Hi Ismail, can you share more on what exactly the issue is that you are seeing is? Is it the same for each of the defective ones or are there different issues among them?
-Brian
Hello Brian
When installing embedded software on the devices we have mass-produced, the process is interrupted and when we try again, we cannot program. When we check through the software, we observe that the relevant port is damaged. We switch to another port and continue our operations until the eighth port fails. So I can say that they all have port failures.
Hin Ismail, ok thanks for the additional details. Let me discuss this internally and see if we have seen this issue before. I will keep you posted!
-Brian
Hi Brian,
I am attaching the Self Test Report from two devices that I believe you can analyze the problem in more detail.
Thank you.
=== MSP-GANG Self test results ( Tuesday, March 25, 2025, 10:16:55 ) === Adapter SN ------: 21080860 Hardware --------: G430: 01.05 Access key ------: MSP-GANG Programmer Silicon Number --: 578C 886E 0B00 1900 API Firmware ----: MSP-Gang A430: 01.03.06.00 BOOT Firmware ---: G430BOOT B430: 01.00.02.00 GUI Software ----: MSP-Gang-GUI G430: 01.03.06.00 DLL Software ----: MSP-Gang-DLL D430: 01.03.06.00 ================ Test results ============= No. name parameter limits result status 1: Data Bus (ALL LOW) 0x0000 (0x0000 - 0x0000) Result: 0x00 ... >> OK << 2: Data Bus (ALL HIGH) 0x00FF (0xFFFF - 0xFFFF) Result: 0xFFFF ... >> OK << 3: Data Bus (D-0 HI ) 0x0001 (0x0101 - 0x0101) Result: 0x0101 ... >> OK << 4: Data Bus (D-1 HI ) 0x0002 (0x0202 - 0x0202) Result: 0x0202 ... >> OK << 5: Data Bus (D-2 HI ) 0x0004 (0x0404 - 0x0404) Result: 0x0404 ... >> OK << 6: Data Bus (D-3 HI ) 0x0008 (0x0808 - 0x0808) Result: 0x0808 ... >> OK << 7: Data Bus (D-4 HI ) 0x0010 (0x1010 - 0x1010) Result: 0x1010 ... >> OK << 8: Data Bus (D-5 HI ) 0x0020 (0x2020 - 0x2020) Result: 0x2020 ... >> OK << 9: Data Bus (D-6 HI ) 0x0040 (0x4040 - 0x4040) Result: 0x4040 ... >> OK << 10: Data Bus (D-7 HI ) 0x0080 (0x8080 - 0x8080) Result: 0x8080 ... >> OK << 11: Data-2 Bus (ALL LOW) 0x0000 (0x0000 - 0x0000) Result: 0x00 ... >> OK << 12: Data-2 Bus (ALL HIGH) 0x00FF (0xFFFF - 0xFFFF) Result: 0xFFFF ... >> OK << 13: Data-2 Bus (D2-0 HI ) 0x0001 (0x0101 - 0x0101) Result: 0x0101 ... >> OK << 14: Data-2 Bus (D2-1 HI ) 0x0002 (0x0202 - 0x0202) Result: 0x0202 ... >> OK << 15: Data-2 Bus (D2-2 HI ) 0x0004 (0x0404 - 0x0404) Result: 0x0404 ... >> OK << 16: Data-2 Bus (D2-3 HI ) 0x0008 (0x0808 - 0x0808) Result: 0x0808 ... >> OK << 17: Data-2 Bus (D2-4 HI ) 0x0010 (0x1010 - 0x1010) Result: 0x1010 ... >> OK << 18: Data-2 Bus (D2-5 HI ) 0x0020 (0x2020 - 0x2020) Result: 0x2020 ... >> OK << 19: Data-2 Bus (D2-6 HI ) 0x0040 (0x4040 - 0x4040) Result: 0x4040 ... >> OK << 20: Data-2 Bus (D2-7 HI ) 0x0080 (0x8080 - 0x8080) Result: 0x8080 ... >> OK << 21: Vcc Target-1 (ALL OFF) 0.00 V ( 0.00 to 0.30) Result: 0.02 V ... >> OK << 22: Vcc Target-2 (ALL OFF) 0.00 V ( 0.00 to 0.30) Result: 0.01 V ... >> OK << 23: Vcc Target-3 (ALL OFF) 0.00 V ( 0.00 to 0.30) Result: 0.01 V ... >> OK << 24: Vcc Target-4 (ALL OFF) 0.00 V ( 0.00 to 0.30) Result: 0.01 V ... >> OK << 25: Vcc Target-5 (ALL OFF) 0.00 V ( 0.00 to 0.30) Result: 0.01 V ... >> OK << 26: Vcc Target-6 (ALL OFF) 0.00 V ( 0.00 to 0.30) Result: 0.01 V ... >> OK << 27: Vcc Target-7 (ALL OFF) 0.00 V ( 0.00 to 0.30) Result: 0.01 V ... >> OK << 28: Vcc Target-8 (ALL OFF) 0.00 V ( 0.00 to 0.30) Result: 0.01 V ... >> OK << 29: Translators VT (OFF) 0.00 V ( 0.00 to 0.50) Result: 0.01 V ... >> OK << 30: Translators VT (ON 1.8V) 1.80 V ( 1.60 to 2.00) Result: 1.72 V ... >> OK << 31: Translators VT (ON 2.7V) 2.70 V ( 2.50 to 2.90) Result: 2.59 V ... >> OK << 32: Translators VT (ON 3.6V) 3.60 V ( 3.40 to 3.80) Result: 3.46 V ... >> OK << 33: Vpp Voltage-in 10.00 V ( 8.00 to 12.00) Result: 10.19 V ... >> OK << 34: Vpp Voltage 7.00 V ( 6.50 to 7.30) Result: 6.87 V ... >> OK << 35: Internal Vcc-3.3V 3.30 V ( 3.20 to 3.40) Result: 3.30 V ... >> OK << 36: Vcc Target-1 (ALL ON 1.8V) 1.80 V ( 1.60 to 2.00) Result: 1.81 V ... >> OK << 37: Vcc Target-2 (ALL ON 1.8V) 1.80 V ( 1.60 to 2.00) Result: 1.80 V ... >> OK << 38: Vcc Target-3 (ALL ON 1.8V) 1.80 V ( 1.60 to 2.00) Result: 1.83 V ... >> OK << 39: Vcc Target-4 (ALL ON 1.8V) 1.80 V ( 1.60 to 2.00) Result: 1.80 V ... >> OK << 40: Vcc Target-5 (ALL ON 1.8V) 1.80 V ( 1.60 to 2.00) Result: 1.81 V ... >> OK << 41: Vcc Target-6 (ALL ON 1.8V) 1.80 V ( 1.60 to 2.00) Result: 1.80 V ... >> OK << 42: Vcc Target-7 (ALL ON 1.8V) 1.80 V ( 1.60 to 2.00) Result: 1.80 V ... >> OK << 43: Vcc Target-8 (ALL ON 1.8V) 1.80 V ( 1.60 to 2.00) Result: 1.81 V ... >> OK << 44: Vcc Target-1 (ALL ON 2.7V) 2.70 V ( 2.50 to 2.90) Result: 2.67 V ... >> OK << 45: Vcc Target-2 (ALL ON 2.7V) 2.70 V ( 2.50 to 2.90) Result: 2.67 V ... >> OK << 46: Vcc Target-3 (ALL ON 2.7V) 2.70 V ( 2.50 to 2.90) Result: 2.70 V ... >> OK << 47: Vcc Target-4 (ALL ON 2.7V) 2.70 V ( 2.50 to 2.90) Result: 2.67 V ... >> OK << 48: Vcc Target-5 (ALL ON 2.7V) 2.70 V ( 2.50 to 2.90) Result: 2.69 V ... >> OK << 49: Vcc Target-6 (ALL ON 2.7V) 2.70 V ( 2.50 to 2.90) Result: 2.67 V ... >> OK << 50: Vcc Target-7 (ALL ON 2.7V) 2.70 V ( 2.50 to 2.90) Result: 2.68 V ... >> OK << 51: Vcc Target-8 (ALL ON 2.7V) 2.70 V ( 2.50 to 2.90) Result: 2.67 V ... >> OK << 52: Vcc Target-1 (ALL ON 3.6V) 3.60 V ( 3.40 to 3.80) Result: 3.54 V ... >> OK << 53: Vcc Target-2 (ALL ON 3.6V) 3.60 V ( 3.40 to 3.80) Result: 3.55 V ... >> OK << 54: Vcc Target-3 (ALL ON 3.6V) 3.60 V ( 3.40 to 3.80) Result: 3.58 V ... >> OK << 55: Vcc Target-4 (ALL ON 3.6V) 3.60 V ( 3.40 to 3.80) Result: 3.56 V ... >> OK << 56: Vcc Target-5 (ALL ON 3.6V) 3.60 V ( 3.40 to 3.80) Result: 3.56 V ... >> OK << 57: Vcc Target-6 (ALL ON 3.6V) 3.60 V ( 3.40 to 3.80) Result: 3.55 V ... >> OK << 58: Vcc Target-7 (ALL ON 3.6V) 3.60 V ( 3.40 to 3.80) Result: 3.56 V ... >> OK << 59: Vcc Target-8 (ALL ON 3.6V) 3.60 V ( 3.40 to 3.80) Result: 3.54 V ... >> OK << 60: Vcc discharge (100ms)Target-1 3.60 V ( 1.00 to 2.70) Result: 1.21 V ... >> OK << 61: Vcc discharge (100ms)Target-2 3.60 V ( 1.00 to 2.70) Result: 1.22 V ... >> OK << 62: Vcc discharge (100ms)Target-3 3.60 V ( 1.00 to 2.70) Result: 1.25 V ... >> OK << 63: Vcc discharge (100ms)Target-4 3.60 V ( 1.00 to 2.70) Result: 1.26 V ... >> OK << 64: Vcc discharge (100ms)Target-5 3.60 V ( 1.00 to 2.70) Result: 1.20 V ... >> OK << 65: Vcc discharge (100ms)Target-6 3.60 V ( 1.00 to 2.70) Result: 1.23 V ... >> OK << 66: Vcc discharge (100ms)Target-7 3.60 V ( 1.00 to 2.70) Result: 1.24 V ... >> OK << 67: Vcc discharge (100ms)Target-8 3.60 V ( 1.00 to 2.70) Result: 1.21 V ... >> OK << 68: Vcc Target-1 ( #1 ON ) 0.00 V ( 3.10 to 3.50) Result: 3.25 V ... >> OK << 69: Vcc Target-2 ( #1 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK << 70: Vcc Target-3 ( #1 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.18 V ... >> OK << 71: Vcc Target-4 ( #1 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.18 V ... >> OK << 72: Vcc Target-5 ( #1 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.18 V ... >> OK << 73: Vcc Target-6 ( #1 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.18 V ... >> OK << 74: Vcc Target-7 ( #1 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.18 V ... >> OK << 75: Vcc Target-8 ( #1 ON ) 3.30 V ( 0.00 to 0.50) Result: 0.18 V ... >> OK << 76: Vcc Target-1 ( #2 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK << 77: Vcc Target-2 ( #2 ON ) 0.00 V ( 3.10 to 3.50) Result: 3.25 V ... >> OK << 78: Vcc Target-3 ( #2 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK << 79: Vcc Target-4 ( #2 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.18 V ... >> OK << 80: Vcc Target-5 ( #2 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.18 V ... >> OK << 81: Vcc Target-6 ( #2 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.18 V ... >> OK << 82: Vcc Target-7 ( #2 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.18 V ... >> OK << 83: Vcc Target-8 ( #2 ON ) 3.30 V ( 0.00 to 0.50) Result: 0.18 V ... >> OK << 84: Vcc Target-1 ( #3 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK << 85: Vcc Target-2 ( #3 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.18 V ... >> OK << 86: Vcc Target-3 ( #3 ON ) 0.00 V ( 3.10 to 3.50) Result: 3.28 V ... >> OK << 87: Vcc Target-4 ( #3 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK << 88: Vcc Target-5 ( #3 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.18 V ... >> OK << 89: Vcc Target-6 ( #3 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.18 V ... >> OK << 90: Vcc Target-7 ( #3 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.18 V ... >> OK << 91: Vcc Target-8 ( #3 ON ) 3.30 V ( 0.00 to 0.50) Result: 0.18 V ... >> OK << 92: Vcc Target-1 ( #4 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK << 93: Vcc Target-2 ( #4 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.18 V ... >> OK << 94: Vcc Target-3 ( #4 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.18 V ... >> OK << 95: Vcc Target-4 ( #4 ON ) 0.00 V ( 3.10 to 3.50) Result: 3.26 V ... >> OK << 96: Vcc Target-5 ( #4 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK << 97: Vcc Target-6 ( #4 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.18 V ... >> OK << 98: Vcc Target-7 ( #4 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.18 V ... >> OK << 99: Vcc Target-8 ( #4 ON ) 3.30 V ( 0.00 to 0.50) Result: 0.18 V ... >> OK << 100: Vcc Target-1 ( #5 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK << 101: Vcc Target-2 ( #5 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.18 V ... >> OK << 102: Vcc Target-3 ( #5 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.18 V ... >> OK << 103: Vcc Target-4 ( #5 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK << 104: Vcc Target-5 ( #5 ON ) 0.00 V ( 3.10 to 3.50) Result: 3.27 V ... >> OK << 105: Vcc Target-6 ( #5 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK << 106: Vcc Target-7 ( #5 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.18 V ... >> OK << 107: Vcc Target-8 ( #5 ON ) 3.30 V ( 0.00 to 0.50) Result: 0.18 V ... >> OK << 108: Vcc Target-1 ( #6 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK << 109: Vcc Target-2 ( #6 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.18 V ... >> OK << 110: Vcc Target-3 ( #6 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.18 V ... >> OK << 111: Vcc Target-4 ( #6 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.18 V ... >> OK << 112: Vcc Target-5 ( #6 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.18 V ... >> OK << 113: Vcc Target-6 ( #6 ON ) 0.00 V ( 3.10 to 3.50) Result: 3.25 V ... >> OK << 114: Vcc Target-7 ( #6 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK << 115: Vcc Target-8 ( #6 ON ) 3.30 V ( 0.00 to 0.50) Result: 0.18 V ... >> OK << 116: Vcc Target-1 ( #7 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK << 117: Vcc Target-2 ( #7 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.18 V ... >> OK << 118: Vcc Target-3 ( #7 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.18 V ... >> OK << 119: Vcc Target-4 ( #7 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.18 V ... >> OK << 120: Vcc Target-5 ( #7 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.18 V ... >> OK << 121: Vcc Target-6 ( #7 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.18 V ... >> OK << 122: Vcc Target-7 ( #7 ON ) 0.00 V ( 3.10 to 3.50) Result: 3.26 V ... >> OK << 123: Vcc Target-8 ( #7 ON ) 3.30 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK << 124: Vcc Target-1 ( #8 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK << 125: Vcc Target-2 ( #8 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.18 V ... >> OK << 126: Vcc Target-3 ( #8 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.18 V ... >> OK << 127: Vcc Target-4 ( #8 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.18 V ... >> OK << 128: Vcc Target-5 ( #8 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.18 V ... >> OK << 129: Vcc Target-6 ( #8 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.18 V ... >> OK << 130: Vcc Target-7 ( #8 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.18 V ... >> OK << 131: Vcc Target-8 ( #8 ON ) 3.30 V ( 3.10 to 3.50) Result: 3.25 V ... >> OK << 132: SD Power OFF 0x0000 (0x0000 - 0x0000) Result: 0x00 ... >> OK << 133: SD Power ON 0x0001 (0x0001 - 0x0001) Result: 0x01 ... >> OK << 134: SD Discharge - delay 2ms 0x0010 (0x0001 - 0x0001) Result: 0x01 ... >> OK << 135: SD Discharge - delay 50ms 0x0010 (0x0000 - 0x0000) Result: 0x00 ... >> OK << 136: BSL RX bus (#1 HIGH) 0x0001 (0x0001 - 0x0001) Result: 0x01 ... >> OK << 137: BSL RX bus (#2 HIGH) 0x0002 (0x0002 - 0x0002) Result: 0x02 ... >> OK << 138: BSL RX bus (#3 HIGH) 0x0004 (0x0004 - 0x0004) Result: 0x04 ... >> OK << 139: BSL RX bus (#4 HIGH) 0x0008 (0x0008 - 0x0008) Result: 0x08 ... >> OK << 140: BSL RX bus (#5 HIGH) 0x0010 (0x0010 - 0x0010) Result: 0x10 ... >> OK << 141: BSL RX bus (#6 HIGH) 0x0020 (0x0020 - 0x0020) Result: 0x20 ... >> OK << 142: BSL RX bus (#7 HIGH) 0x0040 (0x0040 - 0x0040) Result: 0x40 ... >> OK << 143: BSL RX bus (#8 HIGH) 0x0080 (0x0080 - 0x0080) Result: 0x80 ... >> OK << 144: BSL TX bus (#1 HIGH) 0x0001 (0x0001 - 0x0001) Result: 0x01 ... >> OK << 145: BSL TX bus (#2 HIGH) 0x0002 (0x0002 - 0x0002) Result: 0x02 ... >> OK << 146: BSL TX bus (#3 HIGH) 0x0004 (0x0004 - 0x0004) Result: 0x04 ... >> OK << 147: BSL TX bus (#4 HIGH) 0x0008 (0x0008 - 0x0008) Result: 0x08 ... >> OK << 148: BSL TX bus (#5 HIGH) 0x0010 (0x0010 - 0x0010) Result: 0x10 ... >> OK << 149: BSL TX bus (#6 HIGH) 0x0020 (0x0020 - 0x0020) Result: 0x20 ... >> OK << 150: BSL TX bus (#7 HIGH) 0x0040 (0x0040 - 0x0040) Result: 0x40 ... >> OK << 151: BSL TX bus (#8 HIGH) 0x0080 (0x0080 - 0x0080) Result: 0x80 ... >> OK << 152: TDI bus (#1 HIGH) 0x0001 (0x0001 - 0x0001) Result: 0x01 ... >> OK << 153: TDI bus (#2 HIGH) 0x0002 (0x0002 - 0x0002) Result: 0x02 ... >> OK << 154: TDI bus (#3 HIGH) 0x0004 (0x0004 - 0x0004) Result: 0x04 ... >> OK << 155: TDI bus (#4 HIGH) 0x0008 (0x0008 - 0x0008) Result: 0x08 ... >> OK << 156: TDI bus (#5 HIGH) 0x0010 (0x0010 - 0x0010) Result: 0x10 ... >> OK << 157: TDI bus (#6 HIGH) 0x0020 (0x0020 - 0x0020) Result: 0x20 ... >> OK << 158: TDI bus (#7 HIGH) 0x0040 (0x0040 - 0x0040) Result: 0x40 ... >> OK << 159: TDI bus (#8 HIGH) 0x0080 (0x0080 - 0x0080) Result: 0x80 ... >> OK << 160: TDOI Tx-bus (#1 HIGH) 0x0001 (0x0001 - 0x0001) Result: 0x01 ... >> OK << 161: TDOI Tx-bus (#2 HIGH) 0x0002 (0x0002 - 0x0002) Result: 0x02 ... >> OK << 162: TDOI Tx-bus (#3 HIGH) 0x0004 (0x0004 - 0x0004) Result: 0x00 ... >> ERROR << 163: TDOI Tx-bus (#4 HIGH) 0x0008 (0x0008 - 0x0008) Result: 0x08 ... >> OK << 164: TDOI Tx-bus (#5 HIGH) 0x0010 (0x0010 - 0x0010) Result: 0x10 ... >> OK << 165: TDOI Tx-bus (#6 HIGH) 0x0020 (0x0020 - 0x0020) Result: 0x20 ... >> OK << 166: TDOI Tx-bus (#7 HIGH) 0x0040 (0x0040 - 0x0040) Result: 0x40 ... >> OK << 167: TDOI Tx-bus (#8 HIGH) 0x0080 (0x0080 - 0x0080) Result: 0x00 ... >> ERROR << 168: TDOI Tx-Rx (#1 HIGH) 0x0001 (0x0001 - 0x0001) Result: 0x01 ... >> OK << 169: TDOI Tx-Rx (#2 HIGH) 0x0002 (0x0002 - 0x0002) Result: 0x02 ... >> OK << 170: TDOI Tx-Rx (#3 HIGH) 0x0004 (0x0004 - 0x0004) Result: 0x04 ... >> OK << 171: TDOI Tx-Rx (#4 HIGH) 0x0008 (0x0008 - 0x0008) Result: 0x08 ... >> OK << 172: TDOI Tx-Rx (#5 HIGH) 0x0010 (0x0010 - 0x0010) Result: 0x10 ... >> OK << 173: TDOI Tx-Rx (#6 HIGH) 0x0020 (0x0020 - 0x0020) Result: 0x20 ... >> OK << 174: TDOI Tx-Rx (#7 HIGH) 0x0040 (0x0040 - 0x0040) Result: 0x40 ... >> OK << 175: TDOI Tx-Rx (#8 HIGH) 0x0080 (0x0080 - 0x0080) Result: 0x80 ... >> OK << 176: TDOI Rx-bus (#1 HIGH) 0x0001 (0x0001 - 0x0001) Result: 0x01 ... >> OK << 177: TDOI Rx-bus (#2 HIGH) 0x0002 (0x0002 - 0x0002) Result: 0x02 ... >> OK << 178: TDOI Rx-bus (#3 HIGH) 0x0004 (0x0004 - 0x0004) Result: 0x00 ... >> ERROR << 179: TDOI Rx-bus (#4 HIGH) 0x0008 (0x0008 - 0x0008) Result: 0x08 ... >> OK << 180: TDOI Rx-bus (#5 HIGH) 0x0010 (0x0010 - 0x0010) Result: 0x10 ... >> OK << 181: TDOI Rx-bus (#6 HIGH) 0x0020 (0x0020 - 0x0020) Result: 0x20 ... >> OK << 182: TDOI Rx-bus (#7 HIGH) 0x0040 (0x0040 - 0x0040) Result: 0x40 ... >> OK << 183: TDOI Rx-bus (#84 HIGH) 0x0080 (0x0080 - 0x0080) Result: 0x00 ... >> ERROR << 184: TMS bus (All HIGH) 0x00FF (0x00FF - 0x00FF) Result: 0xFF ... >> OK << 185: TMS bus (All LOW) 0x0000 (0x0000 - 0x0000) Result: 0x00 ... >> OK << 186: TMS bus (#1 HIGH) 0x0001 (0x0001 - 0x0001) Result: 0x01 ... >> OK << 187: TMS bus (#2 HIGH) 0x0002 (0x0002 - 0x0002) Result: 0x02 ... >> OK << 188: TMS bus (#3 HIGH) 0x0004 (0x0004 - 0x0004) Result: 0x00 ... >> ERROR << 189: TMS bus (#4 HIGH) 0x0008 (0x0008 - 0x0008) Result: 0x08 ... >> OK << 190: TMS bus (#5 HIGH) 0x0010 (0x0010 - 0x0010) Result: 0x10 ... >> OK << 191: TMS bus (#6 HIGH) 0x0020 (0x0020 - 0x0020) Result: 0x20 ... >> OK << 192: TMS bus (#7 HIGH) 0x0040 (0x0040 - 0x0040) Result: 0x40 ... >> OK << 193: TMS bus (#8 HIGH) 0x0080 (0x0080 - 0x0080) Result: 0x80 ... >> OK << 194: RST bus (All HIGH) 0x00FF (0x00FF - 0x00FF) Result: 0xFF ... >> OK << 195: RST bus (All LOW) 0x0000 (0x0000 - 0x0000) Result: 0x00 ... >> OK << 196: RST bus (#1 HIGH) 0x0001 (0x0001 - 0x0001) Result: 0x01 ... >> OK << 197: RST bus (#2 HIGH) 0x0002 (0x0002 - 0x0002) Result: 0x02 ... >> OK << 198: RST bus (#3 HIGH) 0x0004 (0x0004 - 0x0004) Result: 0x04 ... >> OK << 199: RST bus (#4 HIGH) 0x0008 (0x0008 - 0x0008) Result: 0x08 ... >> OK << 200: RST bus (#5 HIGH) 0x0010 (0x0010 - 0x0010) Result: 0x10 ... >> OK << 201: RST bus (#6 HIGH) 0x0020 (0x0020 - 0x0020) Result: 0x20 ... >> OK << 202: RST bus (#7 HIGH) 0x0040 (0x0040 - 0x0040) Result: 0x40 ... >> OK << 203: RST bus (#8 HIGH) 0x0080 (0x0080 - 0x0080) Result: 0x80 ... >> OK << 204: Keys buffer (All pull-up) 0x001F (0x001F - 0x001F) Result: 0x1F ... >> OK << 205: Access to LCD RAM (0xAA) 0x00AA (0x00AA - 0x00AA) Result: 0xAA ... >> OK << 206: Access to LCD RAM (0x99) 0x0099 (0x0099 - 0x0099) Result: 0x99 ... >> OK << 207: Image Flash Access (get ID) 0x0002 (0x0001 - 0x0004) Result: 0x04 ... >> OK << 208: TDI Fuse keys (#1 ON) 0x0001 (0x0001 - 0x0001) Result: 0x01 ... >> OK << 209: TDI Fuse keys (#2 ON) 0x0002 (0x0002 - 0x0002) Result: 0x02 ... >> OK << 210: TDI Fuse keys (#3 ON) 0x0004 (0x0004 - 0x0004) Result: 0x04 ... >> OK << 211: TDI Fuse keys (#4 ON) 0x0008 (0x0008 - 0x0008) Result: 0x08 ... >> OK << 212: TDI Fuse keys (#5 ON) 0x0010 (0x0010 - 0x0010) Result: 0x10 ... >> OK << 213: TDI Fuse keys (#6 ON) 0x0020 (0x0020 - 0x0020) Result: 0x20 ... >> OK << 214: TDI Fuse keys (#7 ON) 0x0040 (0x0040 - 0x0040) Result: 0x40 ... >> OK << 215: TDI Fuse keys (#8 ON) 0x0080 (0x0080 - 0x0080) Result: 0x80 ... >> OK << 216: TEST Fuse keys (All OFF ) 0.00 ( 0.00 to 0.30) Result: 0.00 ... >> OK << 217: TEST Fuse keys (#1 ON) 1.00 ( 0.80 to 3.00) Result: 1.35 ... >> OK << 218: TEST Fuse keys (#2 ON) 2.00 ( 0.80 to 3.00) Result: 1.61 ... >> OK << 219: TEST Fuse keys (#3 ON) 3.00 ( 0.80 to 3.00) Result: 1.59 ... >> OK << 220: TEST Fuse keys (#4 ON) 4.00 ( 0.80 to 3.00) Result: 1.55 ... >> OK << 221: TEST Fuse keys (#5 ON) 5.00 ( 0.80 to 3.00) Result: 1.51 ... >> OK << 222: TEST Fuse keys (#6 ON) 6.00 ( 0.80 to 3.00) Result: 1.51 ... >> OK << 223: TEST Fuse keys (#7 ON) 7.00 ( 0.80 to 3.00) Result: 1.52 ... >> OK << 224: TEST Fuse keys (#8 ON) 8.00 ( 0.80 to 3.00) Result: 1.52 ... >> OK << ============== Finished ================================= * Test failed!! 5 error(s). =========================================================
=== MSP-GANG Self test results ( Tuesday, March 25, 2025, 10:15:12 ) === Adapter SN ------: 11091054 Hardware --------: G430: 01.01 Access key ------: MSP-GANG Programmer Silicon Number --: 2216 9046 0F00 2400 API Firmware ----: MSP-Gang A430: 01.03.06.00 BOOT Firmware ---: G430BOOT B430: 01.00.01.00 GUI Software ----: MSP-Gang-GUI G430: 01.03.06.00 DLL Software ----: MSP-Gang-DLL D430: 01.03.06.00 ================ Test results ============= No. name parameter limits result status 1: Data Bus (ALL LOW) 0x0000 (0x0000 - 0x0000) Result: 0x00 ... >> OK << 2: Data Bus (ALL HIGH) 0x00FF (0xFFFF - 0xFFFF) Result: 0xFFFF ... >> OK << 3: Data Bus (D-0 HI ) 0x0001 (0x0101 - 0x0101) Result: 0x0101 ... >> OK << 4: Data Bus (D-1 HI ) 0x0002 (0x0202 - 0x0202) Result: 0x0202 ... >> OK << 5: Data Bus (D-2 HI ) 0x0004 (0x0404 - 0x0404) Result: 0x0404 ... >> OK << 6: Data Bus (D-3 HI ) 0x0008 (0x0808 - 0x0808) Result: 0x0808 ... >> OK << 7: Data Bus (D-4 HI ) 0x0010 (0x1010 - 0x1010) Result: 0x1010 ... >> OK << 8: Data Bus (D-5 HI ) 0x0020 (0x2020 - 0x2020) Result: 0x2020 ... >> OK << 9: Data Bus (D-6 HI ) 0x0040 (0x4040 - 0x4040) Result: 0x4040 ... >> OK << 10: Data Bus (D-7 HI ) 0x0080 (0x8080 - 0x8080) Result: 0x8080 ... >> OK << 11: Data-2 Bus (ALL LOW) 0x0000 (0x0000 - 0x0000) Result: 0x00 ... >> OK << 12: Data-2 Bus (ALL HIGH) 0x00FF (0xFFFF - 0xFFFF) Result: 0xFFFF ... >> OK << 13: Data-2 Bus (D2-0 HI ) 0x0001 (0x0101 - 0x0101) Result: 0x0101 ... >> OK << 14: Data-2 Bus (D2-1 HI ) 0x0002 (0x0202 - 0x0202) Result: 0x0202 ... >> OK << 15: Data-2 Bus (D2-2 HI ) 0x0004 (0x0404 - 0x0404) Result: 0x0404 ... >> OK << 16: Data-2 Bus (D2-3 HI ) 0x0008 (0x0808 - 0x0808) Result: 0x0808 ... >> OK << 17: Data-2 Bus (D2-4 HI ) 0x0010 (0x1010 - 0x1010) Result: 0x1010 ... >> OK << 18: Data-2 Bus (D2-5 HI ) 0x0020 (0x2020 - 0x2020) Result: 0x2020 ... >> OK << 19: Data-2 Bus (D2-6 HI ) 0x0040 (0x4040 - 0x4040) Result: 0x4040 ... >> OK << 20: Data-2 Bus (D2-7 HI ) 0x0080 (0x8080 - 0x8080) Result: 0x8080 ... >> OK << 21: Vcc Target-1 (ALL OFF) 0.00 V ( 0.00 to 0.30) Result: 3.74 V ... >> ERROR << 22: Vcc Target-2 (ALL OFF) 0.00 V ( 0.00 to 0.30) Result: 0.02 V ... >> OK << 23: Vcc Target-3 (ALL OFF) 0.00 V ( 0.00 to 0.30) Result: 0.01 V ... >> OK << 24: Vcc Target-4 (ALL OFF) 0.00 V ( 0.00 to 0.30) Result: 0.01 V ... >> OK << 25: Vcc Target-5 (ALL OFF) 0.00 V ( 0.00 to 0.30) Result: 0.01 V ... >> OK << 26: Vcc Target-6 (ALL OFF) 0.00 V ( 0.00 to 0.30) Result: 0.01 V ... >> OK << 27: Vcc Target-7 (ALL OFF) 0.00 V ( 0.00 to 0.30) Result: 0.01 V ... >> OK << 28: Vcc Target-8 (ALL OFF) 0.00 V ( 0.00 to 0.30) Result: 0.01 V ... >> OK << 29: Translators VT (OFF) 0.00 V ( 0.00 to 0.50) Result: 3.21 V ... >> ERROR << 30: Translators VT (ON 1.8V) 1.80 V ( 1.60 to 2.00) Result: 3.20 V ... >> ERROR << 31: Translators VT (ON 2.7V) 2.70 V ( 2.50 to 2.90) Result: 3.20 V ... >> ERROR << 32: Translators VT (ON 3.6V) 3.60 V ( 3.40 to 3.80) Result: 3.37 V ... >> ERROR << 33: Vpp Voltage-in 10.00 V ( 8.00 to 12.00) Result: 3.34 V ... >> ERROR << 34: Vpp Voltage 7.00 V ( 6.50 to 7.30) Result: 3.74 V ... >> ERROR << 35: Internal Vcc-3.3V 3.30 V ( 3.20 to 3.40) Result: 3.30 V ... >> OK << 36: Vcc Target-1 (ALL ON 1.8V) 1.80 V ( 1.60 to 2.00) Result: 3.75 V ... >> ERROR << 37: Vcc Target-2 (ALL ON 1.8V) 1.80 V ( 1.60 to 2.00) Result: 0.55 V ... >> ERROR << 38: Vcc Target-3 (ALL ON 1.8V) 1.80 V ( 1.60 to 2.00) Result: 0.54 V ... >> ERROR << 39: Vcc Target-4 (ALL ON 1.8V) 1.80 V ( 1.60 to 2.00) Result: 0.54 V ... >> ERROR << 40: Vcc Target-5 (ALL ON 1.8V) 1.80 V ( 1.60 to 2.00) Result: 0.54 V ... >> ERROR << 41: Vcc Target-6 (ALL ON 1.8V) 1.80 V ( 1.60 to 2.00) Result: 0.54 V ... >> ERROR << 42: Vcc Target-7 (ALL ON 1.8V) 1.80 V ( 1.60 to 2.00) Result: 0.53 V ... >> ERROR << 43: Vcc Target-8 (ALL ON 1.8V) 1.80 V ( 1.60 to 2.00) Result: 0.01 V ... >> ERROR << 44: Vcc Target-1 (ALL ON 2.7V) 2.70 V ( 2.50 to 2.90) Result: 3.75 V ... >> ERROR << 45: Vcc Target-2 (ALL ON 2.7V) 2.70 V ( 2.50 to 2.90) Result: 0.33 V ... >> ERROR << 46: Vcc Target-3 (ALL ON 2.7V) 2.70 V ( 2.50 to 2.90) Result: 0.32 V ... >> ERROR << 47: Vcc Target-4 (ALL ON 2.7V) 2.70 V ( 2.50 to 2.90) Result: 0.32 V ... >> ERROR << 48: Vcc Target-5 (ALL ON 2.7V) 2.70 V ( 2.50 to 2.90) Result: 0.32 V ... >> ERROR << 49: Vcc Target-6 (ALL ON 2.7V) 2.70 V ( 2.50 to 2.90) Result: 0.32 V ... >> ERROR << 50: Vcc Target-7 (ALL ON 2.7V) 2.70 V ( 2.50 to 2.90) Result: 0.32 V ... >> ERROR << 51: Vcc Target-8 (ALL ON 2.7V) 2.70 V ( 2.50 to 2.90) Result: 0.01 V ... >> ERROR << 52: Vcc Target-1 (ALL ON 3.6V) 3.60 V ( 3.40 to 3.80) Result: 3.75 V ... >> OK << 53: Vcc Target-2 (ALL ON 3.6V) 3.60 V ( 3.40 to 3.80) Result: 0.14 V ... >> ERROR << 54: Vcc Target-3 (ALL ON 3.6V) 3.60 V ( 3.40 to 3.80) Result: 0.12 V ... >> ERROR << 55: Vcc Target-4 (ALL ON 3.6V) 3.60 V ( 3.40 to 3.80) Result: 0.13 V ... >> ERROR << 56: Vcc Target-5 (ALL ON 3.6V) 3.60 V ( 3.40 to 3.80) Result: 0.12 V ... >> ERROR << 57: Vcc Target-6 (ALL ON 3.6V) 3.60 V ( 3.40 to 3.80) Result: 0.12 V ... >> ERROR << 58: Vcc Target-7 (ALL ON 3.6V) 3.60 V ( 3.40 to 3.80) Result: 0.12 V ... >> ERROR << 59: Vcc Target-8 (ALL ON 3.6V) 3.60 V ( 3.40 to 3.80) Result: 0.01 V ... >> ERROR << 60: Vcc discharge (100ms)Target-1 3.60 V ( 1.00 to 2.70) Result: 3.75 V ... >> ERROR << 61: Vcc discharge (100ms)Target-2 3.60 V ( 1.00 to 2.70) Result: 0.14 V ... >> ERROR << 62: Vcc discharge (100ms)Target-3 3.60 V ( 1.00 to 2.70) Result: 0.13 V ... >> ERROR << 63: Vcc discharge (100ms)Target-4 3.60 V ( 1.00 to 2.70) Result: 0.13 V ... >> ERROR << 64: Vcc discharge (100ms)Target-5 3.60 V ( 1.00 to 2.70) Result: 0.13 V ... >> ERROR << 65: Vcc discharge (100ms)Target-6 3.60 V ( 1.00 to 2.70) Result: 0.13 V ... >> ERROR << 66: Vcc discharge (100ms)Target-7 3.60 V ( 1.00 to 2.70) Result: 0.13 V ... >> ERROR << 67: Vcc discharge (100ms)Target-8 3.60 V ( 1.00 to 2.70) Result: 0.01 V ... >> ERROR << 68: Vcc Target-1 ( #1 ON ) 0.00 V ( 3.10 to 3.50) Result: 3.75 V ... >> ERROR << 69: Vcc Target-2 ( #1 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.20 V ... >> OK << 70: Vcc Target-3 ( #1 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK << 71: Vcc Target-4 ( #1 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK << 72: Vcc Target-5 ( #1 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK << 73: Vcc Target-6 ( #1 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK << 74: Vcc Target-7 ( #1 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK << 75: Vcc Target-8 ( #1 ON ) 3.30 V ( 0.00 to 0.50) Result: 0.01 V ... >> OK << 76: Vcc Target-1 ( #2 ON ) 0.00 V ( 0.00 to 0.50) Result: 3.75 V ... >> ERROR << 77: Vcc Target-2 ( #2 ON ) 0.00 V ( 3.10 to 3.50) Result: 0.20 V ... >> ERROR << 78: Vcc Target-3 ( #2 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK << 79: Vcc Target-4 ( #2 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK << 80: Vcc Target-5 ( #2 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK << 81: Vcc Target-6 ( #2 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK << 82: Vcc Target-7 ( #2 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK << 83: Vcc Target-8 ( #2 ON ) 3.30 V ( 0.00 to 0.50) Result: 0.01 V ... >> OK << 84: Vcc Target-1 ( #3 ON ) 0.00 V ( 0.00 to 0.50) Result: 3.75 V ... >> ERROR << 85: Vcc Target-2 ( #3 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.20 V ... >> OK << 86: Vcc Target-3 ( #3 ON ) 0.00 V ( 3.10 to 3.50) Result: 0.19 V ... >> ERROR << 87: Vcc Target-4 ( #3 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK << 88: Vcc Target-5 ( #3 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK << 89: Vcc Target-6 ( #3 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK << 90: Vcc Target-7 ( #3 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK << 91: Vcc Target-8 ( #3 ON ) 3.30 V ( 0.00 to 0.50) Result: 0.01 V ... >> OK << 92: Vcc Target-1 ( #4 ON ) 0.00 V ( 0.00 to 0.50) Result: 3.75 V ... >> ERROR << 93: Vcc Target-2 ( #4 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.20 V ... >> OK << 94: Vcc Target-3 ( #4 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK << 95: Vcc Target-4 ( #4 ON ) 0.00 V ( 3.10 to 3.50) Result: 0.19 V ... >> ERROR << 96: Vcc Target-5 ( #4 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK << 97: Vcc Target-6 ( #4 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK << 98: Vcc Target-7 ( #4 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK << 99: Vcc Target-8 ( #4 ON ) 3.30 V ( 0.00 to 0.50) Result: 0.01 V ... >> OK << 100: Vcc Target-1 ( #5 ON ) 0.00 V ( 0.00 to 0.50) Result: 3.75 V ... >> ERROR << 101: Vcc Target-2 ( #5 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.20 V ... >> OK << 102: Vcc Target-3 ( #5 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK << 103: Vcc Target-4 ( #5 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK << 104: Vcc Target-5 ( #5 ON ) 0.00 V ( 3.10 to 3.50) Result: 0.19 V ... >> ERROR << 105: Vcc Target-6 ( #5 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK << 106: Vcc Target-7 ( #5 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK << 107: Vcc Target-8 ( #5 ON ) 3.30 V ( 0.00 to 0.50) Result: 0.01 V ... >> OK << 108: Vcc Target-1 ( #6 ON ) 0.00 V ( 0.00 to 0.50) Result: 3.75 V ... >> ERROR << 109: Vcc Target-2 ( #6 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.20 V ... >> OK << 110: Vcc Target-3 ( #6 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK << 111: Vcc Target-4 ( #6 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK << 112: Vcc Target-5 ( #6 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK << 113: Vcc Target-6 ( #6 ON ) 0.00 V ( 3.10 to 3.50) Result: 0.19 V ... >> ERROR << 114: Vcc Target-7 ( #6 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK << 115: Vcc Target-8 ( #6 ON ) 3.30 V ( 0.00 to 0.50) Result: 0.01 V ... >> OK << 116: Vcc Target-1 ( #7 ON ) 0.00 V ( 0.00 to 0.50) Result: 3.75 V ... >> ERROR << 117: Vcc Target-2 ( #7 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.20 V ... >> OK << 118: Vcc Target-3 ( #7 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK << 119: Vcc Target-4 ( #7 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK << 120: Vcc Target-5 ( #7 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK << 121: Vcc Target-6 ( #7 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK << 122: Vcc Target-7 ( #7 ON ) 0.00 V ( 3.10 to 3.50) Result: 0.19 V ... >> ERROR << 123: Vcc Target-8 ( #7 ON ) 3.30 V ( 0.00 to 0.50) Result: 0.01 V ... >> OK << 124: Vcc Target-1 ( #8 ON ) 0.00 V ( 0.00 to 0.50) Result: 3.75 V ... >> ERROR << 125: Vcc Target-2 ( #8 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.20 V ... >> OK << 126: Vcc Target-3 ( #8 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK << 127: Vcc Target-4 ( #8 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK << 128: Vcc Target-5 ( #8 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK << 129: Vcc Target-6 ( #8 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK << 130: Vcc Target-7 ( #8 ON ) 0.00 V ( 0.00 to 0.50) Result: 0.19 V ... >> OK << 131: Vcc Target-8 ( #8 ON ) 3.30 V ( 3.10 to 3.50) Result: 0.01 V ... >> ERROR << 132: SD Power OFF 0x0000 (0x0000 - 0x0000) Result: 0x00 ... >> OK << 133: SD Power ON 0x0001 (0x0001 - 0x0001) Result: 0x01 ... >> OK << 134: SD Discharge - delay 2ms 0x0010 (0x0001 - 0x0001) Result: 0x01 ... >> OK << 135: SD Discharge - delay 50ms 0x0010 (0x0000 - 0x0000) Result: 0x00 ... >> OK << 136: BSL RX bus (#1 HIGH) 0x0001 (0x0001 - 0x0001) Result: 0x81 ... >> ERROR << 137: BSL RX bus (#2 HIGH) 0x0002 (0x0002 - 0x0002) Result: 0x80 ... >> ERROR << 138: BSL RX bus (#3 HIGH) 0x0004 (0x0004 - 0x0004) Result: 0x84 ... >> ERROR << 139: BSL RX bus (#4 HIGH) 0x0008 (0x0008 - 0x0008) Result: 0x88 ... >> ERROR << 140: BSL RX bus (#5 HIGH) 0x0010 (0x0010 - 0x0010) Result: 0x90 ... >> ERROR << 141: BSL RX bus (#6 HIGH) 0x0020 (0x0020 - 0x0020) Result: 0xA0 ... >> ERROR << 142: BSL RX bus (#7 HIGH) 0x0040 (0x0040 - 0x0040) Result: 0x80 ... >> ERROR << 143: BSL RX bus (#8 HIGH) 0x0080 (0x0080 - 0x0080) Result: 0x80 ... >> OK << 144: BSL TX bus (#1 HIGH) 0x0001 (0x0001 - 0x0001) Result: 0x81 ... >> ERROR << 145: BSL TX bus (#2 HIGH) 0x0002 (0x0002 - 0x0002) Result: 0x80 ... >> ERROR << 146: BSL TX bus (#3 HIGH) 0x0004 (0x0004 - 0x0004) Result: 0x84 ... >> ERROR << 147: BSL TX bus (#4 HIGH) 0x0008 (0x0008 - 0x0008) Result: 0x88 ... >> ERROR << 148: BSL TX bus (#5 HIGH) 0x0010 (0x0010 - 0x0010) Result: 0x90 ... >> ERROR << 149: BSL TX bus (#6 HIGH) 0x0020 (0x0020 - 0x0020) Result: 0xA0 ... >> ERROR << 150: BSL TX bus (#7 HIGH) 0x0040 (0x0040 - 0x0040) Result: 0x80 ... >> ERROR << 151: BSL TX bus (#8 HIGH) 0x0080 (0x0080 - 0x0080) Result: 0x80 ... >> OK << 152: TDI bus (#1 HIGH) 0x0001 (0x0001 - 0x0001) Result: 0x80 ... >> ERROR << 153: TDI bus (#2 HIGH) 0x0002 (0x0002 - 0x0002) Result: 0x80 ... >> ERROR << 154: TDI bus (#3 HIGH) 0x0004 (0x0004 - 0x0004) Result: 0x80 ... >> ERROR << 155: TDI bus (#4 HIGH) 0x0008 (0x0008 - 0x0008) Result: 0x80 ... >> ERROR << 156: TDI bus (#5 HIGH) 0x0010 (0x0010 - 0x0010) Result: 0x80 ... >> ERROR << 157: TDI bus (#6 HIGH) 0x0020 (0x0020 - 0x0020) Result: 0xA0 ... >> ERROR << 158: TDI bus (#7 HIGH) 0x0040 (0x0040 - 0x0040) Result: 0x80 ... >> ERROR << 159: TDI bus (#8 HIGH) 0x0080 (0x0080 - 0x0080) Result: 0x80 ... >> OK << 160: TDOI Tx-bus (#1 HIGH) 0x0001 (0x0001 - 0x0001) Result: 0x00 ... >> ERROR << 161: TDOI Tx-bus (#2 HIGH) 0x0002 (0x0002 - 0x0002) Result: 0x00 ... >> ERROR << 162: TDOI Tx-bus (#3 HIGH) 0x0004 (0x0004 - 0x0004) Result: 0x04 ... >> OK << 163: TDOI Tx-bus (#4 HIGH) 0x0008 (0x0008 - 0x0008) Result: 0x08 ... >> OK << 164: TDOI Tx-bus (#5 HIGH) 0x0010 (0x0010 - 0x0010) Result: 0x10 ... >> OK << 165: TDOI Tx-bus (#6 HIGH) 0x0020 (0x0020 - 0x0020) Result: 0x20 ... >> OK << 166: TDOI Tx-bus (#7 HIGH) 0x0040 (0x0040 - 0x0040) Result: 0x40 ... >> OK << 167: TDOI Tx-bus (#8 HIGH) 0x0080 (0x0080 - 0x0080) Result: 0x80 ... >> OK << 168: TDOI Tx-Rx (#1 HIGH) 0x0001 (0x0001 - 0x0001) Result: 0x01 ... >> OK << 169: TDOI Tx-Rx (#2 HIGH) 0x0002 (0x0002 - 0x0002) Result: 0x02 ... >> OK << 170: TDOI Tx-Rx (#3 HIGH) 0x0004 (0x0004 - 0x0004) Result: 0x04 ... >> OK << 171: TDOI Tx-Rx (#4 HIGH) 0x0008 (0x0008 - 0x0008) Result: 0x08 ... >> OK << 172: TDOI Tx-Rx (#5 HIGH) 0x0010 (0x0010 - 0x0010) Result: 0x10 ... >> OK << 173: TDOI Tx-Rx (#6 HIGH) 0x0020 (0x0020 - 0x0020) Result: 0x20 ... >> OK << 174: TDOI Tx-Rx (#7 HIGH) 0x0040 (0x0040 - 0x0040) Result: 0x40 ... >> OK << 175: TDOI Tx-Rx (#8 HIGH) 0x0080 (0x0080 - 0x0080) Result: 0x80 ... >> OK << 176: TDOI Rx-bus (#1 HIGH) 0x0001 (0x0001 - 0x0001) Result: 0x00 ... >> ERROR << 177: TDOI Rx-bus (#2 HIGH) 0x0002 (0x0002 - 0x0002) Result: 0x00 ... >> ERROR << 178: TDOI Rx-bus (#3 HIGH) 0x0004 (0x0004 - 0x0004) Result: 0x04 ... >> OK << 179: TDOI Rx-bus (#4 HIGH) 0x0008 (0x0008 - 0x0008) Result: 0x08 ... >> OK << 180: TDOI Rx-bus (#5 HIGH) 0x0010 (0x0010 - 0x0010) Result: 0x10 ... >> OK << 181: TDOI Rx-bus (#6 HIGH) 0x0020 (0x0020 - 0x0020) Result: 0x20 ... >> OK << 182: TDOI Rx-bus (#7 HIGH) 0x0040 (0x0040 - 0x0040) Result: 0x40 ... >> OK << 183: TDOI Rx-bus (#84 HIGH) 0x0080 (0x0080 - 0x0080) Result: 0x80 ... >> OK << 184: TMS bus (All HIGH) 0x00FF (0x00FF - 0x00FF) Result: 0xFF ... >> OK << 185: TMS bus (All LOW) 0x0000 (0x0000 - 0x0000) Result: 0x00 ... >> OK << 186: TMS bus (#1 HIGH) 0x0001 (0x0001 - 0x0001) Result: 0x00 ... >> ERROR << 187: TMS bus (#2 HIGH) 0x0002 (0x0002 - 0x0002) Result: 0x00 ... >> ERROR << 188: TMS bus (#3 HIGH) 0x0004 (0x0004 - 0x0004) Result: 0x04 ... >> OK << 189: TMS bus (#4 HIGH) 0x0008 (0x0008 - 0x0008) Result: 0x08 ... >> OK << 190: TMS bus (#5 HIGH) 0x0010 (0x0010 - 0x0010) Result: 0x10 ... >> OK << 191: TMS bus (#6 HIGH) 0x0020 (0x0020 - 0x0020) Result: 0x20 ... >> OK << 192: TMS bus (#7 HIGH) 0x0040 (0x0040 - 0x0040) Result: 0x40 ... >> OK << 193: TMS bus (#8 HIGH) 0x0080 (0x0080 - 0x0080) Result: 0x80 ... >> OK << 194: RST bus (All HIGH) 0x00FF (0x00FF - 0x00FF) Result: 0xFF ... >> OK << 195: RST bus (All LOW) 0x0000 (0x0000 - 0x0000) Result: 0xC0 ... >> ERROR << 196: RST bus (#1 HIGH) 0x0001 (0x0001 - 0x0001) Result: 0xC1 ... >> ERROR << 197: RST bus (#2 HIGH) 0x0002 (0x0002 - 0x0002) Result: 0xC0 ... >> ERROR << 198: RST bus (#3 HIGH) 0x0004 (0x0004 - 0x0004) Result: 0xC4 ... >> ERROR << 199: RST bus (#4 HIGH) 0x0008 (0x0008 - 0x0008) Result: 0xC8 ... >> ERROR << 200: RST bus (#5 HIGH) 0x0010 (0x0010 - 0x0010) Result: 0xD0 ... >> ERROR << 201: RST bus (#6 HIGH) 0x0020 (0x0020 - 0x0020) Result: 0xE0 ... >> ERROR << 202: RST bus (#7 HIGH) 0x0040 (0x0040 - 0x0040) Result: 0xC0 ... >> ERROR << 203: RST bus (#8 HIGH) 0x0080 (0x0080 - 0x0080) Result: 0xC0 ... >> ERROR << 204: Keys buffer (All pull-up) 0x001F (0x001F - 0x001F) Result: 0x1F ... >> OK << 205: Access to LCD RAM (0xAA) 0x00AA (0x00AA - 0x00AA) Result: 0xAA ... >> OK << 206: Access to LCD RAM (0x99) 0x0099 (0x0099 - 0x0099) Result: 0x99 ... >> OK << 207: Image Flash Access (get ID) 0x0002 (0x0001 - 0x0004) Result: 0x02 ... >> OK << 208: TDI Fuse keys (#1 ON) 0x0001 (0x0001 - 0x0001) Result: 0x80 ... >> ERROR << 209: TDI Fuse keys (#2 ON) 0x0002 (0x0002 - 0x0002) Result: 0x82 ... >> ERROR << 210: TDI Fuse keys (#3 ON) 0x0004 (0x0004 - 0x0004) Result: 0x84 ... >> ERROR << 211: TDI Fuse keys (#4 ON) 0x0008 (0x0008 - 0x0008) Result: 0x88 ... >> ERROR << 212: TDI Fuse keys (#5 ON) 0x0010 (0x0010 - 0x0010) Result: 0x90 ... >> ERROR << 213: TDI Fuse keys (#6 ON) 0x0020 (0x0020 - 0x0020) Result: 0xA0 ... >> ERROR << 214: TDI Fuse keys (#7 ON) 0x0040 (0x0040 - 0x0040) Result: 0xC0 ... >> ERROR << 215: TDI Fuse keys (#8 ON) 0x0080 (0x0080 - 0x0080) Result: 0x80 ... >> OK << 216: TEST Fuse keys (All OFF ) 0.00 ( 0.00 to 0.30) Result: 0.00 ... >> OK << 217: TEST Fuse keys (#1 ON) 1.00 ( 0.80 to 3.00) Result: 0.00 ... >> ERROR << 218: TEST Fuse keys (#2 ON) 2.00 ( 0.80 to 3.00) Result: 0.00 ... >> ERROR << 219: TEST Fuse keys (#3 ON) 3.00 ( 0.80 to 3.00) Result: 0.00 ... >> ERROR << 220: TEST Fuse keys (#4 ON) 4.00 ( 0.80 to 3.00) Result: 0.00 ... >> ERROR << 221: TEST Fuse keys (#5 ON) 5.00 ( 0.80 to 3.00) Result: 0.00 ... >> ERROR << 222: TEST Fuse keys (#6 ON) 6.00 ( 0.80 to 3.00) Result: 0.00 ... >> ERROR << 223: TEST Fuse keys (#7 ON) 7.00 ( 0.80 to 3.00) Result: 0.00 ... >> ERROR << 224: TEST Fuse keys (#8 ON) 8.00 ( 0.80 to 3.00) Result: 0.00 ... >> ERROR << ============== Finished ================================= * Test failed!! 104 error(s). =========================================================
Hi Ismail, thanks for sending this over, should hopefully help us find the root cause. Will keep you updated.
Hi Ismail, no news yet unfortunately. I will bump up the priority here, we may need to borrow one of these defective devices to further investigate. If that is the case we can shift this over to direct communication trough email.
Hi Brian;
I can of course send the devices to you if it will help as long as it takes to get them to you. Thank you very much for your support.
