Hi ,
Planning to add Secondary protection for our BMS which has a spec of 60V, 60 Amp continuous, 100 Amp peak.
Couldn't find and e Fuse that suits our requirement .
* Can we use e Fuse in parallel to increase current rating ?
* Can you suggest any other solution that can be used to cut off power (from cells to output terminals - to be used in series with existing charging and discharging MOSFETs of BMS) ?
Thanks & Regards,
Anil
