Dear TI Teams,
We are plan to use TPS6287B10 to achieve 3.3V input and 0.85V/10A output. Form the datasheet we can learned that the VSET1 and VSET2 can set the defult output voltage to 0.85V, but we don't know how should the I2C interface be connected at this time. Can you help to confirm it?
We also designed the following circuit based on the pin definitions on the datasheet. Can you help check if there are any problem?
Kind Regards
