TPS54561: PWM switched feedback resistors
Part Number: TPS54561
I am wondering whether this arrangement to switch the lower side feedback resistor value using a PWM signal and a FET might work OK as a way to dynamically adjust the output voltage on the TPS54561?
Thanks.
  • Hello
    I don't think that would work, since you can not combine the filtering in the feedback.
    The large capacitor will add a low frequency pole to the loop.
    You will need to filter your PWM first, then apply it as a "DAC" voltage to the FB pin through a resistor.
    Then you don't need the FET.
    I have attached a spreadsheet that you may find helpful with this type of application.
    You will need to test it carefully on an EVM before going into production.
    DAC_calc4.xlsx
  • Hi Frank,
    I feared that might be the case. Thanks so much for your reply, I couldn't have asked for any more Slight smile
    All the best,
    Andres
