Other Parts Discussed in Thread: TPS61041, TPS61096, TPS61040
Hello Expert,
Our customer is looking for ultra low current output boost converter.
I found TPS61288 on TI.com and simulate efficiency using WEBENCH in last week.
Below is last week simulation result.
TPS61288_SIM (1).pdf
It seems very good efficiency but it is too good rather that datasheet's result at low current load condition.
So I re-simulation efficiency using the same condition of datasheet(Vout=16V and FB resistor follow this E2E thread )
But this simulation result is similar against datasheet as below.
WBDesign332.pdf
Therefore, I reconfirmed efficiency using first simulation parameter.
But I got following result and it is completely different against first report even though I used same external components.
WBDesign331 (1).pdf
Then, I'd like to know about which simulation performance is similar as actual condition.
And, I'd want to know about whether both simulation result worth to trust.
Would you tell me answer for above questions?
Kazuki Kuramochi
