Hi
I'd like to know the parameter of LPDDR4 config tool which is related to some header file.
I mean that I'd like to do convert back from header file to LPDDR4 config tool parameter.
Could you let me know the procedure how to do for it?
(Or, please let me know the parameter of LPDDR4 config tool which corresponding to the header file for TDA4VM EVM?)
Thanks and Best regards,
Tsurumoto.
There is no way to take a DTSI file and convert to XLS inputs.
Regarding the inputs used in the SDK 7.3 (4266 data rate), make the following changes to the default settings of the tool found on CDDS (version 0.5.0).
On "Config" tab, change A.7 (DDR Memory Frequency Set 2) to "2133"
On "DRAMTiming" tab, change the latency settings for F1 / F2 to the following:
Kevin
