[FAQ] TPS6594-Q1: TPS6594-Q1 differences of orderables?
Part Number: TPS6594-Q1
Other Parts Discussed in Thread: TDA4VM, , DRA829
Hi Team,
Can you please check and advise with following request?
We have a design that uses TI's TDA4VM processor.
In TI's reference design, both PTPS659413F0RWERQ1 and TPS65941111RWERQ1 were used as PMICs.
We are also considering using the mnemonic structure, but we saw that TPS65941111RWERQ1 is ROHS while PTPS659413F0RWERQ1 is non-ROHS.
I have two questions for you about this, I would appreciate if you can help.
What are the main differences between the following variants of the TPS6594-Q1 with different part numbers? (PTPS659411F0RWERQ1, PTPS659413F0RWERQ1, PTPS659414F4RWERQ1
TPS65941111RWERQ1, TPS65941212RWERQ1)
I guess there are some differences from the factory set as one-time programmable. Is there a document listing them?
2-Can the material with the part number TPS65941212RWERQ1 (ROHS) be used instead of the material with the part number PTPS659413F0RWERQ1 (non-ROHS) in the sample design? If unavailable
Does ROHS production appear on the TI road map for PTPS659413F0RWERQ1?
Thanks in advance
Best Regards
Furkan Sefiloglu
