Hi team,
I know from data sheet that BQ24610 have battery detect function,and I test it in EVM.
when I only supply power to adapter(15v,2A), and I find the waveform of Vbat has a constant voltage of less than 1V.
Is this normal? According to my understanding, the waveform shown in the figure below should appear. Please tell me about this problem in detail
BR
Z
Hi Z,
Is charge enabled? Do you see STAT1 or STAT2 lit? most likely you are in a fault condition or charge is not enabled. Please follow the EVM user guide directions as closely as possible.
