Other Parts Discussed in Thread: LM5164
Dear CC,
In our BMS board we have used LM5164 device. This circuit is design for 12V/1A. But nominal current is only 50mA.
During conducted emission test this is failed even we have removed BMS PCB load (MCU and other peripherals). we have connected fixed 100 Ohm resistance at output.
Could you please help to pass this buck converter in CISPR Class 3. I have tuned input EMI filter and output snubber circuit but there is no much benefit.
this is urgent and solution is needed on an urgent basis.
Please see the attached schematics and failed frequency range and graph.
Conducted emission failed at 535KHz to 710 KHz range.pdf
Thanks and regards
Subhash Dhyani
