Other Parts Discussed in Thread: TPS40170, LM5145
Cluster_Cranking_Sheet-1.pdf We have modified the circuit as TI team guided us. kinldy check the modified circuit and provide your feeback. FYR please check the previous post for further infprmation.
Hello Anbarasan
#1-4 items are all fixed, but it looks like #5 item has not been checked. Please download the calculator here and check your compensation component selections https://www.ti.com/lit/zip/sluc263 \
And here are what I found additionally.
-Eric Lee (Applications Engineering)
Hi Eric Lee,
Thank you for your suggestions, It was very helpful to us.
As per your feedback we have modified the circuit.
Please go through the attached updated circuit one time and let us know if any changes needed in that.
We planned to manufacture the proto PCB, please help us to correct the major issues.
Thanks and Regards,
Anbarasan MCluster_Cranking_Sheet.pdf
Hello Anbarasan I found only one.
Hello Anbarasan
I will close this thread . If you have an issue, please feel free to open a new thread or reopen this thread.
