Other Parts Discussed in Thread: ISO7831, UCC27712, LM1117, LM3410
Hi TIer,
We plan use LMG3411R150 design for totem pole PFC high speed leg in daughter card.
In 4 layer PCB and only use TOP layer to placement, and bottom just use to cooling with housing. found out the best isolator solution is Infineon's SOI Level shift such. because there is no iso-power need.
if use iso-power with digital isolator such as SN6506 with ISO7831, consider the good layout, need use top and bottom layer.
so, may I know TI have half bridge level 600V shift solution?
