We are debugging DRV8412 board. But I found DRV8412 went to following damage status sometimes:
The first output channel (Pin5-7) is abnormal - No PWM output. But the second output channel (Pin15-17) is normal output with PWM we control. The FLT and OT are both in high level status.
So far we have found 3 pcs of DRV8412 with this same issue.
Could you help analyze which factor or operation trigger this issue? The solution will be very helpful and critical for our risk retirement. I attached circuit as below.
Thanks.
Xulong
