Hi
What is the maximum duty cycle limits of the TPS54325?
I designed the circuit with Webench.
But the error log is displayed.
I used the following parameters.
Thank you.
Hi
Thank you.
Hi Keisuke-san,
We are able to replicate the issue. Currently working with product expert to verify if its a valid fail.
Shall keep you updated on the same.
Thanks and Regards,
Umayal
Hi Keisuke-san,
Device TPS54325 has maximum duty cycle limit of 70%.
On discussion with product expert we have extended the maximum duty cycle of device to 80%.With this change design gets created for the condition mentioned above.
The change is currently in our internal servers and will be available on ti.com tentatively by end of next week.
We shall keep you updated on the same.
For an immediate reference kindly refer the attached design report for the condition mentioned above.1425.TPS54325.pdf
Thanks and regards,
Umayal
Hi Keisuke-san,
The fix is now available on ti.com.
Kindly let us know in case you have any queries.
Thanks & Regards,
Umayal
