Other Parts Discussed in Thread: TLV62090
Hi TI,
I need a 5V input - 1V output buck converter, and I am considering to use TLVM13630. Why is the recommended output capacitance so large? It is written 300uF in the datasheet for Vout 1V.
The load current in my design is maximum 500mA. Is it possible to reduce the output capacitance? If yes, what would you recommend? In my current design, there is no room for several capacitors in parallel...
Thank you for your attention!
