) 3.60 V ( 3.40 to 3.80) Result: 3.62 V ... >> OK << 55: Vcc Target-4 (ALL ON 3.6V) 3.60 V ( 3.40 to 3.80) Result: 3.62 V ... >> OK << 56: Vcc Target-5 (ALL ON 3.6V) 3.60 V ( 3.40 to 3.80) Result: 3.60 V ... >> OK << 57: Vcc Target-6 (ALL ON 3.6V) 3.60 V ( 3.40 to 3.80) Result: 3.59 V ... >> OK << 58: Vcc Target-7 (ALL ON 3.6V) 3.60 V ( 3.40 to 3.80) Result: 3.61 V ... >> OK << 59: Vcc Target-8 (ALL ON 3.6V) 3.60 V ( 3.40 to 3.80) Result: 3.60 V ... >> OK << 60: Vcc discharge (100ms)Target-1 3.60 V ( 1.00 to 2.70) Result: 1.09 V ... >> OK << 61: Vcc discharge (100ms)Target-2 3.60 V ( 1.00 to 2.70) Result: 1.11 V ... >> OK << 62: Vcc discharge (100ms)Target-3 3.60 V ( 1.00 to 2.70) Result: 1.10 V ... >> OK << 63: Vcc discharge (100ms)Target-4 3.60 V ( 1.00 to 2.70) Result: 1.10 V ... >> OK << 64: Vcc discharge (100ms)Target-5 3.60 V ( 1.00 to 2.70) Result: 1.12 V ... >> OK << 65: Vcc discharge (100ms)Target-6 3.60 V ( 1.00 to 2.70) Result: 1.11 V ... >> OK << 66: Vcc discharge (100ms)Target-7 3.60 V ( 1.00 to 2.70) Result: 1.09 V ... >> OK << 67: Vcc discharge (100ms)Target-8 3.60 V ( 1.00 to 2.70) Result: 1.12 V ... >> OK << 68: Vcc Target-1 ( #1 ON ) 0.00 V ( 3.10 to 3.50) Result: 3.29 V ... >> OK << 69: Vcc Target-2 ( #1 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.15 V ... >> OK << 70: Vcc Target-3 ( #1 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.15 V ... >> OK << 71: Vcc Target-4 ( #1 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.15 V ... >> OK << 72: Vcc Target-5 ( #1 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.15 V ... >> OK << 73: Vcc Target-6 ( #1 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.14 V ... >> OK << 74: Vcc Target-7 ( #1 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.15 V ... >> OK << 75: Vcc Target-8 ( #1 ON ) 3.30 V ( 0.00 to 0.50) Result: 0.14 V ... >> OK << 76: Vcc Target-1 ( #2 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.15 V ... >> OK << 77: Vcc Target-2 ( #2 ON ) 0.00 V ( 3.10 to 3.50) Result: 3.29 V ... >> OK << 78: Vcc Target-3 ( #2 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.15 V ... >> OK << 79: Vcc Target-4 ( #2 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.15 V ... >> OK << 80: Vcc Target-5 ( #2 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.15 V ... >> OK << 81: Vcc Target-6 ( #2 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.14 V ... >> OK << 82: Vcc Target-7 ( #2 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.15 V ... >> OK << 83: Vcc Target-8 ( #2 ON ) 3.30 V ( 0.00 to 0.50) Result: 0.14 V ... >> OK << 84: Vcc Target-1 ( #3 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.15 V ... >> OK << 85: Vcc Target-2 ( #3 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.15 V ... >> OK << 86: Vcc Target-3 ( #3 ON ) 0.00 V ( 3.10 to 3.50) Result: 3.31 V ... >> OK << 87: Vcc Target-4 ( #3 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.15 V ... >> OK << 88: Vcc Target-5 ( #3 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.15 V ... >> OK << 89: Vcc Target-6 ( #3 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.14 V ... >> OK << 90: Vcc Target-7 ( #3 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.15 V ... >> OK << 91: Vcc Target-8 ( #3 ON ) 3.30 V ( 0.00 to 0.50) Result: 0.14 V ... >> OK << 92: Vcc Target-1 ( #4 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.15 V ... >> OK << 93: Vcc Target-2 ( #4 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.14 V ... >> OK << 94: Vcc Target-3 ( #4 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.15 V ... >> OK << 95: Vcc Target-4 ( #4 ON ) 0.00 V ( 3.10 to 3.50) Result: 3.31 V ... >> OK << 96: Vcc Target-5 ( #4 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.15 V ... >> OK << 97: Vcc Target-6 ( #4 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.14 V ... >> OK << 98: Vcc Target-7 ( #4 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.15 V ... >> OK << 99: Vcc Target-8 ( #4 ON ) 3.30 V ( 0.00 to 0.50) Result: 0.14 V ... >> OK << 100: Vcc Target-1 ( #5 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.15 V ... >> OK << 101: Vcc Target-2 ( #5 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.14 V ... >> OK << 102: Vcc Target-3 ( #5 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.15 V ... >> OK << 103: Vcc Target-4 ( #5 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.15 V ... >> OK << 104: Vcc Target-5 ( #5 ON ) 0.00 V ( 3.10 to 3.50) Result: 3.29 V ... >> OK << 105: Vcc Target-6 ( #5 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.15 V ... >> OK << 106: Vcc Target-7 ( #5 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.15 V ... >> OK << 107: Vcc Target-8 ( #5 ON ) 3.30 V ( 0.00 to 0.50) Result: 0.14 V ... >> OK << 108: Vcc Target-1 ( #6 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.15 V ... >> OK << 109: Vcc Target-2 ( #6 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.14 V ... >> OK << 110: Vcc Target-3 ( #6 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.15 V ... >> OK << 111: Vcc Target-4 ( #6 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.15 V ... >> OK << 112: Vcc Target-5 ( #6 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.15 V ... >> OK << 113: Vcc Target-6 ( #6 ON ) 0.00 V ( 3.10 to 3.50) Result: 3.29 V ... >> OK << 114: Vcc Target-7 ( #6 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.15 V ... >> OK << 115: Vcc Target-8 ( #6 ON ) 3.30 V ( 0.00 to 0.50) Result: 0.14 V ... >> OK << 116: Vcc Target-1 ( #7 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.15 V ... >> OK << 117: Vcc Target-2 ( #7 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.14 V ... >> OK << 118: Vcc Target-3 ( #7 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.15 V ... >> OK << 119: Vcc Target-4 ( #7 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.14 V ... >> OK << 120: Vcc Target-5 ( #7 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.15 V ... >> OK << 121: Vcc Target-6 ( #7 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.15 V ... >> OK << 122: Vcc Target-7 ( #7 ON ) 0.00 V ( 3.10 to 3.50) Result: 3.30 V ... >> OK << 123: Vcc Target-8 ( #7 ON ) 3.30 V ( 0.00 to 0.50) Result: 0.15 V ... >> OK << 124: Vcc Target-1 ( #8 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.15 V ... >> OK << 125: Vcc Target-2 ( #8 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.14 V ... >> OK << 126: Vcc Target-3 ( #8 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.15 V ... >> OK << 127: Vcc Target-4 ( #8 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.15 V ... >> OK << 128: Vcc Target-5 ( #8 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.15 V ... >> OK << 129: Vcc Target-6 ( #8 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.14 V ... >> OK << 130: Vcc Target-7 ( #8 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.15 V ... >> OK << 131: Vcc Target-8 ( #8 ON ) 3.30 V ( 3.10 to 3.50) Result: 3.29 V ... >> OK << 132: SD Power OFF 0x0000 (0x0000 - 0x0000) Result: 0x00 ... >> OK << 133: SD Power ON 0x0001 (0x0001 - 0x0001) Result: 0x01 ... >> OK << 134: SD Discharge - delay 2ms 0x0010 (0x0001 - 0x0001) Result: 0x01 ... >> OK << 135: SD Discharge - delay 50ms 0x0010 (0x0000 - 0x0000) Result: 0x00 ... >> OK << 136: BSL RX bus (#1 HIGH) 0x0001 (0x0001 - 0x0001) Result: 0x01 ... >> OK << 137: BSL RX bus (#2 HIGH) 0x0002 (0x0002 - 0x0002) Result: 0x02 ... >> OK << 138: BSL RX bus (#3 HIGH) 0x0004 (0x0004 - 0x0004) Result: 0x04 ... >> OK << 139: BSL RX bus (#4 HIGH) 0x0008 (0x0008 - 0x0008) Result: 0x08 ... >> OK << 140: BSL RX bus (#5 HIGH) 0x0010 (0x0010 - 0x0010) Result: 0x10 ... >> OK << 141: BSL RX bus (#6 HIGH) 0x0020 (0x0020 - 0x0020) Result: 0x20 ... >> OK << 142: BSL RX bus (#7 HIGH) 0x0040 (0x0040 - 0x0040) Result: 0x40 ... >> OK << 143: BSL RX bus (#8 HIGH) 0x0080 (0x0080 - 0x0080) Result: 0x80 ... >> OK << 144: BSL TX bus (#1 HIGH) 0x0001 (0x0001 - 0x0001) Result: 0x01 ... >> OK << 145: BSL TX bus (#2 HIGH) 0x0002 (0x0002 - 0x0002) Result: 0x02 ... >> OK << 146: BSL TX bus (#3 HIGH) 0x0004 (0x0004 - 0x0004) Result: 0x04 ... >> OK << 147: BSL TX bus (#4 HIGH) 0x0008 (0x0008 - 0x0008) Result: 0x08 ... >> OK << 148: BSL TX bus (#5 HIGH) 0x0010 (0x0010 - 0x0010) Result: 0x10 ... >> OK << 149: BSL TX bus (#6 HIGH) 0x0020 (0x0020 - 0x0020) Result: 0x20 ... >> OK << 150: BSL TX bus (#7 HIGH) 0x0040 (0x0040 - 0x0040) Result: 0x40 ... >> OK << 151: BSL TX bus (#8 HIGH) 0x0080 (0x0080 - 0x0080) Result: 0x80 ... >> OK << 152: TDI bus (#1 HIGH) 0x0001 (0x0001 - 0x0001) Result: 0x01 ... >> OK << 153: TDI bus (#2 HIGH) 0x0002 (0x0002 - 0x0002) Result: 0x02 ... >> OK << 154: TDI bus (#3 HIGH) 0x0004 (0x0004 - 0x0004) Result: 0x04 ... >> OK << 155: TDI bus (#4 HIGH) 0x0008 (0x0008 - 0x0008) Result: 0x08 ... >> OK << 156: TDI bus (#5 HIGH) 0x0010 (0x0010 - 0x0010) Result: 0x10 ... >> OK << 157: TDI bus (#6 HIGH) 0x0020 (0x0020 - 0x0020) Result: 0x20 ... >> OK << 158: TDI bus (#7 HIGH) 0x0040 (0x0040 - 0x0040) Result: 0x40 ... >> OK << 159: TDI bus (#8 HIGH) 0x0080 (0x0080 - 0x0080) Result: 0x80 ... >> OK << 160: TDOI Tx-bus (#1 HIGH) 0x0001 (0x0001 - 0x0001) Result: 0x01 ... >> OK << 161: TDOI Tx-bus (#2 HIGH) 0x0002 (0x0002 - 0x0002) Result: 0x02 ... >> OK << 162: TDOI Tx-bus (#3 HIGH) 0x0004 (0x0004 - 0x0004) Result: 0x04 ... >> OK << 163: TDOI Tx-bus (#4 HIGH) 0x0008 (0x0008 - 0x0008) Result: 0x08 ... >> OK << 164: TDOI Tx-bus (#5 HIGH) 0x0010 (0x0010 - 0x0010) Result: 0x10 ... >> OK << 165: TDOI Tx-bus (#6 HIGH) 0x0020 (0x0020 - 0x0020) Result: 0x20 ... >> OK << 166: TDOI Tx-bus (#7 HIGH) 0x0040 (0x0040 - 0x0040) Result: 0x40 ... >> OK << 167: TDOI Tx-bus (#8 HIGH) 0x0080 (0x0080 - 0x0080) Result: 0x80 ... >> OK << 168: TDOI Tx-Rx (#1 HIGH) 0x0001 (0x0001 - 0x0001) Result: 0x01 ... >> OK << 169: TDOI Tx-Rx (#2 HIGH) 0x0002 (0x0002 - 0x0002) Result: 0x02 ... >> OK << 170: TDOI Tx-Rx (#3 HIGH) 0x0004 (0x0004 - 0x0004) Result: 0x04 ... >> OK << 171: TDOI Tx-Rx (#4 HIGH) 0x0008 (0x0008 - 0x0008) Result: 0x08 ... >> OK << 172: TDOI Tx-Rx (#5 HIGH) 0x0010 (0x0010 - 0x0010) Result: 0x10 ... >> OK << 173: TDOI Tx-Rx (#6 HIGH) 0x0020 (0x0020 - 0x0020) Result: 0x20 ... >> OK << 174: TDOI Tx-Rx (#7 HIGH) 0x0040 (0x0040 - 0x0040) Result: 0x40 ... >> OK << 175: TDOI Tx-Rx (#8 HIGH) 0x0080 (0x0080 - 0x0080) Result: 0x80 ... >> OK << 176: TDOI Rx-bus (#1 HIGH) 0x0001 (0x0001 - 0x0001) Result: 0x01 ... >> OK << 177: TDOI Rx-bus (#2 HIGH) 0x0002 (0x0002 - 0x0002) Result: 0x02 ... >> OK << 178: TDOI Rx-bus (#3 HIGH) 0x0004 (0x0004 - 0x0004) Result: 0x04 ... >> OK << 179: TDOI Rx-bus (#4 HIGH) 0x0008 (0x0008 - 0x0008) Result: 0x08 ... >> OK << 180: TDOI Rx-bus (#5 HIGH) 0x0010 (0x0010 - 0x0010) Result: 0x10 ... >> OK << 181: TDOI Rx-bus (#6 HIGH) 0x0020 (0x0020 - 0x0020) Result: 0x20 ... >> OK << 182: TDOI Rx-bus (#7 HIGH) 0x0040 (0x0040 - 0x0040) Result: 0x40 ... >> OK << 183: TDOI Rx-bus (#84 HIGH) 0x0080 (0x0080 - 0x0080) Result: 0x80 ... >> OK << 184: TMS bus (All HIGH) 0x00FF (0x00FF - 0x00FF) Result: 0xFF ... >> OK << 185: TMS bus (All LOW) 0x0000 (0x0000 - 0x0000) Result: 0x00 ... >> OK << 186: TMS bus (#1 HIGH) 0x0001 (0x0001 - 0x0001) Result: 0x01 ... >> OK << 187: TMS bus (#2 HIGH) 0x0002 (0x0002 - 0x0002) Result: 0x02 ... >> OK << 188: TMS bus (#3 HIGH) 0x0004 (0x0004 - 0x0004) Result: 0x04 ... >> OK << 189: TMS bus (#4 HIGH) 0x0008 (0x0008 - 0x0008) Result: 0x08 ... >> OK << 190: TMS bus (#5 HIGH) 0x0010 (0x0010 - 0x0010) Result: 0x10 ... >> OK << 191: TMS bus (#6 HIGH) 0x0020 (0x0020 - 0x0020) Result: 0x20 ... >> OK << 192: TMS bus (#7 HIGH) 0x0040 (0x0040 - 0x0040) Result: 0x40 ... >> OK << 193: TMS bus (#8 HIGH) 0x0080 (0x0080 - 0x0080) Result: 0x80 ... >> OK << 194: RST bus (All HIGH) 0x00FF (0x00FF - 0x00FF) Result: 0xFF ... >> OK << 195: RST bus (All LOW) 0x0000 (0x0000 - 0x0000) Result: 0x00 ... >> OK << 196: RST bus (#1 HIGH) 0x0001 (0x0001 - 0x0001) Result: 0x01 ... >> OK << 197: RST bus (#2 HIGH) 0x0002 (0x0002 - 0x0002) Result: 0x02 ... >> OK << 198: RST bus (#3 HIGH) 0x0004 (0x0004 - 0x0004) Result: 0x04 ... >> OK << 199: RST bus (#4 HIGH) 0x0008 (0x0008 - 0x0008) Result: 0x08 ... >> OK << 200: RST bus (#5 HIGH) 0x0010 (0x0010 - 0x0010) Result: 0x10 ... >> OK << 201: RST bus (#6 HIGH) 0x0020 (0x0020 - 0x0020) Result: 0x20 ... >> OK << 202: RST bus (#7 HIGH) 0x0040 (0x0040 - 0x0040) Result: 0x40 ... >> OK << 203: RST bus (#8 HIGH) 0x0080 (0x0080 - 0x0080) Result: 0x80 ... >> OK << 204: Keys buffer (All pull-up) 0x001F (0x001F - 0x001F) Result: 0x1F ... >> OK << 205: Access to LCD RAM (0xAA) 0x00AA (0x00AA - 0x00AA) Result: 0xAA ... >> OK << 206: Access to LCD RAM (0x99) 0x0099 (0x0099 - 0x0099) Result: 0x99 ... >> OK << 207: Image Flash Access (get ID) 0x0002 (0x0001 - 0x0004) Result: 0x03 ... >> OK << 208: TDI Fuse keys (#1 ON) 0x0001 (0x0001 - 0x0001) Result: 0x01 ... >> OK << 209: TDI Fuse keys (#2 ON) 0x0002 (0x0002 - 0x0002) Result: 0x02 ... >> OK << 210: TDI Fuse keys (#3 ON) 0x0004 (0x0004 - 0x0004) Result: 0x04 ... >> OK << 211: TDI Fuse keys (#4 ON) 0x0008 (0x0008 - 0x0008) Result: 0x08 ... >> OK << 212: TDI Fuse keys (#5 ON) 0x0010 (0x0010 - 0x0010) Result: 0x10 ... >> OK << 213: TDI Fuse keys (#6 ON) 0x0020 (0x0020 - 0x0020) Result: 0x20 ... >> OK << 214: TDI Fuse keys (#7 ON) 0x0040 (0x0040 - 0x0040) Result: 0x40 ... >> OK << 215: TDI Fuse keys (#8 ON) 0x0080 (0x0080 - 0x0080) Result: 0x80 ... >> OK << 216: TEST Fuse keys (All OFF ) 0.00 ( 0.00 to 0.30) Result: 0.00 ... >> OK << 217: TEST Fuse keys (#1 ON) 1.10 ( 0.80 to 3.00) Result: 1.54 ... >> OK << 218: TEST Fuse keys (#2 ON) 1.10 ( 0.80 to 3.00) Result: 1.45 ... >> OK << 219: TEST Fuse keys (#3 ON) 1.10 ( 0.80 to 3.00) Result: 1.41 ... >> OK << 220: TEST Fuse keys (#4 ON) 1.10 ( 0.80 to 3.00) Result: 1.30 ... >> OK << 221: TEST Fuse keys (#5 ON) 1.10 ( 0.80 to 3.00) Result: 1.22 ... >> OK << 222: TEST Fuse keys (#6 ON) 1.10 ( 0.80 to 3.00) Result: 1.33 ... >> OK << 223: TEST Fuse keys (#7 ON) 1.10 ( 0.80 to 3.00) Result: 1.46 ... >> OK << 224: TEST Fuse keys (#8 ON) 1.10 ( 0.80 to 3.00) Result: 1.51 ... >> OK << ============== Finished ================================= * Test pass - no errors. =========================================================
Eric Chen
