Other Parts Discussed in Thread: TPS2116
Why the IN pin has leakage voltage about 4.xV when there is a 5V supply at OUT pin. In the TPS22953, it coming with the Reverse block feature, isn't?
In the circuitry, the SNS pin is pull up to OUT pin via resistance. Is that a problem? any suggestion?
Here is the application circutry.
Brian W
