Other Parts Discussed in Thread: MCF8316A, MCT8316Z
I asked and solved the problem that the motor does not rotate well in the closed loop.
But I still have some problems.
(1) Motor does not rotate stably at low speed (30 [fps])
When the speed drops below about 40 [fps], it often stops.
(2) If the torque load fluctuates, the motor cannot maintain its speed.
Especially low speed rotation is difficult with my low power motor.
My motor has an encoder, but it doesn't have A, B, C phase Hall sensors...
{ "signature": "oneui-register-data", "data": [ [ { "idx": 0, "id": "isd_config", "value": "0x04638C20" }, { "idx": 1, "id": "rev_drive_config", "value": "0x283AF064" }, { "idx": 2, "id": "motor_startup1", "value": "0x0A8407D0" }, { "idx": 3, "id": "motor_startup2", "value": "0x1382E034" }, { "idx": 4, "id": "closed_loop1", "value": "0x0D3201B4" }, { "idx": 5, "id": "closed_loop2", "value": "0x1AADD858" }, { "idx": 6, "id": "closed_loop3", "value": "0x28800000" }, { "idx": 7, "id": "closed_loop4", "value": "0x0A004870" }, { "idx": 8, "id": "speed_profiles1", "value": "0x000007E8" }, { "idx": 9, "id": "speed_profiles2", "value": "0x70000000" }, { "idx": 10, "id": "speed_profiles3", "value": "0x00000000" }, { "idx": 11, "id": "speed_profiles4", "value": "0x00000000" }, { "idx": 12, "id": "speed_profiles5", "value": "0x00000000" }, { "idx": 13, "id": "speed_profiles6", "value": "0x00000000" } ], [ { "idx": 0, "id": "fault_config1", "value": "0x5FE8820E" }, { "idx": 1, "id": "fault_config2", "value": "0x74008000" } ], [ { "idx": 0, "id": "pin_config", "value": "0x2DD0E480" }, { "idx": 1, "id": "device_config1", "value": "0x08000001" }, { "idx": 2, "id": "device_config2", "value": "0x00003000" }, { "idx": 3, "id": "peri_config1", "value": "0x00000000" }, { "idx": 4, "id": "gd_config1", "value": "0x00000000" }, { "idx": 5, "id": "gd_config2", "value": "0x00000000" } ], [ { "idx": 0, "id": "ana_trim3", "value": "0x48004800" }, { "idx": 1, "id": "ana_trim4", "value": "0x00000000" }, { "idx": 2, "id": "ana_trim5", "value": "0x00000013" }, { "idx": 3, "id": "ana_trim6", "value": "0x00000000" }, { "idx": 4, "id": "ana_trim7", "value": "0x00000000" }, { "idx": 5, "id": "ana_trim8", "value": "0x00005C95" }, { "idx": 6, "id": "ana_trim9", "value": "0x008D55D7" }, { "idx": 7, "id": "ana_trim10", "value": "0x537E013A" } ], [ { "idx": 0, "id": "int_algo_1", "value": "0x00020000" }, { "idx": 1, "id": "int_algo_2", "value": "0x00000140" } ], [ { "idx": 0, "id": "gate_driver_fault_status", "value": "0x00000000" }, { "idx": 1, "id": "controller_fault_status", "value": "0x00000000" } ], [ { "idx": 0, "id": "algo_status", "value": "0x0E7E0000" }, { "idx": 1, "id": "mtr_params", "value": "0x00000000" }, { "idx": 2, "id": "algo_status_mpet", "value": "0x0A000000" } ], [ { "idx": 0, "id": "algo_ctrl1", "value": "0x00000000" } ], [ { "idx": 0, "id": "algo_debug1", "value": "0x00000000" }, { "idx": 1, "id": "algo_debug2", "value": "0x00000000" }, { "idx": 2, "id": "current_pi", "value": "0x0005813D" }, { "idx": 3, "id": "speed_pi", "value": "0x00000000" } ], [ { "idx": 0, "id": "speed_ref_closed_loop", "value": "0x00000000" }, { "idx": 1, "id": "vm_voltage", "value": "0x0348C000" }, { "idx": 2, "id": "voltage_gain_feedback", "value": "0x00000001" }, { "idx": 3, "id": "csa_gain_feedback", "value": "0x00000003" }, { "idx": 4, "id": "phase_voltage_va", "value": "0x00000000" }, { "idx": 5, "id": "phase_voltage_vb", "value": "0x00000000" }, { "idx": 6, "id": "phase_voltage_vc", "value": "0x00000000" }, { "idx": 7, "id": "id_ref_closed_loop", "value": "0x00000000" }, { "idx": 8, "id": "iq_ref_closed_loop", "value": "0x00000000" }, { "idx": 9, "id": "id", "value": "0x00000000" }, { "idx": 10, "id": "iq", "value": "0x00000000" }, { "idx": 11, "id": "vd", "value": "0x00000000" }, { "idx": 12, "id": "vq", "value": "0x00000000" }, { "idx": 13, "id": "ialpha", "value": "0x00000000" }, { "idx": 14, "id": "ibeta", "value": "0x00000000" }, { "idx": 15, "id": "valpha", "value": "0x00000000" }, { "idx": 16, "id": "vbeta", "value": "0x00000000" }, { "idx": 17, "id": "bus_current", "value": "0xFFFFFF9C" }, { "idx": 18, "id": "ipd_state", "value": "0x00000000" }, { "idx": 19, "id": "isd_state", "value": "0x00000000" }, { "idx": 20, "id": "algorithm_state", "value": "0x00000000" }, { "idx": 21, "id": "phase_current_a", "value": "0x00000000" }, { "idx": 22, "id": "phase_current_b", "value": "0x00000000" }, { "idx": 23, "id": "phase_current_c", "value": "0x00000000" }, { "idx": 24, "id": "ipd_angle", "value": "0x00000000" }, { "idx": 25, "id": "isd_speed", "value": "0x00000000" }, { "idx": 26, "id": "speed_ref_open_loop", "value": "0x00000000" }, { "idx": 27, "id": "iq_ref_open_loop", "value": "0x00000000" }, { "idx": 28, "id": "iq_ref_rotor_align", "value": "0x00000000" }, { "idx": 29, "id": "ed", "value": "0x00000000" }, { "idx": 30, "id": "eq", "value": "0x00000000" }, { "idx": 31, "id": "theta_est", "value": "0x00000000" }, { "idx": 32, "id": "speed_fdbk", "value": "0x00000000" }, { "idx": 33, "id": "sin_commutation_angle", "value": "0x0503BDA8" }, { "idx": 34, "id": "cos_commutation_angle", "value": "0x00000000" } ] ] }
Tetsuya K
