Hi Sir,
My customer want to find a low noise solution for their sensor application. (5V to -1.2V with LDO). Do you think we can use LM27761 for that? Or other suggestion? Thanks for your kindly help.
Gary Teng
Hi Gary,
Unfortunately we do not have a Charge pump that could generate a -1.2Vout.
You may have to consider Inverting Bucks like TPS63710.
It would be interesting to know further about the sensor application.
-What exactly is the EE?
-Is it a typical requirement?
-What is the load for the -1.2V rail?
-What is the max load current required?
Febin
Hi Gary,
Just another thought, you could configure any buck in an inverted topology.
Please refer the App notes below or Blog.
Using the TPS62125 in an Inverting Buck-Boost Topology
Create an Inverting Power Supply From a Step-Down Regulator
Using a buck converter in an inverting buck-boost topology
Febin
Hi Gary,
Do you need any further support? If not, I will go ahead and close this thread.
Febin
