My customer would like to know the work for safety timer at TMR pin. His application set CE pin to High (disable charge) from Low (enable charge). He expects the internal safety timer which is set at TMR pin will be cleared after setting CE pin to high. Is it correct?
If his expect is correct, how long will it take to reset the timer after setting High ?
e.g. his application currently wait 4ms to clear the timer after setting CE pin to high, He would like to know the actual time how long his application should wait.
Nagata.
